.INCLUDE hardware.inc
.IRAM
_Led_Out:
.dw 0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000
_List_8421_Data: //16進(jìn)位數(shù)轉(zhuǎn)換成8421碼的位權(quán)表,萬(wàn)位每千位進(jìn)位,千位每百位進(jìn)位,百位每十位進(jìn)位
.dw 0xFFFF,0xEA60,0xC350,0x9C40,0x7530,0x4E20,0x2710
//60000-10000
.dw 0x2328,0x1F40,0x1B58,0x1770,0x1388,0x0FA0,0x0BB8,0x07D0,0x03E8
//9000-1000
.dw 0x0384,0x0320,0x02BC,0x0258,0x01F4,0x0190,0x012C,0x00C8,0x0064
//900-100
.dw 0x005A,0x0050,0x0046,0x003C,0x0032,0x0028,0x001E,0x0014,0x000A
//90-10
//.RAM
//.DATA
.code
//函數(shù): hex_to_8421()
//語(yǔ)法:hex_to_8421(被轉(zhuǎn)換數(shù),符號(hào)標(biāo)記)
//描述:16進(jìn)位數(shù)轉(zhuǎn)換成8421碼,存放在C段中定義好的數(shù)組當(dāng)中
//須定義一個(gè)下標(biāo)8位的整數(shù)數(shù)組,C段中如下書(shū)寫(xiě)
//extern int led_out [8]={0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0};
//參數(shù):被轉(zhuǎn)換數(shù)小于0xFFFF的數(shù),符號(hào)標(biāo)記0或非零的數(shù)
//返回:無(wú)
.PUBLIC _hex_to_8421;
_hex_to_8421: .PROC
push bp to [sp];
bp=sp+1; //基址重定位,準(zhǔn)備取參數(shù)
r1=[bp+3]; //備轉(zhuǎn)換成8421碼的16進(jìn)位數(shù)字
r3=[bp+4]; //符號(hào)位標(biāo)志,為0,則做無(wú)符號(hào)整數(shù)處理,非1做有符號(hào)數(shù)處理
R4=_Led_Out; //輸出數(shù)據(jù)的地址******************************可修改輸出名稱
bp=_List_8421_Data; //基址定位到位權(quán)表頭**************************對(duì)應(yīng).IRAM段,可修改輸入名稱
test R3,0xFFFF; //檢查R3是否非0,如果非零,做有符號(hào)數(shù)處理,如果為0,做無(wú)符號(hào)數(shù)處理
je _hex_loop0; //為0,做無(wú)符號(hào)數(shù)處理,跳到_hex_loop0
R3=0xF000; //非0,做有符號(hào)數(shù)處理
[R4]=r3; //表的第1個(gè)單元高4字節(jié)存放符號(hào)標(biāo)記,F(xiàn)為負(fù),0為正
R1-=0X0001; //包括下1步,減1后反碼轉(zhuǎn)換成10進(jìn)位正數(shù)
R1^=0xFFFF;
_hex_loop0:
R2=0X0007; //R2為進(jìn)位標(biāo)志,從9到1循環(huán),R2初置7,進(jìn)入循環(huán)后減1為6做初值
_hex_loop1: //位權(quán)表遍歷開(kāi)始標(biāo)記
CALL _Clear_WatchDog; // 清看門狗
BP+=0X0001; //基址加1,定位到位權(quán)表第一個(gè)有效數(shù)字
R2-=0X0001; //位權(quán)減1,準(zhǔn)備輸出位權(quán)表第一個(gè)有效數(shù)字所對(duì)應(yīng)的位數(shù)字
cmp r1,[bp]; //比較被轉(zhuǎn)換數(shù)和當(dāng)前位權(quán)的大小
jb _hex_loop2; //如果被轉(zhuǎn)換數(shù)小于當(dāng)前位權(quán),則跳到"_hex_loop1",繼續(xù)比較
jmp _hex_loop3; //如果被轉(zhuǎn)換數(shù)大于當(dāng)前位權(quán),則跳到"_hex_loop3",進(jìn)行轉(zhuǎn)換
_hex_loop2: //R2進(jìn)位循環(huán)處理的標(biāo)記
CMP R2,0X0002;
JB _hex_loop4; //包括上1步,如果R2小于2,跳到_hex_loop4,將R2置為10
JMP _hex_loop1; //如果R2大于等于2,跳到"_hex_loop1",繼續(xù)比較
_hex_loop4:
R2=0x000A; //包括下1步,將R2置為10,跳到"_hex_loop1",繼續(xù)比較
JMP _hex_loop1;
_hex_loop3: //判斷并輸出數(shù)據(jù)的標(biāo)記
cmp r1,0x2710;
jnb _hex_2710; //包括上1步,如果R1大于等于0x2710(10000),跳到_hex_2710處理
cmp r1,0x03e8;
jnb _hex_03e8; //包括上1步,如果R1大于等于0x03E8(1000),跳到_hex_03E8處理
cmp r1,0x0064;
jnb _hex_0064; //包括上1步,如果R1大于等于0x0064(100),跳到_hex_0064處理
cmp r1,0x000a;
jnb _hex_000a; //包括上1步,如果R1大于等于0x000A(10),跳到_hex_000A處理
R3=R4+5; //包括下2步,輸出10進(jìn)制第1位,跳到"_hex_000",結(jié)束轉(zhuǎn)換
[R3]=R1;
jmp _hex_over;
_hex_2710:
R3=R4+1; //包括下3步,輸出10進(jìn)制第5位,被轉(zhuǎn)換數(shù)減位權(quán),做被轉(zhuǎn)換數(shù),跳到"_hex_loop1",繼續(xù)比較
[R3]=R2;
r1-=[bp];
jmp _hex_loop1;
_hex_03e8:
R3=R4+2; //包括下3步,輸出10進(jìn)制第4位,被轉(zhuǎn)換數(shù)減位權(quán),做被轉(zhuǎn)換數(shù),跳到"_hex_loop1",繼續(xù)比較
[R3]=R2;
r1-=[bp];
jmp _hex_loop1;
_hex_0064:
R3=R4+3; //包括下3步,輸出10進(jìn)制第3位,被轉(zhuǎn)換數(shù)減位權(quán),做被轉(zhuǎn)換數(shù),跳到"_hex_loop1",繼續(xù)比較
[R3]=R2;
r1-=[bp];
jmp _hex_loop1;
_hex_000a:
R3=R4+4; //包括下3步,輸出10進(jìn)制第2位,被轉(zhuǎn)換數(shù)減位權(quán),做被轉(zhuǎn)換數(shù),跳到"_hex_loop1",繼續(xù)比較
[R3]=R2;
r1-=[bp];
jmp _hex_loop1;
_hex_over:
pop bp from [sp];
RETF
.ENDP;
.PUBLIC _Clear_WatchDog;
_Clear_WatchDog: .PROC
PUSH R1 TO [SP];
R1 = 0x0001;
[ASM_Port_Watchdog_Clear] = R1;
POP R1 FROM [SP];
RETF
.ENDP;
