甲機(jī)程序: #include <reg52.h>#define uint unsigned int
sbit LED1 = P0^0;
sbit LED2 = P0^3;
sbit K1 = P1^0;
void Delay(uint x)
uchar i;
while(x--)
for(i=0;i<120;i++);
void putc_to_SerialPort(uchar c)
SBUF = c;
while(TI == 0);
TI = 0;
uchar Operation_NO = 0;
SCON = 0x40;
TMOD = 0x20;
PCON = 0x00;
TH1 = 0xfd;
TL1 = 0xfd;
TI = 0;
TR1 = 1;
if(K1 == 0)
while(K1==0);
Operation_NO=(Operation_NO+1)%4;
switch(Operation_NO)
case 0:
LED1=LED2=1; break;
case 1:
putc_to_SerialPort('A');
LED1=~LED1;LED2=1;break;
case 2:
putc_to_SerialPort('B');
LED2=~LED2;LED1=1;break;
case 3:
putc_to_SerialPort('C');
LED1=~LED1;LED2=LED1;break;
Delay(10);
********************************************************************************************************************乙機(jī)程序:
#include <reg52.h>
uchar a,b;
uint num;
//sfr T2MOD = 0xC9; //reg52.h頭文件中未定義,故此處單獨(dú)添加sfr定義
sbit SW1 = P1^5;
sbit SW2 = P1^6;
sbit SW3 = P1^7;
sbit LED= P3^4;
uchar code table[]={0xC0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,};
// 主程序
void delayms(int z)
int x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void display(uchar shi,uchar ge)
P2=table[shi];
delayms(5);
P0=table[ge];
delayms(5);
uint read(uchar THX,uchar TLX)
uchar tl,th1,th2;
uint val;
th1=THX;
tl=TLX;
th2=THX;
if(th1==th2)
break;
val=th1*256+tl;
return val;
SCON =0x50;
PCON =0x00;
TMOD =0x25;
TH1 =0xfd;
TL1 =0xfd;
TH0 =0X00;
TL0=0x00;
TR0 =1;
TR1 = 1;
RI = 0;
if(RI)
RI = 0;
switch(SBUF)
case 'A': LED=~LED;delayms(100);break;
case 'B': LED=1;delayms(100);break;
case 'C': LED=0;delayms(100);break;
LED=1;
delayms(100);
num=read(TH0,TL0);
if(num>99)
num=0;
TH0=0;
TL0=0;
a=num/10;
b=num%10;
display(a,b);
