查看: 3212|回復: 5
搖搖棒c程序
ID:78027 發(fā)表于 2015-5-8 22:30 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#define  uchar  unsigned    char
#define  uint   unsigned   int
sbit key=P2^7;            //切換按鍵
uint  num=0;
uchar code zi[]={
0x10,0x40,0x10,0x22,0xF0,0x15,0x1F,0x08,
      0x10,0x14,0xF0,0x63,0x80,0x00,0x82,0x00,
      0x82,0x40,0x82,0x80,0xE2,0x7F,0x92,0x00,
      0x8A,0x00,0xC6,0x00,0x80,0x00,0x00,0x00,
0x40,0x04,0x30,0x04,0x11,0x04,0x96,0x04,
      0x90,0x04,0x90,0x44,0x91,0x84,0x96,0x7E,
      0x90,0x06,0x90,0x05,0x98,0x04,0x14,0x04,
      0x13,0x04,0x50,0x06,0x30,0x04,0x00,0x00,
0x04,0x00,0x04,0x00,0x04,0x08,0x04,0x18,
      0x14,0x04,0x24,0x04,0xC4,0x02,0x04,0x02,
      0x04,0x01,0x04,0x21,0x84,0x40,0x04,0x80,
      0x04,0x40,0xFE,0x3F,0x04,0x00,0x00,0x00,
  0x40,0x80,0x42,0x80,0x42,0x40,0x42,0x20,
      0x42,0x10,0x42,0x0C,0x42,0x03,0xFE,0x00,
      0x42,0x03,0x42,0x0C,0x42,0x10,0x42,0x20,
      0x43,0x40,0x62,0xC0,0x40,0x40,0x00,0x00,
0x00,0x00,0xF8,0xFF,0x08,0x00,0x08,0x00,
      0xCC,0x1F,0x4A,0x08,0x49,0x08,0x48,0x08,
      0x48,0x08,0x48,0x08,0xE8,0x1F,0x48,0x40,
      0x08,0x80,0xFC,0x7F,0x08,0x00,0x00,0x00,
0x00,0x40,0x00,0x40,0x00,0x40,0x00,0x40,
      0x00,0x40,0x00,0x40,0x00,0x40,0xFF,0x7F,
      0x20,0x40,0x20,0x40,0x20,0x40,0x30,0x40,
      0x20,0x40,0x00,0x60,0x00,0x40,0x00,0x00
//好好學習 天天向上
uchar  code  xingming[]={
0x00,0x01,0x00,0x01,0x88,0x00,0x88,0x7F,
      0x44,0x89,0x47,0x89,0x28,0x89,0x10,0x8F,
      0x28,0x89,0x45,0x89,0x42,0x89,0x84,0x9F,
      0x8C,0x80,0x00,0xE1,0x00,0x01,0x00,0x00,
      0x10,0x14,0xF0,0x63,0x02,0x08,0xFA,0x09,
      0x02,0x09,0x02,0x09,0x02,0x4D,0xFF,0x89,
      0x02,0x41,0x80,0x3F,0x00,0x01,0x00,0x00,
};//爸爸媽媽
uchar code loveyou[]={
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x78,0x00,0xFC,0x00,0xFE,0x01,0xFE,0x03,0xFE,0x07,0xFE,0x0F,0xFE,0x1F,0xFC,0x3F,
0xF8,0x7F,0xFC,0x3F,0xFE,0x1F,0xFE,0x0F,0xFE,0x07,0xFE,0x03,0xFE,0x01,0xFC,0x00,
0x78,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/*心形圖案*/
uchar  code  Hello[]={
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/* " " 0*/
0X08,0X20,0Xf8,0x3f,0x08,0x21,0x00,0x01,0x00,0x01,0x08,0x21,0Xf8,0x3f,0x08,0x20,/* "H" 1*/
0x00,0x00,0x00,0x1F,0x80,0x22,0x80,0x22,0x80,0x22,0x80,0x22,0x00,0x13,0x00,0x00,/* "e" 2*/
0x00,0x00,0x08,0x20,0x08,0x20,0xF8,0x3F,0x00,0x20,0x00,0x20,0x00,0x00,0x00,0x00,/* "l",3*/
0x00,0x00,0x08,0x20,0x08,0x20,0xF8,0x3F,0x00,0x20,0x00,0x20,0x00,0x00,0x00,0x00,/* "l",4*/
0x00,0x00,0x00,0x1F,0x80,0x20,0x80,0x20,0x80,0x20,0x80,0x20,0x00,0x1F,0x00,0x00,/* "o",5*/
0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x33,0x00,0x30,0x00,0x00,0x00,0x00,0x00,0x00,/* "!",6*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/* " ",7*/
uchar code Smile[] =
0xF0,0x1F,0x3C,0x3C,0x0E,0xF7,0x06,0xEF,0xF3,0xDC,0xF3,0xB0,0x63,0xB0,0x03,0xB0,
0xF3,0xB0,0xF3,0xB8,0x03,0xDD,0x06,0xEF,0x0E,0x76,0x3C,0x3C,0xF8,0x1F,0x00,0x00,
    //笑臉
uchar code Thanks[] =
//  謝
      0x40,0x00,0x42,0x00,0xCC,0x3F,0x00,0x52,0xFC,0x2B,0x56,0x12,0x55,0x4A,0x54,0x86,
      0xFE,0x7F,0x24,0x01,0x20,0x46,0x20,0x80,0xFF,0x7F,0x20,0x00,0x20,0x00,0x00,0x00,
//   謝
      0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7C,0x10,0xFE,0x3B,
      0xFE,0x3B,0x7C,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
uchar code tian[]=
      0x80,0x00,0x82,0x80,0x82,0x40,0x82,0x30,
      0xFE,0x0F,0x82,0x00,0x82,0x00,0x82,0x00,
      0x82,0x00,0x82,0x00,0xFE,0xFF,0x82,0x00,
      0x83,0x00,0xC2,0x00,0x80,0x00,0x00,0x00,
      0x00,0x04,0x00,0x02,0xC0,0x01,0x00,0x00,
      0xF0,0x3F,0x00,0x40,0x01,0x40,0x02,0x40,
      0x1C,0x40,0x08,0x40,0x00,0x40,0x00,0x70,
      0x40,0x00,0x80,0x00,0x00,0x07,0x00,0x00
     // 天天開心
uchar code  happy[]=
   0x00,0x00,0x80,0x40,0x60,0x40,0x38,0x40,
      0x1E,0x41,0x14,0x41,0x10,0x41,0x10,0x41,
      0xFF,0x7F,0xFE,0x7F,0x10,0x41,0x10,0x41,
      0x90,0x41,0x18,0x41,0x10,0x60,0x00,0x40,
    0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0xFF,
      0xFC,0x7F,0x84,0x20,0x84,0x20,0x84,0x20,
      0x84,0x20,0x84,0x20,0x84,0x20,0x84,0x20,
      0xFC,0xFF,0xFE,0x7F,0x04,0x00,0x00,0x00,
   0x00,0x00,0xC0,0x00,0x60,0x00,0xFF,0xFF,
      0xFE,0x7F,0x30,0x80,0x60,0x41,0x08,0x71,
      0x08,0x3D,0xFF,0x0F,0xFE,0x07,0x08,0x0D,
      0xF8,0x39,0xFC,0x71,0x08,0xE1,0x00,0x41,
     0x00,0x00,0x00,0x40,0x80,0x20,0x80,0x30,
      0xFE,0x1C,0xFC,0x0E,0x84,0x24,0x84,0x40,
      0xFE,0xFF,0xF6,0x7F,0x82,0x00,0x83,0x02,
      0xC2,0x0C,0x80,0x18,0x00,0x70,0x00,0x20
// 生日快樂
uchar  code shenti[]={
0x00,0x40,0x00,0x42,0x00,0x42,0x00,0x22,
      0xFC,0x23,0x54,0x22,0x56,0x12,0x55,0x12,
      0x54,0x0A,0x54,0x46,0x54,0x82,0xFE,0x7F,
      0x04,0x01,0x80,0x00,0x40,0x00,0x00,0x00,
0x40,0x00,0x20,0x00,0xF8,0xFF,0x07,0x08,
      0x10,0x06,0x90,0x01,0x70,0x04,0x10,0x04,
      0xFF,0xFF,0x10,0x04,0x70,0x04,0x90,0x01,
      0x18,0x06,0x10,0x0C,0x00,0x04,0x00,0x00,
0x40,0x00,0x20,0x00,0xF8,0xFF,0x07,0x44,
      0x88,0x29,0x48,0x19,0x38,0x27,0x10,0x49,
      0x54,0x89,0x54,0x89,0xFF,0xFF,0x54,0x89,
      0x54,0x89,0x7C,0xCD,0x10,0x49,0x00,0x00,
0x00,0x40,0x00,0x30,0xFC,0x0F,0x44,0x40,
      0x54,0x23,0x54,0x15,0x54,0x49,0x55,0x81,
      0xFE,0x7F,0x54,0x05,0x54,0x09,0x54,0x11,
      0xF4,0x29,0x46,0x64,0x44,0x20,0x00,0x00
// 身體健康
void delay(uint z)
   uint x;
     for(x=0;x<z;x++);
void display1()                              //顯示“LOVE” 64*16像素
    uchar i;
     delay(4000);
      for(i=0;i<128;i++)
           P1=~zi[2*i];
           P3=~zi[2*i+1];
           delay(120);
void display2()                           //顯示“心形圖案” 64*16像素
  uchar  i;
     delay(4000);
      for(i=0;i<64;i++)
          P1=~xingming[2*i];
          P3=~xingming[2*i+1];
          delay(120);
  void display3()                                //顯示“LOVE” 64*16像素
    uchar i;
     delay(4000);
      for(i=0;i<64;i++)
           P1=~loveyou[2*i];
           P3=~loveyou[2*i+1];
           delay(120);
void display4()                     //顯示“Hello!” 64*16像素
  uchar i;
  delay(4000);
  for(i=0;i<64;i++)
   P1=~Hello[i*2];
P3=~Hello[i*2+1];
delay(120);
void display5()                  //顯示“笑臉圖案” 64*16像素
  uchar i;
  delay(4000);
  for(i=0;i<64;i++)
   P1=~Smile[i*2];
P3=~Smile[i*2+1];
delay(120);
void display6()
   uchar i;
   delay(4000);
  for(i=0;i<64;i++)
   P1=~tian[i*2];
   P3=~tian[i*2+1];
delay(120);
void display7()
   uchar i;
   delay(4000);
  for(i=0;i<64;i++)
   P1=~happy[i*2];
   P3=~happy[i*2+1];
delay(120);
void display8()
   uchar i;
   delay(4000);
  for(i=0;i<64;i++)
   P1=~shenti[i*2];
   P3=~shenti[i*2+1];
delay(120);
void display9()           //顯示“謝謝!” 48*16像素
   uchar i;
   delay(4000);
  for(i=0;i<48;i++)
   P1=~Thanks[i*2];
   P3=~Thanks[i*2+1];
delay(120);
void  keyscan()
     if(key==0)
       delay(500);
        if(key==0)
          num++;
          while(!key);
          if(num==10)
           num=1;
void  display()
           switch(num)
              case 1: display1();break;
              case 2: display2();break;
              case 3: display3();break;
              case 4: display4();break;
              case 5: display5();break;
              case 6: display6();break;
              case 7: display7();break;
              case 8: display8();break;
              case 9: display9();break;
              default :display1();
void  main()
    keyscan();
     display();
admin + 50 共享資料的積分獎勵!
ID:1 發(fā)表于 2015-5-8 22:37 | 只看該作者
很好的資料 能分享一下電路圖和詳細的制作資料嗎?
ID:104472 發(fā)表于 2016-3-7 16:22 | 只看該作者
實用,51程序里面比較明了的程序,就是注釋比較少。
ID:117053 發(fā)表于 2016-5-3 18:41 | 只看該作者
建議加一些注釋,
ID:166208 發(fā)表于 2017-2-23 19:52 | 只看該作者
能不能提供一張原理圖
能不能提供一張原理圖
