查看: 4396|回復(fù): 0
(分享設(shè)計(jì))秒表設(shè)計(jì),按鍵控制
ID:68009 發(fā)表于 2014-11-21 16:23 | 顯示全部樓層 |閱讀模式
//簡(jiǎn)易秒表,T1定時(shí)器,方式1,9999秒定時(shí)
#include<reg51.h>
#define TH1_DATA (65536-50000)/256
#define TL1_DATA (65536-50000)%256
#define count_1s 20
int time_value=0;
#define SET_PORT P0
sbit DIS_TENS=P1^1;      //顯示數(shù)碼秒值十位的公共端
sbit DIS_UNIT=P1^0;                 //顯示數(shù)碼秒值個(gè)位的公共端
sbit DIS_HUND=P1^2;                 //顯示數(shù)碼秒值百位的公共端
sbit DIS_THOU=P1^3;             //顯示數(shù)碼秒值千位的公共端
sbit key=P3^2;                         //定義按鍵接口P3^2
bit flag_1s;             //定義1秒時(shí)間到標(biāo)志
void delay(uchar);
uchar dis_number[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};          //0~9的字形碼
void main(void)
        uchar time_thou=0,time_hund=0,time_tens=0,time_unit=0;
        TMOD=0x10;
        TH1=TH1_DATA;
        TL1=TL1_DATA;
        ET1=1;
        EA=1;
        TR1=1;                                                  //啟動(dòng)定時(shí)器
        IT0=1;                                              //外部中斷0
        EX0=1;
        EA=1;
           if(flag_1s == 1)                          //如果1s到了
            flag_1s=0;                                  //標(biāo)記重新清0
                time_value++;                          //1S次數(shù)加1
                        if(time_value >= 10000) //如果到了10000秒
                                time_value=0;          //1s的次數(shù)歸0
            time_thou=time_value / 1000;                        //計(jì)算當(dāng)前秒表計(jì)時(shí)值的千位
                time_hund=(time_value % 1000) / 100;        //計(jì)算當(dāng)前秒表計(jì)時(shí)值的百位
                time_tens=(time_value % 100) / 10;                //計(jì)算當(dāng)前秒表計(jì)時(shí)值的十位
                time_unit=time_value % 10;                                //計(jì)算當(dāng)前秒表計(jì)時(shí)值的個(gè)位
                //顯示千位數(shù)字
                SET_PORT=dis_number[time_thou];                   //送段碼
                DIS_THOU=0;        //送位碼
                delay(4);        //延時(shí)
                DIS_THOU=1;        //關(guān)閉當(dāng)前顯示位
                //顯示百位數(shù)字
        SET_PORT=dis_number[time_hund];
                DIS_HUND=0;
                delay(4);
                DIS_HUND=1;
                //顯示十位數(shù)字
                SET_PORT=dis_number[time_tens];
                DIS_TENS=0;
                delay(4);
                DIS_TENS=1;
                //顯示個(gè)位數(shù)字
                SET_PORT=dis_number[time_unit];
                DIS_UNIT=0;
                delay(4);
                DIS_UNIT=1;
void int_t3() interrupt 3 using 1
        static uchar count_50ms=0;
        TH1=TH1_DATA;
        TL1=TL1_DATA;
        count_50ms++;
        if(count_50ms >= count_1s)
                count_50ms=0;
                flag_1s=1;
void int_t1() interrupt 1 using 1                 //當(dāng)按鍵按下時(shí)
        TR1=~TR1;                                                         //定時(shí)器的狀態(tài)取反
void delay(uchar x)
        uchar i,j;
        for(i=x;i>0;i--)
                for(j=250;j>0;j--)
admin + 50 共享資料的積分獎(jiǎng)勵(lì)!
