查看: 5269|回復(fù): 0
51單片機入門——捕獲(內(nèi)部中斷)
ID:65608 發(fā)表于 2014-9-12 01:01 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
uchar shi,ge,a,b;
uint num ;
sbit dula=P2^6;
sbit wela=P2^7;
uchar code table[]=
  0x3f,0x06,0x5b,0x4f,
  0x66,0x6d,0x7d,0x07,
  0x7f,0x6f,0x77,0x7c,
  0x39,0x5e,0x79,0x71
void delayms(uint);
void display(uchar shi,uchar ge)
  dula=1;
  P0=table[shi];
  dula=0;
  P0=0xff;
  wela=1;
  P0=0xfe;
  wela=0;
  delayms(5);
  dula=1;
  P0=table[ge] ;
  dula=0;
  P0=0xff;
  wela=1;
  P0=0xfd;
  wela=0;
  delayms(5);
void delayms(uint xms)
   uint i,j;
   for(i=xms;i>0;i--)
      for(j=110;j>0;j--);
uint read()
   uchar t1,th1,th2;
   uint val;
      th1=TH0;
t1=TL0;
th2=TH0;
if(th1==th2)
      break;
   val=th1*256+t1;
   return val;
{   TMOD=0x01;
TH0=(65536-45872)/256;
TL0=(65536-45872)%6;
EA=1;
ET0=1;
TR0=1;
      display(a,b);
  void T1_time()interrupt 1
   num=read();
   if(num==99)
      num=0;
