查看: 8084|回復(fù): 8
我做51單片機(jī),矩陣鍵盤輸入,想輸入4位數(shù),并在數(shù)碼管上顯示出來(lái),我的程序哪里不...
ID:65696 發(fā)表于 2014-9-2 18:15 | 顯示全部樓層 |閱讀模式
鍵盤掃描函數(shù),顯示函數(shù)都沒(méi)問(wèn)題,都測(cè)試過(guò)了,就主函數(shù)那一塊,一直調(diào)試不出來(lái),要實(shí)現(xiàn)的功能就是由鍵盤輸入,比如說(shuō)輸入2345,就在鍵盤上分別按2345鍵,然后由數(shù)碼管顯示出來(lái)
#include<reg52.h>
sbit wela=P2^7;
sbit dula=P2^6;
uchar temp,num,num1,bitnum=0,i,flag;
uint value,temp1=1;
uchar keybuffer[4];
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
void delay(x)
uint a,b;
for(a=x;a>0;a--)
for(b=110;b>0;b--);
void display(uint num)
uchar ge,shi,bai,qian;
ge=num%10;
shi=num%100/10;
bai=num%1000/100;
qian=num/1000;
wela=1;
P0=0xf7;
wela=0;
dula=1;
P0=table[ge];
dula=0;
delay(5);
wela=1;
P0=0xfb;
wela=0;
dula=1;
P0=table[shi];
dula=0;
delay(5);
wela=1;
P0=0xfd;
wela=0;
dula=1;
P0=table[bai];
dula=0;
delay(5);
wela=1;
P0=0xfe;
wela=0;
dula=1;
P0=table[qian];
dula=0;
delay(5);
uchar keyscan()
P1=0xfe;
temp=P1;
temp=temp&0xf0;
while(temp!=0xf0)
delay(5);
temp=P1;
temp=temp&0xf0;
while(temp!=0xf0)
temp=P1;
switch(temp)
case 0xee:num=1;flag=1;
break;
case 0xde:num=2;flag=1;
break;
case 0xbe:num=3;flag=1;
break;
case 0x7e:num=4;flag=1;
break;
while(temp!=0xf0)
temp=P1;
temp=temp&0xf0;
P1=0xfd;
temp=P1;
temp=temp&0xf0;
while(temp!=0xf0)
delay(5);
temp=P1;
temp=temp&0xf0;
while(temp!=0xf0)
temp=P1;
switch(temp)
case 0xed:num=5;flag=1;
break;
case 0xdd:num=6;flag=1;
break;
case 0xbd:num=7;flag=1;
break;
case 0x7d:num=8;flag=1;
break;
while(temp!=0xf0)
temp=P1;
temp=temp&0xf0;
P1=0xfb;
temp=P1;
temp=temp&0xf0;
while(temp!=0xf0)
delay(5);
temp=P1;
temp=temp&0xf0;
while(temp!=0xf0)
temp=P1;
switch(temp)
case 0xeb:num=9;flag=1;
break;
case 0xdb:num=10;flag=1;
break;
case 0xbb:num=11;flag=1;
break;
case 0x7b:num=12;flag=1;
break;
while(temp!=0xf0)
temp=P1;
temp=temp&0xf0;
P1=0xf7;
temp=P1;
temp=temp&0xf0;
while(temp!=0xf0)
delay(5);
temp=P1;
temp=temp&0xf0;
while(temp!=0xf0)
temp=P1;
switch(temp)
case 0xe7:num=13;flag=1;
break;
case 0xd7:num=14;flag=1;
break;
case 0xb7:num=15;flag=1;
break;
case 0x77:num=16;flag=1;
break;
while(temp!=0xf0)
temp=P1;
temp=temp&0xf0;
return num;
while(num1<10&bitnum<4)
num1=keyscan();
keybuffer[bitnum]=num1;
if(flag==1)
bitnum++;
flag=0;
for(i=0;i<bitnum;i++)
value=keybuffer[bitnum-i]*temp1+value;
temp1=temp1*10;
display(value);
ID:1 發(fā)表于 2014-9-2 18:29 來(lái)自觸屏版 | 顯示全部樓層
你現(xiàn)在這個(gè)程序按鍵以后,顯示屏上面有反應(yīng)嗎
ID:63656 發(fā)表于 2014-9-3 11:01 | 顯示全部樓層
本帖最后由 2842687945 于 2014-9-3 11:08 編輯
#include "reg52.h"
typedef unsigned int uint16;
typedef unsigned char uint8;
                uint8 d;
                P1 = 0xff;//初始化P1口
                        P1 = 0xfe;//第一行鍵,1111 1110
                        //第一行鍵的鍵碼的判斷
                        d = P1;
                        switch(d)
                                case 0xee:P0 = 0x3f;break;
                                case 0xde:P0 = 0x06;break;
                                case 0xbe:P0 = 0x5b;break;
                                case 0x7e:P0 = 0x4f;break;
                        P1 = 0xfd;//第二行鍵,1111 1101
                        //第二行鍵的鍵碼的判斷
                        d = P1;
                        switch(d)
                                case 0xed:P0 = 0x66;break;
                                case 0xdd:P0 = 0x6d;break;
                                case 0xbd:P0 = 0x7d;break;
                                case 0x7d:P0 = 0x07;break;
                        P1 = 0xfb;//第三行鍵,1111 1011
                        //第三行鍵的鍵碼的判斷
                        d = P1;
                        switch(d)
                                case 0xeb:P0 = 0x7f;break;
                                case 0xdb:P0 = 0x6f;break;
                                case 0xbb:P0 = 0x77;break;
                                case 0x7b:P0 = 0x7c;break;
                        P1 = 0xf7;//第四行鍵,1111 0111
                        //第四行鍵的鍵碼的判斷
                        d = P1;
                        switch(d)
                                case 0xe7:P0 = 0x39;break;
                                case 0xd7:P0 = 0x5e;break;
                                case 0xb7:P0 = 0x79;break;
                                case 0x77:P0 = 0x71;break;
ID:63656 發(fā)表于 2014-9-3 11:09 | 顯示全部樓層
這個(gè)程序是我寫的,我試過(guò)了
ID:65758 發(fā)表于 2014-9-3 16:09 | 顯示全部樓層
2842687945 發(fā)表于 2014-9-3 11:01
#include "reg52.h"
他要實(shí)現(xiàn)的是連續(xù)按鍵4次,然后出現(xiàn)千位數(shù)。
ID:65758 發(fā)表于 2014-9-3 16:50 | 顯示全部樓層
我感覺(jué)你那個(gè) flag 沒(méi)起作用,  另你在初始化下 num1=0  flag=0,  另外如果你那按鍵大于9以上的話,會(huì)直接調(diào)出while大循環(huán),
ID:65696 發(fā)表于 2014-9-3 21:04 | 顯示全部樓層
hesongchuan 發(fā)表于 2014-9-3 16:50
我感覺(jué)你那個(gè) flag 沒(méi)起作用,  另你在初始化下 num1=0  flag=0,  另外如果你那按鍵大于9以上的話,會(huì)直接 ...
那你說(shuō)我具體應(yīng)該怎么做呢
ID:65696 發(fā)表于 2014-9-3 21:05 | 顯示全部樓層
ID:65758 發(fā)表于 2014-9-5 18:02 | 顯示全部樓層
本帖最后由 hesongchuan 于 2014-9-7 13:57 編輯
lx983625241 發(fā)表于 2014-9-3 21:05
這幾天忙,很簡(jiǎn)答  啊,swith case ,語(yǔ)句   case 0x7e:num=4,flag=1;    num 和flag用逗號(hào)不要分號(hào),
把  num <=10的語(yǔ)句去掉,     另外while(num1<10&bitnum<5)  全局變量bitnum初值等于1。
下面程序可以實(shí)現(xiàn)連續(xù)按鍵四次,出現(xiàn)一個(gè)千位數(shù),然后在按第十個(gè)鍵  ,數(shù)碼管關(guān)閉,實(shí)驗(yàn)下吧。
#include<reg52.h>
sbit wela=P2^1;
sbit dula=P2^2;
sbit sb=P3^5;//管段數(shù)碼管鍵 第十個(gè)鍵
uchar temp,num,num1,bitnum=1,i,flag;
uint value,temp1=1;
void display(uint z);
uchar keyscan();
uchar keybuffer[4];
void delay(uint x)
uint a,b;
for(a=x;a>0;a--)
for(b=110;b>0;b--);
ge=z%10;
shi=z/10%10;
bai=z/100%10;
qian=z/1000%10;
wela=1;
P1=0xf7;
wela=0;
dula=1;
P1=table[ge];
dula=0;
delay(5);
wela=1;
P1=0xfb;
wela=0;
dula=1;
P1=table[shi];
dula=0;
delay(5);
wela=1;
P1=0xfd;
wela=0;
dula=1;
P1=table[bai];
dula=0;
delay(5);
wela=1;
P1=0xfe;
wela=0;
dula=1;
P1=table[qian];
dula=0;
delay(5);
uchar keyscan()
P3=0xfe;
temp=P3;
temp=temp&0xf0;
while(temp!=0xf0)
delay(5);
temp=P3;
temp=temp&0xf0;
while(temp!=0xf0)
temp=P3;
switch(temp)
case 0xee:num=1,flag=1;
break;
case 0xde:num=2,flag=1;
break;
case 0xbe:num=3,flag=1;
break;
break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
P3=0xfd;
temp=P3;
temp=temp&0xf0;
while(temp!=0xf0)
delay(5);
temp=P3;
temp=temp&0xf0;
while(temp!=0xf0)
temp=P3;
switch(temp)
case 0xed:num=5,flag=1;
break;
case 0xdd:num=6,flag=1;
break;
case 0xbd:num=7,flag=1;
break;
case 0x7d:num=8,flag=1;
break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
P3=0xfb;
temp=P3;
temp=temp&0xf0;
while(temp!=0xf0)
delay(5);
temp=P3;
temp=temp&0xf0;
while(temp!=0xf0)
temp=P3;
switch(temp)
case 0xeb:num=9,flag=1;
break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
return num;
while(bitnum<5)
num1=keyscan();
if(flag==1)
bitnum++;
flag=0;
value=0;
for(i=4;i>0;i--)
temp1=temp1*10;
temp1=1;
bitnum=0;
sb=1;
while(sb==1)     //未按管段鍵,一直執(zhí)行顯示程序。
display(value);
wela=1;
P1=0xff;
wela=0;
