查看: 4275|回復: 0
stm32常用圖表
ID:72519 發(fā)表于 2015-1-23 01:25 | 顯示全部樓層 |閱讀模式
STM32的時鐘樹:
STM32的結構:
STM32的RCC時鐘控制位:
STM32的中斷和異常向量表:
typedef enum IRQn
/******  Cortex-M3 Processor Exceptions Numbers ***************************************************/
  NonMaskableInt_IRQn         = -14,    /*!< 2 Non Maskable Interrupt                             */
  MemoryManagement_IRQn       = -12,    /*!< 4 Cortex-M3 Memory Management Interrupt              */
  BusFault_IRQn               = -11,    /*!< 5 Cortex-M3 Bus Fault Interrupt                      */
  UsageFault_IRQn             = -10,    /*!< 6 Cortex-M3 Usage Fault Interrupt                    */
  SVCall_IRQn                 = -5,     /*!< 11 Cortex-M3 SV Call Interrupt                       */
  DebugMonitor_IRQn           = -4,     /*!< 12 Cortex-M3 Debug Monitor Interrupt                 */
  PendSV_IRQn                 = -2,     /*!< 14 Cortex-M3 Pend SV Interrupt                       */
  SysTick_IRQn                = -1,     /*!< 15 Cortex-M3 System Tick Interrupt                   */
/******  STM32 specific Interrupt Numbers *********************************************************/
  WWDG_IRQn                   = 0,      /*!< Window WatchDog Interrupt                            */
  PVD_IRQn                    = 1,      /*!< PVD through EXTI Line detection Interrupt            */
  TAMPER_IRQn                 = 2,      /*!< Tamper Interrupt                                     */
  RTC_IRQn                    = 3,      /*!< RTC global Interrupt                                 */
  FLASH_IRQn                  = 4,      /*!< FLASH global Interrupt                               */
  RCC_IRQn                    = 5,      /*!< RCC global Interrupt                                 */
  EXTI0_IRQn                  = 6,      /*!< EXTI Line0 Interrupt                                 */
  EXTI1_IRQn                  = 7,      /*!< EXTI Line1 Interrupt                                 */
  EXTI2_IRQn                  = 8,      /*!< EXTI Line2 Interrupt                                 */
  EXTI3_IRQn                  = 9,      /*!< EXTI Line3 Interrupt                                 */
  EXTI4_IRQn                  = 10,     /*!< EXTI Line4 Interrupt                                 */
  DMA1_Channel1_IRQn          = 11,     /*!< DMA1 Channel 1 global Interrupt                      */
  DMA1_Channel2_IRQn          = 12,     /*!< DMA1 Channel 2 global Interrupt                      */
  DMA1_Channel3_IRQn          = 13,     /*!< DMA1 Channel 3 global Interrupt                      */
  DMA1_Channel4_IRQn          = 14,     /*!< DMA1 Channel 4 global Interrupt                      */
  DMA1_Channel5_IRQn          = 15,     /*!< DMA1 Channel 5 global Interrupt                      */
  DMA1_Channel6_IRQn          = 16,     /*!< DMA1 Channel 6 global Interrupt                      */
  DMA1_Channel7_IRQn          = 17,     /*!< DMA1 Channel 7 global Interrupt                      */
#ifdef STM32F10X_CL
  ADC1_2_IRQn                 = 18,     /*!< ADC1 and ADC2 global Interrupt                       */
  CAN1_TX_IRQn                = 19,     /*!< USB Device High Priority or CAN1 TX Interrupts       */
  CAN1_RX0_IRQn               = 20,     /*!< USB Device Low Priority or CAN1 RX0 Interrupts       */
  CAN1_RX1_IRQn               = 21,     /*!< CAN1 RX1 Interrupt                                   */
  CAN1_SCE_IRQn               = 22,     /*!< CAN1 SCE Interrupt                                   */
  EXTI9_5_IRQn                = 23,     /*!< External Line[9:5] Interrupts                        */
  TIM1_BRK_IRQn               = 24,     /*!< TIM1 Break Interrupt                                 */
  TIM1_UP_IRQn                = 25,     /*!< TIM1 Update Interrupt                                */
  TIM1_TRG_COM_IRQn           = 26,     /*!< TIM1 Trigger and Commutation Interrupt               */
  TIM1_CC_IRQn                = 27,     /*!< TIM1 Capture Compare Interrupt                       */
  TIM2_IRQn                   = 28,     /*!< TIM2 global Interrupt                                */
  TIM3_IRQn                   = 29,     /*!< TIM3 global Interrupt                                */
  TIM4_IRQn                   = 30,     /*!< TIM4 global Interrupt                                */
  I2C1_EV_IRQn                = 31,     /*!< I2C1 Event Interrupt                                 */
  I2C1_ER_IRQn                = 32,     /*!< I2C1 Error Interrupt                                 */
  I2C2_EV_IRQn                = 33,     /*!< I2C2 Event Interrupt                                 */
  I2C2_ER_IRQn                = 34,     /*!< I2C2 Error Interrupt                                 */
  SPI1_IRQn                   = 35,     /*!< SPI1 global Interrupt                                */
  SPI2_IRQn                   = 36,     /*!< SPI2 global Interrupt                                */
  USART1_IRQn                 = 37,     /*!< USART1 global Interrupt                              */
  USART2_IRQn                 = 38,     /*!< USART2 global Interrupt                              */
  USART3_IRQn                 = 39,     /*!< USART3 global Interrupt                              */
  EXTI15_10_IRQn              = 40,     /*!< External Line[15:10] Interrupts                      */
  RTCAlarm_IRQn               = 41,     /*!< RTC Alarm through EXTI Line Interrupt                */
  OTG_FS_WKUP_IRQn            = 42,     /*!< USB OTG FS WakeUp from suspend through EXTI Line Interrupt */
  TIM5_IRQn                   = 50,     /*!< TIM5 global Interrupt                                */
  SPI3_IRQn                   = 51,     /*!< SPI3 global Interrupt                                */
  UART4_IRQn                  = 52,     /*!< UART4 global Interrupt                               */
  UART5_IRQn                  = 53,     /*!< UART5 global Interrupt                               */
  TIM6_IRQn                   = 54,     /*!< TIM6 global Interrupt                                */
  TIM7_IRQn                   = 55,     /*!< TIM7 global Interrupt                                */
  DMA2_Channel1_IRQn          = 56,     /*!< DMA2 Channel 1 global Interrupt                      */
  DMA2_Channel2_IRQn          = 57,     /*!< DMA2 Channel 2 global Interrupt                      */
  DMA2_Channel3_IRQn          = 58,     /*!< DMA2 Channel 3 global Interrupt                      */
  DMA2_Channel4_IRQn          = 59,     /*!< DMA2 Channel 4 global Interrupt                      */
  DMA2_Channel5_IRQn          = 60,     /*!< DMA2 Channel 5 global Interrupt                      */
  ETH_IRQn                    = 61,     /*!< Ethernet global Interrupt                            */
  ETH_WKUP_IRQn               = 62,     /*!< Ethernet Wakeup through EXTI line Interrupt          */
  CAN2_TX_IRQn                = 63,     /*!< CAN2 TX Interrupt                                    */
  CAN2_RX0_IRQn               = 64,     /*!< CAN2 RX0 Interrupt                                   */
  CAN2_RX1_IRQn               = 65,     /*!< CAN2 RX1 Interrupt                                   */
  CAN2_SCE_IRQn               = 66,     /*!< CAN2 SCE Interrupt                                   */
  OTG_FS_IRQn                 = 67      /*!< USB OTG FS global Interrupt                          */
#endif /* STM32F10X_CL */
} IRQn_Type;
GPIO時鐘使能和JTAG引腳禁能:
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOC
                              |RCC_APB2Periph_GPIOD|RCC_APB2Periph_GPIOE|RCC_APB2Periph_AFIO, ENABLE);
  GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE); //禁能JTAG,主要影響SPI3、I2S3和PB3、PB4、PA15的重映射功能。
