查看: 2861|回復: 0
移動顯示C語言程序
ID:70976 發(fā)表于 2014-12-26 23:30 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
      24MHZ的晶振,點線掃描地址為:0xFFFF
#include <reg51.h>
#include <stdio.h>
#include <intrins.h>
#include <ABSACC.h>
#define  uchar  unsigned char
#define  uint  unsigned int
#define  SPEED  6
uchar col, disrow;
uint  word;
uchar code HZ[];
uchar BUFF[6];
void  loadoneline(void);  //裝載某行一線點陣數(shù)據(jù)
void  sendoneline(void);  //串行發(fā)送一行線點陣數(shù)據(jù)
/****************************主函數(shù)***************************/
void main(void)
        uchar i;
        col  = 0;
        word = 0;
        while(col <16)                          // 循環(huán)16次,點亮并移動一個漢字
        for(i=0; i <SPEED; i++)          //漢字在屏幕上的停留時間(即移動速度快慢)
        for(disrow=0;disrow <16;disrow++)//掃描16行
              loadoneline();            //裝載一線點陣數(shù)據(jù)
              sendoneline();            //發(fā)送一線點陣數(shù)據(jù)
              XBYTE[0xFFFF]= 0x10 + disrow;      // 點亮屏幕
              XBYTE[0xFFFF] = 0x20 + disrow;      //鎖住74LS595
                col++;         //列指針遞增
                col = 0;
                word= word + 32;      // 一個漢字移動后,指向下一個漢字
                if(word >= 1600)
                        word = 0;      // 移動50個漢字后,重新開始
/****************用"字模"等軟件提出要顯示的字符漢字點陣碼*************************/
uchar code HZ[]=
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
//0x08,0x20,0x06,0x30,0x04,0x40,0x3F,0xF8,0x21,0x08,0x3F,0xF8,0x21,0x08,0x21,0x08,
0x3F,0xF8,0x21,0x08,0x01,0x00,0xFF,0xFE,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,/*"
0x00,0x40,0x10,0x40,0x10,0x40,0x10,0x44,0x1F,0xFE,0x10,0x00,0x10,0x00,0x10,0x00,
0x1F,0xF0,0x10,0x10,0x10,0x10,0x10,0x10,0x20,0x10,0x20,0x10,0x40,0x10,0x80,0x10,/*"
0x10,0x00,0x10,0xF8,0x10,0x88,0xFE,0x88,0x10,0x88,0x10,0x88,0x38,0x88,0x34,0x88,
0x54,0x88,0x50,0x88,0x91,0x08,0x11,0x0A,0x12,0x0A,0x12,0x0A,0x14,0x06,0x10,0x00,/*"
0x00,0x00,0x0F,0xF0,0x08,0x10,0x0F,0xF0,0x08,0x10,0x0F,0xF0,0x08,0x10,0x0F,0xF0,
0x
相關帖子
