查看: 2464|回復(fù): 0
MS51定時器的計數(shù)功能
ID:65608 發(fā)表于 2014-9-1 00:30 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
今天用到C/T的計數(shù)功能,一上午沒有搞定,很郁悶。下午才搞明白,51內(nèi)核C/T的外部脈沖計數(shù)功能,原來是不開中斷的。暈倒。!大半天的功夫都浪費了。∮涗浵聛硪詡渫!
#include <reg52.h>
void timer0Init(void)
TMOD &= 0xF0;
TMOD |= 0x05;
TH0 = 0xFF;
TL0 = 0xFD;
TR0 = 1;
void timer1Init(void)
TMOD &= 0x0F;
TMOD |= 0x50;
TH1 = 0xFF;
TL1 = 0xFD;
TR1 = 1;
void SystemInit(void)
EA = 0;
P1 = P2 = P3 = P0 = 0xFF;
timer0Init();
timer1Init();
EA = 1;
void main(void)
// unsigned int temp;
unsigned char count;
SystemInit();
//  temp = TL0|(TH0<<8);
  if(TF0)
   TF0 = 0;
   TH0 = 0xFF;
   TL0 = 0xFD;
//   P1  = temp;
   if(count++ >= 3)
    count = 0;
    P1 = ~P1;
  if(TF1)
   TF1 = 0;
   TH1 = 0xFF;
   TL1 = 0xFD;
//   P1  = temp;
   if(count++ >= 3)
    count = 0;
    P0 = ~P0;
   P2 = count;
