查看: 2753|回復(fù): 1
LCD驅(qū)動(dòng)IC CS701 代碼程序
ID:10867 發(fā)表于 2015-4-10 10:50 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
byte datareg,s;
byte s1,s2,s3,s4,s5;
void write_ppi(void)
byte t;
t=8;
while(t--)
  l_ckb=1;
  l_ckb=0;
  src datareg;
  if(flag.1)
   l_cd0=1;
   l_cd0=0;
  l_ckb=1;
  nop;
  nop;
void lcd_init(void)
//device reset
l_csb = 1;
l_csb = 0;
    datareg=0x01;
write_ppi();
.delay 20;
//0x31  DT[2:0] 011  4 duty
l_csb = 1;
l_csb = 0;
datareg=0x31;
write_ppi();
datareg=0x03;
write_ppi();
//0x32
//[7:5] 001 internal RC 35khz  S0 S1
//[4]  1  LCD ON
//[3:1] 111
//[0] 0  Disable INTB
datareg=0x32;
write_ppi();
datareg=0x3E;//00111110
write_ppi();
//0x33 [7] 0 S2_INTB=S2
datareg=0x33;
write_ppi();
datareg=0x00;
write_ppi();
//0x34 frame rate 70hz
datareg=0x34;
write_ppi();
datareg=116;
write_ppi();
//0x35 Hi-Drive strong
datareg=0x35;
write_ppi();
datareg=0x03;
write_ppi();
//0x20 set write++
datareg=0x20;
write_ppi();
l_csb = 1;
clear_ram();
void display_bt(void)
//clear_ram();
l_csb = 1;
l_csb = 0;
datareg=0x80;
write_ppi();
s = s1;
datareg=s;
write_ppi();
s = s2;
datareg=s;
write_ppi();
  s = s3;
datareg=s;
write_ppi();
s = s4;
datareg=s;
write_ppi();
s = s5;
datareg=s;
write_ppi();
l_csb = 1;
CS701.pdf
277.7 KB, 下載次數(shù): 5, 下載積分: 黑幣 -5
ID:105891 發(fā)表于 2016-2-20 09:25 | 只看該作者
謝謝分享,參考一下
