讓我們先來看看STARTUP.A51文件(默認(rèn)設(shè)置)吧!根據(jù)源文件中的說明文字,我們很容易分析出STARTUP.A51文件的工作方式和作用!讓我們把它先漢化一下看看! $NOMOD51 ;Ax51宏匯編器控制命令:禁止預(yù)定義的8051
; This file is part of the C51 Compiler package
; Copyright (c) 1988-2002 Keil Elektronik GmbH and Keil Software, Inc.
; STARTUP.A51: This code is executed after processor reset.
; STARTUP.A51: STARTUP.A51文件所生成的代碼將在單片機(jī)復(fù)位后被執(zhí)行!
; To translate this file use A51 with the following invocation:
; 將按照下面的命令行語句調(diào)用A51編譯器進(jìn)行編譯產(chǎn)生目標(biāo)文件
; A51 STARTUP.A51
; To link the modified STARTUP.OBJ file to your application use the following
; BL51 invocation:
; 將按照下面的命令行語句調(diào)用BL51連接器把STARTUP.OBJ定位連接到您的程序代碼中
; BL51 <your object file list>, STARTUP.OBJ <controls>
; User-defined Power-On Initialization of Memory
; 自定義上電后需要初始化的儲存區(qū)域
; With the following EQU statements the initialization of memory
; at processor reset can be defined:
; 使用下列EQU偽指令定義初始化的存儲區(qū)域 在單片機(jī)復(fù)位后定義生效
; ; the absolute start-address of IDATA memory is always 0
IDATALEN EQU 80H ; the length of IDATA memory in bytes.
; IDATA(間接尋址區(qū))其起始地址固定為0;IDATALEN用于指定需要初始化的IDATA區(qū)長度(以字節(jié)為單位)* XDATASTART EQU 0H ; the absolute start-address of XDATA memory
XDATALEN EQU 0H ; the length of XDATA memory in bytes.
;XDATA (外部直接尋址區(qū)) XDATASTART用于指定需要初始化的XDATA區(qū)起始地址
;XDATALEN 用于指定需要初始化的XDATA區(qū)長度(以字節(jié)為單位)*
PDATASTART EQU 0H ; the absolute start-address of PDATA memory
PDATALEN EQU 0H ; the length of PDATA memory in bytes.
;PDATA(頁尋址區(qū)) PDATASTART用于指定需要初始化的PDATA區(qū)起始地址
;PDATALEN用于指定需要初始化的;PDATA區(qū)長度(以字節(jié)為單位)*
; Notes: The IDATA space overlaps physically the DATA and BIT areas of the
; 8051 CPU. At minimum the memory space occupied from the C51
; run-time routines must be set to zero. ;注釋:8051中 IDATA 區(qū)物理上已經(jīng)包括了DATA區(qū)(直接尋址區(qū))以及 BIT區(qū) (位尋址
區(qū))。C51(庫)占用了 最小化內(nèi)存空間,運(yùn)行時程序需要把它設(shè)為0 ;------------------------------------------------------------------------------
; Reentrant Stack Initilization
; 重入堆棧初始化
; The following EQU statements define the stack pointer for reentrant
; functions and initialized it:
; 下面的EQU語句定義重入函數(shù)的堆棧指針并初始化它
; Stack Space for reentrant functions in the SMALL model.
; SMALL模式下的重入函數(shù)的堆�?臻g
IBPSTACK EQU 0 ; set to 1 if small reentrant is used.
;如果再SMALL模式下使用重入則設(shè)為1
IBPSTACKTOP EQU 0FFH+1 ; set top of stack to highest location+1.
;設(shè)置堆棧頂 最高位置+1
; Stack Space for reentrant functions in the LARGE model.
; LARGE模式下的重入函數(shù)的堆�?臻g
XBPSTACK EQU 0 ; set to 1 if large reentrant is used.
;如果再LARGE模式下使用重入則設(shè)為1
XBPSTACKTOP EQU 0FFFFH+1; set top of stack to highest location+1.
;設(shè)置堆棧頂 最高位置+1
; Stack Space for reentrant functions in the COMPACT model.
; COMPACT模式下的重入函數(shù)的堆�?臻g
PBPSTACK EQU 0 ; set to 1 if compact reentrant is used.
;如果再COMPACT模式下使用重入則設(shè)為1
PBPSTACKTOP EQU 0FFFFH+1; set top of stack to highest location+1.
;設(shè)置堆棧頂 最高位置+1
; Page Definition for Using the Compact Model with 64 KByte xdata RAM
; 使用COMPACT模式時為64KB的XDATA RAM定義頁
; The following EQU statements define the xdata page used for pdata
; variables. The EQU PPAGE must conform with the PPAGE control used
; in the linker invocation.
; 下面的EQU語句定義PDATA變量的使用了XDATA頁
PPAGEENABLE EQU 0 ; set to 1 if pdata object are used.
;如果使用PDATA頁則設(shè)為1
PPAGE EQU 0 ; define PPAGE number.
;定義頁號
PPAGE_SFR DATA 0A0H ; SFR that supplies uppermost address byte
;SFR的最高地址字節(jié)
; (most 8051 variants use P2 as uppermost address byte)
; (大多數(shù)8051變量要用P2的最高地址字節(jié))
;------------------------------------------------------------------------------ ; Standard SFR Symbols
; 標(biāo)準(zhǔn)SFR符號
ACC DATA 0E0H
B DATA 0F0H
SP DATA 81H
DPL DATA 82H
DPH DATA 83H NAME ?C_STARTUP
?C_C51STARTUP SEGMENT CODE
?STACK SEGMENT IDATA
RSEG ?STACK
DS 1 EXTRN CODE (?C_START)
;外部代碼(這個標(biāo)號將代表用戶程序的啟始地址)
PUBLIC ?C_STARTUP
;給外部使用的符號 CSEG AT 0
;在code段的0地址處放以下代碼(使用AT指令進(jìn)行絕對地址的定位)
?C_STARTUP: LJMP STARTUP1 RSEG ?C_C51STARTUP STARTUP1: IF IDATALEN <> 0
;如果長度大于1則初始化IDATA
MOV R0,#IDATALEN - 1
CLR A
IDATALOOP: MOV @R0,A
DJNZ R0,IDATALOOP
ENDIF IF XDATALEN <> 0
;如果長度大于1則初始化XDATA
MOV DPTR,#XDATASTART
MOV R7,#LOW (XDATALEN)
IF (LOW (XDATALEN)) <> 0
;預(yù)置初始化時的外循環(huán)次數(shù)到R6
MOV R6,#(HIGH (XDATALEN)) +1
ELSE
MOV R6,#HIGH (XDATALEN)
ENDIF
CLR A
XDATALOOP: MOVX @DPTR,A
INC DPTR
DJNZ R7,XDATALOOP
DJNZ R6,XDATALOOP
ENDIF
IF PPAGEENABLE <> 0
MOV PPAGE_SFR,#PPAGE
ENDIF IF PDATALEN <> 0
;如果長度大于1則初始化PDATA
MOV R0,#LOW (PDATASTART)
MOV R7,#LOW (PDATALEN)
CLR A
PDATALOOP: MOVX @R0,A
INC R0
DJNZ R7,PDATALOOP
ENDIF IF IBPSTACK <> 0
;SMALL模式下使用重入函數(shù)時要設(shè)置的堆棧
EXTRN DATA (?C_IBP) MOV ?C_IBP,#LOW IBPSTACKTOP
ENDIF IF XBPSTACK <> 0
;COMPACT模式下使用重入函數(shù)時要設(shè)置的堆棧
EXTRN DATA (?C_XBP) MOV ?C_XBP,#HIGH XBPSTACKTOP
MOV ?C_XBP+1,#LOW XBPSTACKTOP
ENDIF IF PBPSTACK <> 0
;LARGE模式下使用重入函數(shù)時要設(shè)置的堆棧
EXTRN DATA (?C_PBP)
MOV ?C_PBP,#LOW PBPSTACKTOP
ENDIF MOV SP,#?STACK-1
; This code is required if you use L51_BANK.A51 with Banking Mode 4
; 如果你的程序使用了Mode 4 程序分組技術(shù)(BANKING)請啟用下面的程序代碼
; EXTRN CODE (?B_SWITCH0)
; CALL ?B_SWITCH0 ; init bank mechanism to code bank 0
;程序從第一個塊(bank0)開始執(zhí)行
LJMP ?C_START ;從這里跳到你的程序入口 END
