查看: 5761|回復(fù): 0
ATmega32單片機(jī)定時(shí)器程序
ID:68618 發(fā)表于 2014-11-11 22:52 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
ATmega32的有三個(gè)定時(shí)器,T0和T2是8位的,T1是16位的,各自提供了很多功能
都是以前用studio寫的,那時(shí)還沒(méi)用iar
//定時(shí)器0溢出中斷
//CPU:mega32
//編譯器:winavr
#include <avr/io.h>
#include <avr/interrupt.h>
int main(void)
DDRC |= (1 << 7);//PC7置為輸出
TIMSK |= 1<<TOIE0;//不屏蔽T0溢出中斷
TCCR0 |= (1 << CS02) |(0 << CS01) | (1 << CS00);//1024分頻
sei();//使能全局中斷
while(1);
SIGNAL(SIG_OVERFLOW0)//TIMER0 溢出中斷服務(wù)程序
PORTC ^= 1<<7;//PC7取反
//定時(shí)器0普通匹配模式中斷
//CPU:mega32
//編譯器:winavr
#include <avr/io.h>
int main(void)
TIMSK |= 1<<OCIE0;//不屏蔽T0匹配中斷
OCR0 = 0X10;//匹配值
sei();//使能全局中斷
while(1);
SIGNAL(SIG_OUTPUT_COMPARE0)//TIMER0 匹配中斷服務(wù)程序
TCNT0 = 0;//計(jì)數(shù)值清0
//定時(shí)器0匹配時(shí)清零模式(CTC)中斷
//CPU:mega32
//編譯器:winavr
#include <avr/io.h>
int main(void)
DDRB |= (1 << 3);//PC7置為輸出
OCR0 = 0X10;//匹配值
TCCR0 |= (1 << WGM01) | (0 << WGM00) | (1 << CS02) | (0 << CS01) | (1 << CS00);//CTC模式,1024分頻
sei();//使能全局中斷
while(1);
//定時(shí)器0輸出正弦波
//CPU:mega32
//編譯器:winavr
#include <avr/io.h>
const char sindata[128] = {128,134,140,147,153,159,165,171,177,182,188,
193,199,204,209,213, 218,222,226,230,234,237,240,243,245,248,250,251,253,254,
254,255, 255,255,254,254,253,251,250,248,245,243,240,237,234,230,226,222, 218,
213,209,204,199,193,188,182,177,171,165,159,153,147,140,134, 128,122,116,109,
103,97,91,85,79,74,68,63,57,52,47,43, 38,34,30,26,22,19,16,13,11,8,6,5,3,2,2,1,
1,1,2,2,3,5,6,8,11,13,16,19,22,26,30,34, 38,43,47,52,57,63,68,74,79,85,91,97,
103,109,116,122};
unsigned char x=0;
int main(void)
DDRB |= (1 << 3);//PB3  (OC0)  置為輸出
TCCR0 |= (1 << WGM01) | (1 << WGM00) | (1 << COM01) | (0 << COM00) |(0 << CS02) | (0 << CS01) | (1 << CS00);//CTC模式,“高低”占空比,不分頻
sei();//使能全局中斷
while(1);
OCR0 = sindata[x];
if( ++x > 127 ) x=0;
//定時(shí)器1捕捉中斷
//CPU:mega32
//編譯器:winavr
#include <avr/io.h>
int main(void)
TIMSK |= 1<<TICIE1;//不屏蔽T1捕捉中斷
TCCR1A |= (0<<WGM11) | (0<<WGM10);
TCCR1B |= (0<<WGM13) | (0<<WGM12) | (0 << CS12) |(1 << CS11) | (0 << CS10);//普通模式,不分頻
sei();//使能全局中斷
while(1);
SIGNAL(SIG_INPUT_CAPTURE1)//TIMER1 捕捉中斷服務(wù)程序
//定時(shí)器1溢出中斷
//CPU:mega32
//編譯器:winavr
#include <avr/io.h>
int main(void)
TIMSK |= 1<<TOIE1;//不屏蔽T1溢出中斷
sei();//使能全局中斷
while(1);
SIGNAL(SIG_OVERFLOW1)//TIMER1 溢出中斷服務(wù)程序
TCNT1H = 0X99;//先寫高位,后寫低位
TCNT1L = 0X88;
//定時(shí)器測(cè)頻率
//定時(shí)器1計(jì)數(shù),定時(shí)器2定時(shí)
//CPU:mega32
//編譯器:winavr
#include <avr/io.h>
#define F 1000000
int main(void)
TIMSK |= 1<<OCIE2;//不屏蔽T2匹配中斷
OCR2 = 0.1  *F/1024;//定時(shí)0.1s
TCCR2 |= (1 << WGM01) | (0 << WGM00) | (1 << CS02) | (1 << CS01) | (1 << CS00);//CTC模式,1024分頻
sei();//使能全局中斷
TCCR1B |= (0<<WGM13) | (0<<WGM12) | (1 << CS12) |(1 << CS11) | (0 << CS10);//普通模式,T1下降沿計(jì)數(shù)
while(1);
SIGNAL(SIG_OUTPUT_COMPARE2)//TIMER2 匹配中斷服務(wù)程序
TCNT1H = 0;
TCNT1L = 0;
//定時(shí)器測(cè)1捕捉中斷
//可以測(cè)周期用
//CPU:mega32
//編譯器:winavr
#include <avr/io.h>
int main(void)
sei();//使能全局中斷
while(1);
TCNT1H = 0;
TCNT1L = 0;
