查看: 17942|回復(fù): 3
STM32 高級(jí)定時(shí)器TIM1“計(jì)時(shí)不準(zhǔn)”?
ID:65608 發(fā)表于 2014-9-15 17:16 | 顯示全部樓層 |閱讀模式
      最近,在學(xué)習(xí)STM32單片機(jī),選用的型號(hào)是通用型STM32F103,在學(xué)習(xí)定時(shí)器應(yīng)用時(shí),遇到了一個(gè)很頭疼的問(wèn)題,懷疑STM32 高級(jí)定時(shí)器TIM1“計(jì)時(shí)不準(zhǔn)”。       事情的來(lái)龍去脈是這樣的,之前寫(xiě)了一個(gè)通過(guò)tim1定時(shí)器中斷實(shí)現(xiàn)led閃爍的程序,測(cè)試時(shí)led閃爍頻率和我設(shè)置的頻率一致,當(dāng)我后面繼續(xù)這個(gè)程序上添加ad采樣程序后,調(diào)試時(shí),偶然發(fā)現(xiàn)led閃爍頻率變慢,RCC時(shí)鐘配置和原來(lái)一樣,為什么加個(gè)ad采樣程序,會(huì)影響定時(shí)器工作,這讓我覺(jué)得非常奇怪。
       led閃爍頻率變慢,可以肯定與RCC配置和定時(shí)器配置有關(guān),當(dāng)時(shí)寫(xiě)的程序如下:
void RCC_Configuration(void)
ErrorStatus HSEStartUpStatus;
RCC_DeInit();
RCC_HSEConfig(RCC_HSE_ON);
HSEStartUpStatus=RCC_WaitForHSEStartUp();
if(HSEStartUpStatus == SUCCESS)
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
FLASH_SetLatency(FLASH_Latency_2);
RCC_HCLKConfig(RCC_SYSCLK_Div1);
RCC_PCLK2Config(RCC_HCLK_Div1);
RCC_PCLK1Config(RCC_HCLK_Div2);
RCC_ADCCLKConfig(RCC_PCLK2_Div6);
RCC_PLLConfig(RCC_PLLSource_HSE_Div2,RCC_PLLMul_9);     //16M外部晶振,16/2M*9=72
RCC_PLLCmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY)==RESET);
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
while(RCC_GetSYSCLKSource() !=0x08);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1,ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);
void TIM1_Configuration(void)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef     TIM_OCInitStructure;
TIM_DeInit(TIM1);
TIM_InternalClockConfig(TIM1);
TIM_TimeBaseStructure.TIM_Period = 2000;          //計(jì)數(shù)2000次,每2000/2K=1s產(chǎn)生一次中斷
TIM_TimeBaseStructure.TIM_Prescaler = 35999;    //進(jìn)行預(yù)分頻35999+1,72M/36K=2K Hz
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM1,&TIM_TimeBaseStructure);
TIM_PrescalerConfig(TIM1,35999,TIM_PSCReloadMode_Immediate);
TIM_ClearFlag(TIM1,TIM_FLAG_Update);
        TIM_ARRPreloadConfig(TIM1, DISABLE);
TIM_ITConfig(TIM1,TIM_IT_Update,ENABLE);
      從程序上看Tim1每一秒產(chǎn)生一次中斷,在中斷函數(shù)中實(shí)現(xiàn)led亮一秒暗一秒,但是實(shí)際led閃爍頻率會(huì)變慢,而當(dāng)我改變ad采集口時(shí),led閃爍頻率會(huì)變得更慢,配置io會(huì)影響時(shí)鐘,很無(wú)厘頭,這芯片還敢用嗎?實(shí)在沒(méi)辦法,我配置了一下Tim2,用Tim2定時(shí)中斷,結(jié)果一切都工作正常。這是什么邏輯,高級(jí)定時(shí)器tim1反而沒(méi)普通定時(shí)器tim2靠譜,無(wú)語(yǔ)。。。。。
       最近又查了下資料,終于發(fā)現(xiàn)tim1定時(shí)器有一些特有的配置功能,它可以控制溢出中斷的周期,它是由寄存器TIM1_RCR控制,如下圖所示,庫(kù)函數(shù)中是由TIM_TimeBaseStructure.TIM_RepetitionCounter 來(lái)控制
當(dāng)TIM_TimeBaseStructure.TIM_RepetitionCounter=N時(shí),表示重復(fù)溢出N次后,才產(chǎn)生一次中斷;當(dāng)TIM_TimeBaseStructure.TIM_RepetitionCounter=0時(shí),當(dāng)然就表示溢出直接中斷。所以當(dāng)在配置tim1定時(shí)器時(shí),在TIM_TimeBaseInit();前面加一句TIM_TimeBaseStructure.TIM_RepetitionCounter=0;定時(shí)器1一切工作正常。
       問(wèn)題雖然解決,但依然很奇怪的是,TIM1_RCR的復(fù)位值為0,即使我不在程序中將其置零,也不會(huì)影響它的值,為什么程序運(yùn)行時(shí)它的值會(huì)莫名其妙的被改變,這個(gè)問(wèn)題想不通!
       P.S. 測(cè)試時(shí)又偶然發(fā)現(xiàn),TIM1和TIM2工作時(shí)的時(shí)鐘頻率都是72M,不是說(shuō)TIM2是來(lái)源于A(yíng)PB2,是36M嗎?
ID:77005 發(fā)表于 2016-5-11 23:33 | 顯示全部樓層
哥們  特意注冊(cè)一個(gè)號(hào)來(lái)感謝你啊,這個(gè)問(wèn)題困擾我好久。。。
ID:142416 發(fā)表于 2016-10-12 12:07 | 顯示全部樓層
感謝~查了半天~終于知道了~以前能用的就是調(diào)整優(yōu)化級(jí)別后出現(xiàn)的問(wèn)題~
那個(gè)來(lái)源APB2的定時(shí)器是有一個(gè)2倍頻的~所以也是72m
ID:194316 發(fā)表于 2017-4-27 19:36 | 顯示全部樓層
哥們。我特意注冊(cè)了一個(gè)號(hào)碼,來(lái)感謝你的,今天下午排查這個(gè)問(wèn)題半天,看到你的提示,解決問(wèn)題了,謝謝。對(duì)于你說(shuō)的為什么TIME2 時(shí)鐘會(huì)是72MHZ,你仔細(xì)看時(shí)鐘樹(shù),當(dāng)你配置住時(shí)鐘為72Mhz,經(jīng)過(guò)APB1 2分頻為36MHZ,這個(gè)時(shí)鐘一個(gè)是給給了APB1外設(shè),另外是給定時(shí)器2-7,但是給定時(shí)器2-7之前,有句話(huà)是“如果APB1預(yù)分頻系數(shù)為1,那么頻率不變,不為1,那么頻率為*2”,我們APB1預(yù)分頻系數(shù)為2,所以定時(shí)器2-7的時(shí)鐘頻率就為了72Mhz。
