查看: 3426|回復(fù): 0
Wave文件解碼
ID:75926 發(fā)表于 2015-4-10 16:53 | 顯示全部樓層 |閱讀模式
typedef unsigned int uint32_t;
typedef unsigned short uint16_t;
//RIFF塊
typedef  struct
    uint32_t ChunkID;                           //chunk id;這里固定為"RIFF",即0X46464952
    uint32_t ChunkSize ;                //集合大小;文件總大小-8
    uint32_t Format;                           //格式;WAVE,即0X45564157
}ChunkRIFF ;
//fmt塊
typedef  struct
    uint32_t ChunkID;                           //chunk id;這里固定為"fmt ",即0X20746D66
    uint32_t ChunkSize ;                //子集合大小(不包括ID和Size);這里為:20.
    uint16_t AudioFormat;                  //音頻格式;0X01,表示線性PCM;0X11表示IMA ADPCM
    uint16_t NumOfChannels;                //通道數(shù)量;1,表示單聲道;2,表示雙聲道;
    uint32_t SampleRate;                //采樣率  每秒鐘有多少個(gè)字節(jié)的數(shù)據(jù)送到DAC上
    uint32_t ByteRate;                        //字節(jié)速率;通道數(shù)*DAC精度
    uint16_t BlockAlign;                //塊對(duì)齊(字節(jié));
    uint16_t BitsPerSample;                //單個(gè)采樣數(shù)據(jù)大小  就是DAC需要的精度
//   uint16_t ByteExtraData;                //附加的數(shù)據(jù)字節(jié);2個(gè); 線性PCM,沒有這個(gè)參數(shù)
}ChunkFMT;
int main()
    char Wave[]="ykzzldx.wav";
    ChunkRIFF Riff;
    ChunkFMT Fmt;
    FILE *Wavefil;
    Wavefil=fopen(Wave,"r+");
    if(Wavefil==NULL)
        printf("da kai wen jian shi bai\n");
        return 0;
    fread(&Riff,sizeof(Riff),1,Wavefil);
    fread(&Fmt,sizeof(Fmt),1,Wavefil);
    if(Riff.ChunkID==0X46464952)
        printf("zhe shi wav wen jian \n");
        printf("zheng ge wen jian de da xiao wei: %dKB\n",(Riff.ChunkSize+8)>>10);
        if(Fmt.ChunkID==0X20746D66);
            printf("Wav wen jian !\n");
            if(Fmt.AudioFormat==0x01)
                printf("zhe shi xian xing PCM ge shi \n");
            printf("tong dao shu liang wei %d\n",Fmt.NumOfChannels);
            printf("cai yang su lv wei: %dHz\n",Fmt.SampleRate);
            printf("zi jie su lv wei :%dHz\n",Fmt.ByteRate);
            printf("dan ge cai yang shu ju da xiao wei:\t%d\n",Fmt.BitsPerSample);
        printf("zhe bu shi WAV wen jian \n");
        return 0;
    fclose(Wavefil);
    return 0;
