- * @file GPIO/IOToggle/system_stm32f10x.c
- * @author MCD Application Team
- * @version V3.4.0
- * @date 10/15/2010
- * @brief CMSIS Cortex-M3 Device Peripheral Access Layer System Source File.
- * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
- * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
- * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
- * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
- * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
- * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
- * <h2><center>© COPYRIGHT 2010 STMicroelectronics</center></h2>
- /** @addtogroup CMSIS
- /** @addtogroup stm32f10x_system
- /** @addtogroup STM32F10x_System_Private_Includes
- #include "stm32f10x.h"
- /** @addtogroup STM32F10x_System_Private_TypesDefinitions
- /** @addtogroup STM32F10x_System_Private_Defines
- /*!< Uncomment the line corresponding to the desired System clock (SYSCLK)
- frequency (after reset the HSI is used as SYSCLK source)
- IMPORTANT NOTE:
- 1. After each device reset the HSI is used as System clock source.
- 2. Please make sure that the selected System clock doesn't exceed your device's
- maximum frequency.
- 3. If none of the define below is enabled, the HSI is used as System clock
- source.
- 4. The System clock configuration functions provided within this file assume that:
- - For Low, Medium and High density Value line devices an external 8MHz
- crystal is used to drive the System clock.
- - For Low, Medium and High density devices an external 8MHz crystal is
- used to drive the System clock.
- - For Connectivity line devices an external 25MHz crystal is used to drive
- the System clock.
- If you are using different crystal you have to adapt those functions accordingly.
- #if defined (STM32F10X_LD_VL) || (defined STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)//如果定義了這些系統(tǒng)時鐘將設(shè)為24M,如果沒有定義則為72M
- /* #define SYSCLK_FREQ_HSE HSE_VALUE */
- #define SYSCLK_FREQ_24MHz 24000000
- #else
- /* #define SYSCLK_FREQ_24MHz 24000000 */
- /* #define SYSCLK_FREQ_36MHz 36000000 */
- /* #define SYSCLK_FREQ_48MHz 48000000 */
- /* #define SYSCLK_FREQ_56MHz 56000000 */
- #define SYSCLK_FREQ_72MHz 72000000 //系統(tǒng)時鐘默認值的定義 ,如果沒有定義外部高速時鐘則用內(nèi)部高速時鐘,為8000000
- #endif
- /*!< Uncomment the following line if you need to use external SRAM mounted
- on STM3210E-EVAL board (STM32 High density and XL-density devices) or on
- STM32100E-EVAL board (STM32 High-density value line devices) as data memory */
- #if defined (STM32F10X_HD) || (defined STM32F10X_XL) || (defined STM32F10X_HD_VL)//內(nèi)外部SRAM選擇
- /* #define DATA_IN_ExtSRAM */
- #endif
- /*!< Uncomment the following line if you need to relocate your vector Table in
- Internal SRAM. */
- /* #define VECT_TAB_SRAM */
- #define VECT_TAB_OFFSET 0x0 /*!< Vector Table base offset field. //向量表的基址偏移量
- This value must be a multiple of 0x100. */
- /** @addtogroup STM32F10x_System_Private_Macros
- /** @addtogroup STM32F10x_System_Private_Variables
- * Clock Definitions;以下為把系統(tǒng)時鐘的定義值傳給系統(tǒng)內(nèi)核時鐘變量,如果沒有定義外部高速時鐘則用內(nèi)部高速時鐘,為8M
- #ifdef SYSCLK_FREQ_HSE
- uint32_t SystemCoreClock = SYSCLK_FREQ_HSE; /*!< System Clock Frequency (Core Clock) */
- #elif defined SYSCLK_FREQ_24MHz
- uint32_t SystemCoreClock = SYSCLK_FREQ_24MHz; /*!< System Clock Frequency (Core Clock) */
- #elif defined SYSCLK_FREQ_36MHz
- uint32_t SystemCoreClock = SYSCLK_FREQ_36MHz; /*!< System Clock Frequency (Core Clock) */
- #elif defined SYSCLK_FREQ_48MHz
- uint32_t SystemCoreClock = SYSCLK_FREQ_48MHz; /*!< System Clock Frequency (Core Clock) */
- #elif defined SYSCLK_FREQ_56MHz
- uint32_t SystemCoreClock = SYSCLK_FREQ_56MHz; /*!< System Clock Frequency (Core Clock) */
- #elif defined SYSCLK_FREQ_72MHz
- uint32_t SystemCoreClock = SYSCLK_FREQ_72MHz; /*!< System Clock Frequency (Core Clock) */
- #else /*!< HSI Selected as System Clock source */
- uint32_t SystemCoreClock = HSI_VALUE; /*!< System Clock Frequency (Core Clock) 如果沒有定義外部高速時鐘則用內(nèi)部高速時鐘,為8000000*/
- #endif
- __I uint8_t AHBPrescTable[16] = {0, 0, 0, 0, 0, 0, 0, 0, 1, 2, 3, 4, 6, 7, 8, 9};//AHB配方表
- /** @addtogroup STM32F10x_System_Private_FunctionPrototypes
- 以下為函數(shù)聲明
- static void SetSysClock(void); //設(shè)置系統(tǒng)時鐘的函數(shù)聲明
- //以下為根據(jù)不同的系統(tǒng)時鐘的定義來聲明用到的相應(yīng)的函數(shù),為后面的函數(shù)調(diào)用做好準備
- static void SetSysClockToHSE(void);
- static void SetSysClockTo24(void);
- static void SetSysClockTo36(void);
- static void SetSysClockTo48(void);
- static void SetSysClockTo56(void);
- static void SetSysClockTo72(void);
- #endif
- #ifdef DATA_IN_ExtSRAM //外部SRAM選擇后的初始化函數(shù)聲明
- static void SystemInit_ExtMemCtl(void);
- #endif /* DATA_IN_ExtSRAM */
- /** @addtogroup STM32F10x_System_Private_Functions
- * @brief Setup the microcontroller system
- * Initialize the Embedded Flash Interface, the PLL and update the
- * SystemCoreClock variable.
- * @note This function should be used only after reset.
- * @param None
- * @retval None
- void SystemInit (void)//系統(tǒng)初始化函數(shù),設(shè)置系統(tǒng)的時鐘及時鐘中斷(在startup_stm32f10x_md.s中調(diào)用)(復(fù)位RCC時鐘配置為默認狀態(tài),直到設(shè)置時鐘函數(shù))
- /* Reset the RCC clock configuration to the default reset state(for debug purpose) */
- /* Set HSION bit */
- RCC->CR |= (uint32_t)0x00000001; //內(nèi)部高速時鐘使能,內(nèi)部8MHz時鐘開啟
- /* Reset SW, HPRE, PPRE1, PPRE2, ADCPRE and MCO bits */
- #ifndef STM32F10X_CL
- RCC->CFGR &= (uint32_t)0xF8FF0000;//MCO微控制器沒有時鐘輸出(對外部引腳),ADC預(yù)分頻PCLK2 2分頻后作為ADC時鐘,APB預(yù)分頻HCLK不分頻,AHB預(yù)分頻SYSCLK不分頻,HSI作為系統(tǒng)時鐘
- //HSI作為系統(tǒng)時鐘輸出(已輸出),SYSCLK=PCLK=PCLK1=PCLK2=8M,ADCCLK=1/2(PCLK2)=4M
- #else
- RCC->CFGR &= (uint32_t)0xF0FF0000;//同上;RCC->CFGR的27位為保留位始終為0 ,HSI作為系統(tǒng)時鐘輸出(未輸出原因為未編譯)
- #endif /* STM32F10X_CL */
- /* Reset HSEON, CSSON and PLLON bits */
- RCC->CR &= (uint32_t)0xFEF6FFFF;//時鐘監(jiān)測器關(guān)閉,HSE振蕩器關(guān)閉
- /* Reset HSEBYP bit */
- RCC->CR &= (uint32_t)0xFFFBFFFF;//外部4-25MHz振蕩器沒有旁路
- /* Reset PLLSRC, PLLXTPRE, PLLMUL and USBPRE/OTGFSPRE bits */
- RCC->CFGR &= (uint32_t)0xFF80FFFF; //PLL時鐘1.5倍分頻作為USB時鐘,PLL 2倍頻輸出,HSE不分頻,HSI時鐘2分頻后作為PLL輸入時鐘
- //PLLCLK=HSICLK=8M(還未輸出),HSECLK=HSEOSC,USBCLK=PLLCLK/1.5 ,除PLL外其他分頻系數(shù)都為0
- #ifdef STM32F10X_CL
- /* Reset PLL2ON and PLL3ON bits */
- RCC->CR &= (uint32_t)0xEBFFFFFF;//CR中的26和28位置0
- /* Disable all interrupts and clear pending bits */
- RCC->CIR = 0x00FF0000;//清除中斷標志,關(guān)閉一些中斷
- /* Reset CFGR2 register */
- RCC->CFGR2 = 0x00000000; //沒有此寄存器
- #elif defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)
- RCC->CIR = 0x009F0000;//清除中斷標志,關(guān)閉一些中斷
- #else
- RCC->CIR = 0x009F0000; //清除中斷標志,關(guān)閉一些中斷
- SystemInit_ExtMemCtl();//如果宏定義了外部SRAM則對其初始化控制
- #endif
- /* Configure the System clock frequency, HCLK, PCLK2 and PCLK1 prescalers */
- /* Configure the Flash Latency cycles and enable prefetch buffer */
- SetSysClock();//設(shè)置系統(tǒng)時鐘
- #ifdef VECT_TAB_SRAM
- SCB->VTOR = SRAM_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal SRAM. 向量表放在內(nèi)部SRAM中*/
- #else
- SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH. 向量表放在內(nèi)部flash中*/
- #endif
- * @brief Update SystemCoreClock according to Clock Register Values
- * @note None
- * @param None
- * @retval None
- void SystemCoreClockUpdate (void)
- uint32_t tmp = 0, pllmull = 0, pllsource = 0;
- uint32_t prediv1source = 0, prediv1factor = 0, prediv2factor = 0, pll2mull = 0;
- #if defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)
- uint32_t prediv1factor = 0;
- #endif /* STM32F10X_LD_VL or STM32F10X_MD_VL or STM32F10X_HD_VL */
- /* Get SYSCLK source -------------------------------------------------------*/
- tmp = RCC->CFGR & RCC_CFGR_SWS;
- switch (tmp)
- case 0x00: /* HSI used as system clock */
- SystemCoreClock = HSI_VALUE;
- break;
- case 0x04: /* HSE used as system clock */
- SystemCoreClock = HSE_VALUE;
- break;
- case 0x08: /* PLL used as system clock */
- /* Get PLL clock source and multiplication factor ----------------------*/
- pllmull = RCC->CFGR & RCC_CFGR_PLLMULL;
- pllsource = RCC->CFGR & RCC_CFGR_PLLSRC;
- pllmull = ( pllmull >> 18) + 2;
- if (pllsource == 0x00)
- /* HSI oscillator clock divided by 2 selected as PLL clock entry */
- SystemCoreClock = (HSI_VALUE >> 1) * pllmull;
- else
- prediv1factor = (RCC->CFGR2 & RCC_CFGR2_PREDIV1) + 1;
- /* HSE oscillator clock selected as PREDIV1 clock entry */
- SystemCoreClock = (HSE_VALUE / prediv1factor) * pllmull;
- #else
- /* HSE selected as PLL clock entry */
- if ((RCC->CFGR & RCC_CFGR_PLLXTPRE) != (uint32_t)RESET)
- {/* HSE oscillator clock divided by 2 */
- SystemCoreClock = (HSE_VALUE >> 1) * pllmull;
- else
- SystemCoreClock = HSE_VALUE * pllmull;
- #endif
- #else
- pllmull = pllmull >> 18;
- if (pllmull != 0x0D)
- pllmull += 2;
- else
- { /* PLL multiplication factor = PLL input clock * 6.5 */
- pllmull = 13 / 2;
- else
- {/* PREDIV1 selected as PLL clock entry */
- /* Get PREDIV1 clock source and division factor */
- prediv1source = RCC->CFGR2 & RCC_CFGR2_PREDIV1SRC;
- if (prediv1source == 0)
- else
- {/* PLL2 clock selected as PREDIV1 clock entry */
- /* Get PREDIV2 division factor and PLL2 multiplication factor */
- prediv2factor = ((RCC->CFGR2 & RCC_CFGR2_PREDIV2) >> 4) + 1;
- pll2mull = ((RCC->CFGR2 & RCC_CFGR2_PLL2MUL) >> 8 ) + 2;
- SystemCoreClock = (((HSE_VALUE / prediv2factor) * pll2mull) / prediv1factor) * pllmull;
- break;
- default:
- break;
- /* Compute HCLK clock frequency ----------------*/
- /* Get HCLK prescaler */
- tmp = AHBPrescTable[((RCC->CFGR & RCC_CFGR_HPRE) >> 4)];
- /* HCLK clock frequency */
- SystemCoreClock >>= tmp;
- * @brief Configures the System clock frequency, HCLK, PCLK2 and PCLK1 prescalers.
- * @param None
- * @retval None
- static void SetSysClock(void)//根據(jù)不同的宏定義,設(shè)置不同的系統(tǒng)時鐘
- SetSysClockToHSE();
- SetSysClockTo24();
- SetSysClockTo36();
- SetSysClockTo48();
- SetSysClockTo56();
- SetSysClockTo72();
- #endif
- /* If none of the define above is enabled, the HSI is used as System clock
- source (default after reset) */
- * @brief Setup the external memory controller. Called in startup_stm32f10x.s
- * before jump to __main
- * @param None
- * @retval None
- * Called in startup_stm32f10x_xx.s/.c before jump to main.
- * This function configures the external SRAM mounted on STM3210E-EVAL
- * board (STM32 High density devices). This SRAM will be used as program
- * data memory (including heap and stack).
- * @param None
- * @retval None
- void SystemInit_ExtMemCtl(void)
- /*!< FSMC Bank1 NOR/SRAM3 is used for the STM3210E-EVAL, if another Bank is
- required, then adjust the Register Addresses */
- /* Enable FSMC clock */
- RCC->AHBENR = 0x00000114;
- /* Enable GPIOD, GPIOE, GPIOF and GPIOG clocks */
- RCC->APB2ENR = 0x000001E0;
- /* --------------- SRAM Data lines, NOE and NWE configuration ---------------*/
- /*---------------- SRAM Address lines configuration -------------------------*/
- /*---------------- NOE and NWE configuration --------------------------------*/
- /*---------------- NE3 configuration ----------------------------------------*/
- /*---------------- NBL0, NBL1 configuration ---------------------------------*/
- GPIOD->CRL = 0x44BB44BB;
- GPIOD->CRH = 0xBBBBBBBB;
- GPIOE->CRL = 0xB44444BB;
- GPIOE->CRH = 0xBBBBBBBB;
- GPIOF->CRL = 0x44BBBBBB;
- GPIOF->CRH = 0xBBBB4444;
- GPIOG->CRL = 0x44BBBBBB;
- GPIOG->CRH = 0x44444B44;
- /*---------------- FSMC Configuration ---------------------------------------*/
- /*---------------- Enable FSMC Bank1_SRAM Bank ------------------------------*/
- FSMC_Bank1->BTCR[4] = 0x00001011;
- FSMC_Bank1->BTCR[5] = 0x00000200;
- * @brief Selects HSE as System clock source and configure HCLK, PCLK2
- * and PCLK1 prescalers.
- * @param None
- * @retval None
- __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
- /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration ---------------------------*/
- /* Enable HSE */
- RCC->CR |= ((uint32_t)RCC_CR_HSEON);
- /* Wait till HSE is ready and if Time out is reached exit */
- do
- HSEStatus = RCC->CR & RCC_CR_HSERDY;
- StartUpCounter++;
- } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
- if ((RCC->CR & RCC_CR_HSERDY) != RESET)
- HSEStatus = (uint32_t)0x01;
- else
- HSEStatus = (uint32_t)0x00;
- if (HSEStatus == (uint32_t)0x01)
- #if !defined STM32F10X_LD_VL && !defined STM32F10X_MD_VL && !defined STM32F10X_HD_VL
- /* Enable Prefetch Buffer */
- FLASH->ACR |= FLASH_ACR_PRFTBE;
- /* Flash 0 wait state */
- FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
- FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_0;
- #else
- if (HSE_VALUE <= 24000000)
- else
- FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_1;
- #endif
- /* HCLK = SYSCLK */
- RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
- /* PCLK2 = HCLK */
- RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
- /* PCLK1 = HCLK */
- RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV1;
- /* Select HSE as system clock source */
- RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
- RCC->CFGR |= (uint32_t)RCC_CFGR_SW_HSE;
- /* Wait till HSE is used as system clock source */
- while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x04)
- else
- { /* If HSE fails to start-up, the application will have wrong clock
- configuration. User can add here some code to deal with this error */
- * @brief Sets System clock frequency to 24MHz and configure HCLK, PCLK2
- * @param None
- * @retval None
- static void SetSysClockTo24(void)//系統(tǒng)時鐘設(shè)置為24M:SYSCLK=24M,HCLK=24M,PCLK1=24M(最高36M),PCLK2=24M,ADCCLK=12M,
- /* Enable HSE */
- do
- StartUpCounter++;
- else
- #endif
- /* Configure PLLs ------------------------------------------------------*/
- /* PLL configuration: PLLCLK = PREDIV1 * 6 = 24 MHz */
- RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);
- RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 |
- RCC_CFGR_PLLMULL6);
- /* PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz */
- /* PREDIV1 configuration: PREDIV1CLK = PLL2 / 10 = 4 MHz */
- RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |
- RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
- RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |
- RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV10);
- /* Enable PLL2 */
- RCC->CR |= RCC_CR_PLL2ON;
- /* Wait till PLL2 is ready */
- while((RCC->CR & RCC_CR_PLL2RDY) == 0)
- #elif defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || defined (STM32F10X_HD_VL)
- /* PLL configuration: = (HSE / 2) * 6 = 24 MHz */
- RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
- RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLXTPRE_PREDIV1_Div2 | RCC_CFGR_PLLMULL6);
- #else
- RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLXTPRE_HSE_Div2 | RCC_CFGR_PLLMULL6);
- /* Enable PLL */
- RCC->CR |= RCC_CR_PLLON;
- /* Wait till PLL is ready */
- while((RCC->CR & RCC_CR_PLLRDY) == 0)
- /* Select PLL as system clock source */
- RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
- /* Wait till PLL is used as system clock source */
- while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
- else
- * @brief Sets System clock frequency to 36MHz and configure HCLK, PCLK2
- * @param None
- * @retval None
- static void SetSysClockTo36(void)//系統(tǒng)時鐘設(shè)置為36M:SYSCLK=36M,HCLK=36M,PCLK1=36M(最高36M),PCLK2=36M,ADCCLK=18M,
- /* Enable HSE */
- do
- StartUpCounter++;
- else
- /* Flash 1 wait state */
- /* PLL configuration: PLLCLK = PREDIV1 * 9 = 36 MHz */
- RCC_CFGR_PLLMULL9);
- /*!< PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz */
- /* Enable PLL2 */
- #else
- /* PLL configuration: PLLCLK = (HSE / 2) * 9 = 36 MHz */
- RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLXTPRE_HSE_Div2 | RCC_CFGR_PLLMULL9);
- /* Enable PLL */
- else
- * @brief Sets System clock frequency to 48MHz and configure HCLK, PCLK2
- * @param None
- * @retval None
- static void SetSysClockTo48(void)//系統(tǒng)時鐘設(shè)置為48M:SYSCLK=48M,HCLK=48M,PCLK1=24M(最高36M),PCLK2=48M,ADCCLK=24M,
- /* Enable HSE */
- do
- StartUpCounter++;
- else
- /* PCLK1 = HCLK/2 */
- RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;
- /* PREDIV1 configuration: PREDIV1CLK = PLL2 / 5 = 8 MHz */
- RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5);
- /* Enable PLL2 */
- /* PLL configuration: PLLCLK = PREDIV1 * 6 = 48 MHz */
- #else
- /* PLL configuration: PLLCLK = HSE * 6 = 48 MHz */
- RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL6);
- /* Enable PLL */
- else
- * @brief Sets System clock frequency to 56MHz and configure HCLK, PCLK2
- * @param None
- * @retval None
- static void SetSysClockTo56(void)//系統(tǒng)時鐘設(shè)置為56M:SYSCLK=56M,HCLK=56M,PCLK1=28M(最高36M),PCLK2=56M,ADCCLK=28M,
- /* Enable HSE */
- do
- StartUpCounter++;
- else
- /* Flash 2 wait state */
- FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_2;
- /* Enable PLL2 */
- /* PLL configuration: PLLCLK = PREDIV1 * 7 = 56 MHz */
- RCC_CFGR_PLLMULL7);
- #else
- /* PLL configuration: PLLCLK = HSE * 7 = 56 MHz */
- RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL7);
- /* Enable PLL */
- else
- * @brief Sets System clock frequency to 72MHz and configure HCLK, PCLK2
- * @param None
- * @retval None
- static void SetSysClockTo72(void)//系統(tǒng)時鐘設(shè)置為72M:SYSCLK=72M,HCLK=72M,PCLK1=36M(最高36M),PCLK2=72M,ADCCLK=36M,
- __IO uint32_t StartUpCounter = 0, HSEStatus = 0;//啟動計數(shù),HSE狀態(tài)
- /* Enable HSE */
- RCC->CR |= ((uint32_t)RCC_CR_HSEON);//HSE使能
- do //循環(huán),直到HSE使能成功或者超時
- StartUpCounter++;
- HSEStatus = (uint32_t)0x01;//HSE使能成功
- else
- HSEStatus = (uint32_t)0x00;//HSE使能不成功
- if (HSEStatus == (uint32_t)0x01)//HSE使能成功
- FLASH->ACR |= FLASH_ACR_PRFTBE;//flash緩存使能
- FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);//
- FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_2;//
- RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;//RCC_CFGR_HPRE_DIV1=0,CFGR中的值不變
- RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;//RCC_CFGR_PPRE2_DIV1=0,CFGR中的值不變
- RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;//低速APB預(yù)分頻把HCLK 2分頻,APB1CLK=HCLK/2
- /* Enable PLL2 */
- /* PLL configuration: PLLCLK = PREDIV1 * 9 = 72 MHz */
- #else
- /* PLL configuration: PLLCLK = HSE * 9 = 72 MHz */
- RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | //PLL輸入時鐘源HSI時鐘2分頻后作為PLL輸入時鐘,HSE分頻器作為PLL輸入HSE不分頻
- RCC_CFGR_PLLMULL)); //PLL倍頻系數(shù)PLL 2倍頻輸出(為了清零其他位)
- RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL9);//PLL輸入時鐘源HSE時鐘作為PLL輸入時鐘,PLL倍頻系數(shù)PLL 9倍頻輸出
- /* Enable PLL */
- RCC->CR |= RCC_CR_PLLON; //PLL使能
- while((RCC->CR & RCC_CR_PLLRDY) == 0)//等待PLL使能成功
- RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));//HSI作為系統(tǒng)時鐘(為了清零其他位)
- RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL; //PLL輸出作為系統(tǒng)時鐘
- while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)//等待直到PLL成功用作系統(tǒng)時鐘源
- else
- #endif
- /******************* (C) COPYRIGHT 2010 STMicroelectronics *****END OF FILE****/
