#include<reg52.h>
sbit rs=P3^5; //這里沒(méi)有讀寫(xiě)定義是因?yàn)橹苯咏拥亓,因(yàn)槠綍r(shí)都用來(lái)寫(xiě)程序;
sbit en=P3^4; //只要控制rs和en端就可以
sbit dula=P2^6;
sbit wela=P2^7;
uchar temp;int n;
int flag,nn;
void delay(uint x)
uint a,b;
for(a=x;a>0;a--)
for(b=10;b>0;b--);
void delay1(uint x)
uint a,b;
for(a=x;a>0;a--)
for(b=100;b>0;b--);
void write_com(uchar com)
P0=com; //命令寫(xiě)入P0口,待會(huì)使能端可以讀走
rs=0; //寫(xiě)命令
en=0;
delay(10);
en=1;
delay(10);
en=0;
void write_date(uchar date)
P0=date;
rs=1; //寫(xiě)數(shù)據(jù)
en=0;
delay(10);
en=1;
delay(10);
en=0;
uint keyscan()
P3=0xfe;
temp=P3;
temp=temp&0xf0;
while(temp!=0xf0)
{delay(5);
temp=P3;
temp=temp&0xf0;
while(temp!=0xf0)
temp=P3;
switch(temp)
{case 0xee:n=1;break;
case 0xde:n=2;break;
case 0xbe:n=3;break;
case 0x7e:n=4;break;
while(temp!=0xf0)
{temp=P3;
temp=temp&0xf0;
return n;
void init()
dula=0; //這里主要是防止數(shù)碼管亮導(dǎo)致功率增大影響LCD
wela=0;
write_com(0x38); //顯示模式設(shè)置
delay(20);
write_com(0x0f); //顯示光標(biāo)同時(shí)閃爍
delay(20);
write_com(0x06); //正序顯示,07是整屏左移
delay(20);
write_com(0x01); //清零顯示
delay(20);
write_com(0x80);
delay(20);
init();
while(keyscan())
{write_date(0x30+keyscan());
while(1);
