查看: 5951|回復(fù): 3
4*4鍵盤單鍵掃描1602顯示程序,感謝51hei群同胞的幫助
ID:17922 發(fā)表于 2009-12-15 21:42 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<reg52.h>
sbit p30=P3^0;
sbit p31=P3^1;
sbit p32=P3^2;
sbit p07=P0^7;
const s=1;
延時(shí)函數(shù)
delaynms(unsigned int m)
unsigned char i,j;
for(;m!=0;m--)
  for(i=0;i<4;i++)
   for(j=0;j<32;j++)
1602busy jump
busyjump()
bit result;
p30=0;
p31=1;
p32=1;
result=p07;
p32=0;
return result;
1602讀指令
readinstruction(unsigned char ins)
while(busyjump())
 p30=0;
 p31=0;
 P0=ins;
 p32=1;
 p32=0;
 1602讀數(shù)據(jù)
 readdata(unsigned char dat)
   while(busyjump());
   p30=1;
   p31=0;
   P0=dat;
   p32=1;
   p32=0;
 1602初始化
 chush()
 delaynms(15);//模塊熱啟動(dòng)
  readinstruction(0x36);
 readinstruction(0x0c);
 readinstruction(0x01);
 readinstruction(0x06);
顯示地址轉(zhuǎn)換
showaddr(unsigned char addr)
readinstruction(addr|0x80);
定位
char dingwei (char n)
char i;
n=~n;
switch(n)
case 0xf0:i=-1; break;
case 0xf1:i=0; break;
case 0xf2:i=1; break;
case 0xf4:i=2; break;
case 0xf8:i=3;  break;
return i;
主函數(shù)
main()
char h,l,j,k,flag;
unsigned char temp;
chush();
  temp=0xfe;
 flag=0;
  for(j=0;j<4;j++,temp=(temp<<1)+0x01)
 P1=temp;
 h=P1/16;
 l=P1&0x0f;
 k=dingwei(l)*4+dingwei(h)+1;
 if(dingwei(h)+1)
   delaynms(1);
  if(dingwei(h)+1)//去抖動(dòng)
  showaddr(0x00);
  readdata(k/10+0x30);
  readdata(k%10+0x30);
  delaynms(2);
  delaynms(1500);
  flag=1;
   if(j==3&&flag==0)
  showaddr(0x00);
  readdata('n');delaynms(2);
  readdata('o');delaynms(2);
  readdata(' ');delaynms(2);
  readdata('k');delaynms(2);
  readdata('e');delaynms(2);
  readdata('y');delaynms(2);
  readdata('p');delaynms(2);
  readdata('u');delaynms(2);
  readdata('t');delaynms(2);
  delaynms(150);
[此貼子已經(jīng)被作者于2009-12-17 23:32:23編輯過]
ID:19691 發(fā)表于 2009-12-16 09:38 | 只看該作者
不是很懂
i,m都是什么變量呀!
ID:17922 發(fā)表于 2009-12-20 19:29 | 只看該作者
i,m是用來(lái)延時(shí)的
ID:786505 發(fā)表于 2020-6-23 15:21 | 只看該作者
原理圖有沒有?
