查看: 4783|回復(fù): 2
51單片機(jī)紅外線解碼程序
ID:68618 發(fā)表于 2014-11-11 18:45 | 顯示全部樓層 |閱讀模式
*                                          小玩意                                                       *
*   意義:第一次大量用指針寫程序                                                          *
*  作者:大海  ~0~        *
#include <reg51.h>
#include <intrins.h>
typedef unsigned   char uchar;
typedef unsigned   int uint;
#define delayNOP();  {_nop_();_nop_();_nop_();_nop_();};
#define LEDNF(x)    LED1=x&0x01;LED2=(x>>1)&0x01;LED3=(x>>2)&0x01;LED4=(x>>3)&0x01;    //通過宏簡單控制
#define ON          ENA=0; ENB=0
#define OFF    ENA=1; ENB=1;
#define NOLE       IN1=0; IN2=0; IN3=0; IN4=0;
struct Good
uchar goodx;
uchar goody;
void delay(uchar x);  //x*0.14MS
void delay1(uint ms);
void beep();
void LEDRW();
void LEDSRW(uchar,uchar);
void loop(uchar x,uchar y,uchar (*n)[20]);
void too();
void init();
void Jm(uchar);
sbit IRIN = P3^2;         //紅外接收器數(shù)據(jù)線
sbit BEEP = P3^7;         //蜂鳴器驅(qū)動線
sbit L1   = P2^0;    //數(shù)碼管選通
sbit L2   = P2^1;
sbit L3   = P2^2;
sbit L4   = P2^3;
sbit LED1 = P2^4;     //p2口led
sbit LED2 = P2^5;
sbit LED3 = P2^6;
sbit LED4 = P2^7;
sbit ENA  = P3^7;     //too控制
sbit IN1  = P1^7;
sbit IN2  = P1^6;
sbit IN3  = P1^5;
sbit IN4  = P1^4;
sbit ENB  = P1^3;
uchar i;      //時(shí)鐘
uchar x,y;
uchar *unx,*uny;
uchar LED[10]={0x40,0xf9,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10};
uchar IRCOM[7];
uchar shuju[20][2]={{9,17},{9,18},{9,19},{9,16},{9,17},{9,18},{9,19},{9,16}};     //動作數(shù)據(jù)存儲
uchar (*p)[2];
struct Good nooxy;      //結(jié)構(gòu)體用作數(shù)據(jù)傳遞
struct Good *xy;
main()
init();
  LEDSRW(*unx,*uny);
} //end main
void init()
    IRIN=1;                    //I/O口初始化
    BEEP=1;
    delay1(10);                 //延時(shí)
EA=1;
EX0=1;
ET0=1;        //允許總中斷中斷,使能 INT0 外部中斷
TH0=(65536-50000)/256;
TL0=(65536-50000)%25;  //裝初值,定時(shí)器50ms溢出
TCON = 0x01;               //觸發(fā)方式為脈沖負(fù)邊沿觸發(fā)
p=shuju;
unx=&x;
uny=&y;
xy=&nooxy;
void IR_IN() interrupt 0 using 0
  static uchar _i,a;
  unsigned char j,k,N=0;
     EX0 = 0;
  delay(15);
  if (IRIN==1)
     { EX0 =1;
    return;
                           //確認(rèn)IR信號出現(xiàn)
  while (!IRIN)            //等IR變?yōu)楦唠娖,跳過9ms的前導(dǎo)低電平信號。
    {delay(1);}
for (j=0;j<4;j++)         //收集四組數(shù)據(jù)
  for (k=0;k<8;k++)        //每組數(shù)據(jù)有8位
   while (IRIN)            //等 IR 變?yōu)榈碗娖,跳過4.5ms的前導(dǎo)高電平信號。
     {delay(1);}
    while (!IRIN)          //等 IR 變?yōu)楦唠娖?br />      {delay(1);}
     while (IRIN)           //計(jì)算IR高電平時(shí)長
    delay(1);
    N++;
    if (N>=30)
  EX0=1;
  return;}                  //0.14ms計(jì)數(shù)過長自動離開。
      }                        //高電平計(jì)數(shù)完畢
     IRCOM[j]=IRCOM[j] >> 1;                  //數(shù)據(jù)最高位補(bǔ)“0”
     if (N>=8) {IRCOM[j] = IRCOM[j] | 0x80;}  //數(shù)據(jù)最高位補(bǔ)“1”
     N=0;
   }//end for k
}//end for j
     if (IRCOM[2]!=~IRCOM[3])
    { EX0=1;
      return; }
  if(IRCOM[2]!=28&&IRCOM[2]!=11)
   if(_i==0)
   loop(*unx,*uny,shuju);
    (*uny==1)?(*uny=0):(*uny=1);
    if(*uny==0)
     (*unx>=19)?(*unx=0):(++*unx);
   ON;
    TR0=0;
   NOLE;
   TR0=0;
   if(IRCOM[2]==18) //前
    IN1=1;
    IN2=0;
    IN3=1;
    IN4=0;
   if(IRCOM[2]==19)   //后
    IN1=0;
    IN2=1;
    IN3=0;
    IN4=1;
   if(IRCOM[2]==16)  //左
    IN1=0;
    IN2=1;
    IN3=0;
    IN4=0;
   if(IRCOM[2]==17)    //右
    IN1=0;
    IN2=0;
    IN3=1;
    IN4=0;
   if(IRCOM[2]==15)
       NOLE;
  else if(IRCOM[2]==28)
   if(*unx!=0&&uny!=0)
    xy->goodx=*unx;
   xy->goody=*uny;
  *uny=0;
  *unx=0;
  OFF;
  TR0=1;
  _i=~_i;
     beep();
     EX0 = 1;
  for(a=500;a>0;a--)
  LEDRW();
void IT_IN() interrupt 1
static uchar num;
if(num==100)
  num=0;
  i++;
  too();
  LED1=~LED1;
num++;
void beep()
  unsigned char i;
  for (i=0;i<100;i++)
    delay(4);
    BEEP=!BEEP;                 //BEEP取反
  BEEP=1;                      //關(guān)閉蜂鳴器
void LEDRW()
P0=LED[(IRCOM[2]/1000)];   //計(jì)算紅外的碼值并在二極管上顯示
L4=0;
   delayNOP();
L4=1;
P0=LED[((IRCOM[2]%1000)/100)];
L3=0;
    delayNOP();
L3=1;
  P0=LED[(((IRCOM[2]%1000)%100)/10)];
L2=0;
delayNOP();
L2=1;
P0=LED[(((IRCOM[2]%1000)%100)%10)];
L1=0;
    delayNOP();
L1=1;
void LEDSRW(char x,uchar y)
P0=LED[y];   //顯示當(dāng)前數(shù)據(jù)
L4=0;
   delayNOP();
L4=1;
/* P0=LED[];
L3=0;
    delayNOP();
L3=1;   */
  P0=LED[x/10];
L2=0;
delayNOP();
L2=1;
P0=LED[x%10];
L1=0;
    delayNOP();
L1=1;
void loop(uchar x,uchar y,uchar (*n)[2])
*(*(n+x)+y)=IRCOM[2];
void too()       //行走控制
static uchar n;
if(i==*(*(p+n)+1))
n++;
i=0;
if(n>=xy->goodx)
  n=0;
  beep();
Jm(n);
void Jm(uchar n)
if(*(*(p+n)+0)==18) //前
  IN1=1;
  IN2=0;
  IN3=1;
  IN4=0;
if(*(*(p+n)+0)==19)   //后
  IN1=0;
  IN2=1;
  IN3=0;
  IN4=1;
if(*(*(p+n)+0)==16)  //左
  IN1=0;
  IN2=1;
  IN3=0;
  IN4=0;
if(*(*(p+n)+0)==17)    //右
  IN1=0;
  IN2=0;
  IN3=1;
  IN4=0;
void delay(unsigned char x)    //x*0.14MS
  unsigned char i;
   while(x--)
    for (i = 0; i<13; i++) {}
void delay1(int ms)
  unsigned char y;
   while(ms--)
    for(y = 0; y<250; y++)
      _nop_();
      _nop_();
      _nop_();
      _nop_();
ID:66287 發(fā)表于 2015-6-2 10:30 | 顯示全部樓層
應(yīng)該是解TC9012的程序,很有新意!
ID:47634 發(fā)表于 2016-1-5 08:39 | 顯示全部樓層
很好很好,學(xué)習(xí)了
