可以的,這個是我買的開發(fā)板上的配夽程序:/********************************************************************************
* 描述: *
* lcd1602顯示 遙控鍵值讀取器 *
* lcd1602顯示 遙控器接p3.3 *
* 喇叭接p3.6 *
* 連接方法:使用紅外功能時 J1跳線短接 *
#include <reg51.h>
#include <intrins.h>
#define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};
void delay(uchar x); //x*0.14MS
void delay1(int ms);
void beep();
sbit IRIN = P3^3; //紅外接收器數(shù)據(jù)線
sbit BEEP = P3^6; //蜂鳴器驅(qū)動線
sbit RELAY= P1^4; //繼電器驅(qū)動線
uchar IRCOM[7];
sbit LCD_RS = P2^3;
sbit LCD_RW = P2^4;
sbit LCD_EN = P2^5;
uchar code cdis1[ ] = {" Red Control "};
uchar code cdis2[ ] = {" IR-CODE: --H "};
/*檢查LCD忙狀態(tài) */
/*lcd_busy為1時,忙,等待。lcd-busy為0時,閑,可寫指令與數(shù)據(jù)。 */
bit lcd_busy()
bit result;
LCD_RS = 0;
LCD_RW = 1;
LCD_EN = 1;
delayNOP();
result = (bit)(P0&0x80);
LCD_EN = 0;
return(result);
/*寫指令數(shù)據(jù)到LCD */
/*RS=L,RW=L,E=高脈沖,D0-D7=指令碼。 */
void lcd_wcmd(uchar cmd)
while(lcd_busy());
LCD_RS = 0;
LCD_RW = 0;
LCD_EN = 0;
_nop_();
_nop_();
// cmd = ((cmd&0x01)<<7)|((cmd&0x02)<<5)|((cmd&0x04)<<3)|((cmd&0x08)<<1)|((cmd&0x10)>>1)|((cmd&0x20)>>3)|((cmd&0x40)>>5)|((cmd&0x80)>>7);
P0 = cmd;
delayNOP();
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
/*寫顯示數(shù)據(jù)到LCD */
/*RS=H,RW=L,E=高脈沖,D0-D7=數(shù)據(jù)。 */
void lcd_wdat(uchar dat)
while(lcd_busy());
LCD_RS = 1;
LCD_RW = 0;
LCD_EN = 0;
// dat = ((dat&0x01)<<7)|((dat&0x02)<<5)|((dat&0x04)<<3)|((dat&0x08)<<1)|((dat&0x10)>>1)|((dat&0x20)>>3)|((dat&0x40)>>5)|((dat&0x80)>>7);
P0 = dat;
delayNOP();
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
/* LCD初始化設(shè)定 */
void lcd_init()
delay1(15);
lcd_wcmd(0x38); //16*2顯示,5*7點(diǎn)陣,8位數(shù)據(jù)
delay1(5);
lcd_wcmd(0x38);
delay1(5);
lcd_wcmd(0x38);
delay1(5);
lcd_wcmd(0x0c); //顯示開,關(guān)光標(biāo)
delay1(5);
lcd_wcmd(0x06); //移動光標(biāo)
delay1(5);
lcd_wcmd(0x01); //清除LCD的顯示內(nèi)容
delay1(5);
/* 設(shè)定顯示位置 */
void lcd_pos(uchar pos)
lcd_wcmd(pos | 0x80); //數(shù)據(jù)指針=80+地址變量
main()
uchar m;
IRIN=1; //I/O口初始化
BEEP=1;
RELAY=1;
delay1(10); //延時
lcd_init(); //初始化LCD
lcd_pos(0); //設(shè)置顯示位置為第一行的第1個字符
m = 0;
while(cdis1[m] != '\0')
{ //顯示字符
lcd_wdat(cdis1[m]);
m++;
lcd_pos(0x40); //設(shè)置顯示位置為第二行第1個字符
m = 0;
while(cdis2[m] != '\0')
lcd_wdat(cdis2[m]); //顯示字符
m++;
// IE = 0x81; //允許總中斷中斷,使能 INT0 外部中斷
// TCON = 0x01; //觸發(fā)方式為脈沖負(fù)邊沿觸發(fā)
IT1=1;
EX1=1;
EA=1;
while(1) ;
} //end main
void IR_IN() interrupt 2 using 0
unsigned char j,k,N=0;
EX1 = 0;
delay(15);
if (IRIN==1)
{ EX1 =1;
return;
//確認(rèn)IR信號出現(xiàn)
while (!IRIN) //等IR變?yōu)楦唠娖,跳過9ms的前導(dǎo)低電平信號。
{delay(1);}
for (j=0;j<4;j++) //收集四組數(shù)據(jù)
for (k=0;k<8;k++) //每組數(shù)據(jù)有8位
while (IRIN) //等 IR 變?yōu)榈碗娖,跳過4.5ms的前導(dǎo)高電平信號。
{delay(1);}
while (!IRIN) //等 IR 變?yōu)楦唠娖?br />
{delay(1);}
while (IRIN) //計算IR高電平時長
delay(1);
N++;
if (N>=30)
{ EX1=1;
return;} //0.14ms計數(shù)過長自動離開。
} //高電平計數(shù)完畢
IRCOM[j]=IRCOM[j] >> 1; //數(shù)據(jù)最高位補(bǔ)“0”
if (N>=8) {IRCOM[j] = IRCOM[j] | 0x80;} //數(shù)據(jù)最高位補(bǔ)“1”
N=0;
}//end for k
}//end for j
if (IRCOM[2]!=~IRCOM[3])
{ EX1=1;
return; }
IRCOM[5]=IRCOM[2] & 0x0F; //取鍵碼的低四位
IRCOM[6]=IRCOM[2] >> 4; //右移4次,高四位變?yōu)榈退奈?br />
if(IRCOM[5]>9)
{ IRCOM[5]=IRCOM[5]+0x37;}
IRCOM[5]=IRCOM[5]+0x30;
if(IRCOM[6]>9)
{ IRCOM[6]=IRCOM[6]+0x37;}
IRCOM[6]=IRCOM[6]+0x30;
lcd_pos(0x4b);
lcd_wdat(IRCOM[6]); //第一位數(shù)顯示
lcd_pos(0x4c);
lcd_wdat(IRCOM[5]); //第二位數(shù)顯示
beep();
EX1 = 1;
void beep()
unsigned char i;
for (i=0;i<100;i++)
delay(4);
BEEP=!BEEP; //BEEP取反
BEEP=1; //關(guān)閉蜂鳴器
void delay(unsigned char x) //x*0.14MS
unsigned char i;
while(x--)
for (i = 0; i<13; i++) {}
void delay1(int ms)
unsigned char y;
while(ms--)
for(y = 0; y<250; y++)
_nop_();
_nop_();
_nop_();
_nop_();
