查看: 4577|回復(fù): 0
avr單片機(jī)mega32基于狀態(tài)機(jī)的按鍵設(shè)計(jì)
ID:68618 發(fā)表于 2014-11-11 22:51 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
以前用延時(shí)消抖,比較浪費(fèi)時(shí)間,現(xiàn)在用狀態(tài)機(jī)設(shè)計(jì),不占用太多時(shí)間,但是需要一個(gè)定時(shí)器。
1.狀態(tài)機(jī)按鍵消抖
//狀態(tài)機(jī)按鍵消抖
//CPU:mega32
//編譯器:winavr
#include <avr/io.h>
#include <avr/interrupt.h>
char key_scan(void);
#define PRESS   ( PIND&(1<<3) ) == 0
#define NOT_PRESS  ( PIND&(1<<3) ) != 0
int main(void)
DDRC |= (1 << 7);//PC7置為輸出
PORTD |= 1<<3;//按鍵上拉
TIMSK |= 1<<OCIE0;//不屏蔽T0匹配中斷
OCR0 = 0X10;//匹配值 大約10ms
TCCR0 |= (1 << WGM01) | (0 << WGM00) | (1 << CS02) | (0 << CS01) | (1 << CS00);//CTC模式,1024分頻
sei();//使能全局中斷
while(1);
SIGNAL(SIG_OUTPUT_COMPARE0)//TIMER0 匹配中斷服務(wù)程序
if ( key_scan() == 1 )
  PORTC ^= 1<<7;//PC7取反
char key_scan(void)
static char state=0;
switch(state)
case 0: if ( PRESS )
    state = 1;
    return 0;
    state = 0;
    return 0;
case 1: if ( PRESS )
    state = 2;
    return 1;
    state = 0;
    return 0;
case 2: if ( PRESS )
    state = 2;
    return 0;
    state = 0;
    return 0;
return 0;
2.狀態(tài)機(jī)按鍵檢測(cè)連擊
//狀態(tài)機(jī)按鍵消抖
//CPU:mega32
//編譯器:winavr
#include <avr/io.h>
int main(void)
DDRC |= (1 << 7) | (1 << 6);//PC7 PC6 置為輸出
PORTD |= 1<<3;//PD3按鍵內(nèi)部上拉
sei();//使能全局中斷
while(1);
char key;
key = key_scan();
if ( key == 1 )
if ( key == 2 ) //連擊
  PORTC ^= 1<<6;//PC6取反
char key_scan(void)
char times;
switch(state)
    state = 1;
    return 0;
    state = 0;
    return 0;
    times = 0;
    state = 2;
    return 1;
    state = 0;
    return 0;
    state = 2;
    times++;
    if (times > 50)//500ms
     times = 0;
     return 2;
     return 0;
    state = 0;
    return 0;
return 0;
