查看: 3293|回復(fù): 6
LED點(diǎn)陣問題求教
ID:65890 發(fā)表于 2014-9-7 01:32 | 顯示全部樓層 |閱讀模式
取字模時(shí)是8*40的點(diǎn)陣,為什么我將index改成40運(yùn)行到最后會(huì)出現(xiàn)一行亂碼
#include <reg52.h>
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
unsigned char code image[] = {  //圖片的字模表
    0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
    0x99,0x99,0x99,0x99,0x99,0x81,0xC3,0xFF,
    0x99,0x00,0x00,0x00,0x81,0xC3,0xE7,0xFF,
    0xC3,0xE7,0xE7,0xE7,0xE7,0xE7,0xC3,0xFF,
    EA = 1;       //使能總中斷
    ENLED = 0;    //使能U4,選擇LED點(diǎn)陣
    ADDR3 = 0;
    TMOD = 0x01;  //設(shè)置T0為模式1
    TH0  = 0xFC;  //為T0賦初值0xFC67,定時(shí)1ms
    TL0  = 0x67;
    ET0  = 1;     //使能T0中斷
    TR0  = 1;     //啟動(dòng)T0
    while (1);
/* 定時(shí)器0中斷服務(wù)函數(shù) */
void InterruptTimer0() interrupt 1
    static unsigned char i = 0;  //動(dòng)態(tài)掃描的索引
    static unsigned char tmr = 0;  //250ms軟件定時(shí)器
    static unsigned char index = 39;
    TH0 = 0xFC;  //重新加載初值
    TL0 = 0x67;
    //以下代碼完成LED點(diǎn)陣動(dòng)態(tài)掃描刷新
    P0 = 0xFF;   //顯示消隱
    switch (i)
        case 0: ADDR2=0; ADDR1=0; ADDR0=0; i++; P0=image[index-7]; break;
        case 1: ADDR2=0; ADDR1=0; ADDR0=1; i++; P0=image[index-6]; break;
        case 2: ADDR2=0; ADDR1=1; ADDR0=0; i++; P0=image[index-5]; break;
        case 3: ADDR2=0; ADDR1=1; ADDR0=1; i++; P0=image[index-4]; break;
        case 4: ADDR2=1; ADDR1=0; ADDR0=0; i++; P0=image[index-3]; break;
        case 5: ADDR2=1; ADDR1=0; ADDR0=1; i++; P0=image[index-2]; break;
        case 6: ADDR2=1; ADDR1=1; ADDR0=0; i++; P0=image[index-1]; break;
        case 7: ADDR2=1; ADDR1=1; ADDR0=1; i=0; P0=image[index-0]; break;
        default: break;
    //以下代碼完成每250ms改變一幀圖像
    tmr++;
    if (tmr >= 250)  //達(dá)到250ms時(shí)改變一次圖片索引
        tmr = 0;
        if (index <= 8)
            index = 39;
            index--;
ID:1 發(fā)表于 2014-9-7 20:45 來自觸屏版 | 顯示全部樓層
電路圖呢
ID:58502 發(fā)表于 2014-9-8 00:51 | 顯示全部樓層
index取值范圍是0-39,剛好哦40個(gè)對(duì)應(yīng)點(diǎn)陣的40行。如果改為40,就有41行了,所以出錯(cuò)。如果你硬要用40的話就需要將圖片的字模表改一下
ID:65837 發(fā)表于 2014-9-9 09:48 | 顯示全部樓層
8*40,只有39,如果你喜歡40,就取1~40好了
ID:70898 發(fā)表于 2014-12-22 14:45 | 顯示全部樓層
樓主是用的宋雪松老師的單片機(jī)吧,錯(cuò)誤挺明顯的,字模數(shù)組一共40個(gè)元素,編號(hào)從0~39。當(dāng)你取40時(shí)image[index-0]找不到你賦的值,可能就去找內(nèi)存其他地址的數(shù)據(jù)讀出來了。我試過了,取40的時(shí)候讀出的數(shù)據(jù)是0x4B。之后就正常了,因?yàn)槟阍谥袛嗄┪布恿艘痪渥屗貧w39這個(gè)初值的語句。如果樓主把這里的39也改成40,之后的每次循環(huán)開始處都會(huì)出現(xiàn)0x4B對(duì)應(yīng)的LED燈亮的情況了。
ID:71239 發(fā)表于 2014-12-27 22:17 | 顯示全部樓層
你好 我也在研究這個(gè) 交流交流經(jīng)驗(yàn)
ID:250660 發(fā)表于 2017-12-3 11:39 | 顯示全部樓層
我自己用了p1   p2腳。沒有驅(qū)動(dòng)芯片,只有單片機(jī)和最小系統(tǒng),大神救救我,給我程序。可以顯示4個(gè)漢字的那種
