查看: 3426|回復(fù): 0
TINY13+HC163+18B20溫度顯示與控制
ID:18916 發(fā)表于 2015-5-11 14:18 | 顯示全部樓層 |閱讀模式
//ICC-AVR application builder : 2012/6/19 下午 10:43:42
// Target : T13
// Crystal: 4.8000Mhz
#include <iot13v.h>
#include <macros.h>
#include "ds18b20.h"
#define CPL  PORTB &= ~(1<<PB4)
#define CPH  PORTB |=(1<<PB4)
#define DAL  PORTB &= ~(1<<PB3)
#define DAH  PORTB |=(1<<PB3)
#define FSL  PORTB &= ~(1<<PB1)
#define FSH  PORTB |=(1<<PB1)
char dsp,tdsp;
char adcdata=0;
flash char LED[]={
               0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F
                                //0xed,0x21,0x8f,0xab,0x63,0xea,0xee,0xa1,0xef,0xeb
void delay1ms(void)   //誤差 0us
     unsigned char a,b;
    for(b=4;b>0;b--)
        for(a=248;a>0;a--);
void delay10ms(void)   //誤差 0us
    unsigned char a,b;
    for(b=215;b>0;b--)
        for(a=45;a>0;a--);
void beep(void)  //蜂鳴器響一聲函數(shù)
  unsigned char i;
  for (i=0;i<100;i++)
   FSH;
   delay1ms();
   FSL;       //BEEP取反
   delay1ms();
   for (i=0;i<100;i++)
   FSH;
   //delay1ms();
   //FSL;       //BEEP取反
   delay1ms();
void send(char a)
  char i;
  for(i=8;i>0;i--)
                  CPL;delay(1);
                  if(a&0x80)
                   DAH;
                    DAL;
          CPH;delay(1);
                   a=a<<1;
void disp(void)
  //FSH;
  send(LED[dsp%10]+tdsp);
  send(LED[dsp/10]+tdsp);
  //delay(255);
  //delay(255);FSL;
void port_init(void)
PORTB = 0x00;
DDRB  = 0x1B;
void  adcstar(void)
        DIDR0=0x04;
        ADMUX (ADC Multiplexer Select Register) PDF86?
        bit7  Res                 ??
        bit6  REFS0                0=VCC????????;1=??????
        bit5  ADLAR                0=???;1=???(8bit??ADCH??)
        bit4:2  Res                 ??
        bit1:0  MUX1,MUX0        ????,00=ADC0(PB5);01=ADC1(PB2);10=ADC2(PB4);11=ADC3 (PB3)
        ADMUX=(1<<REFS0)|(0<<ADLAR)|(0<<MUX1)|(1<<MUX0);
        ADCSRA=(1<<ADEN)|(1<<ADSC)|(0<<ADATE)|(0<<ADIF)|(0<<ADIE)|(0<<ADPS2)|(1<<ADPS1)|(0<<ADPS0);
        ADCSRA (ADC Control and Status Register A) PDF 87?
        bit7   ADEN ADC??=1
        bit6   ADSC ??ADC????=1
        bit5   ADATE ?????
        bit4   ADIF ADC????
        bit3   ADIE ADC????
        bit2:0 ADC ??????
#pragma interrupt_handler eeprom_ready_isr:iv_EE_RDY
void eeprom_ready_isr(void)//內(nèi)部EEPROM讀寫初始化
//eeprom ready event
//call this routine to initialize all peripherals
void init_devices(void)
//stop errant interrupts until set up
CLI(); //disable all interrupts
port_init();
MCUCR = 0x00;
TIMSK0 = 0x00; //timer interrupt sources
GIMSK = 0x00; //interrupt sources
SEI(); //re-enable interrupts
//all peripherals are now initialized
char key(void)
  if (ADCSRA&(1<<ADIF))
           adcdata=ADC/4;
           ADCSRA|=(1<<ADSC)|(1<<ADIF); // ???ADC ???? ADIF?1???????1??0
        }//delay(100);
                return(adcdata);
void main(void)
  char stmp,mode=0;
  init_devices();
  Init_DS18B20();
  adcstar();
  ReadTemp();
  stmp=EEPROMread(0);//讀取EEPROM預(yù)設(shè)溫度數(shù)據(jù)
     FSH;
        // delay10ms();
        //tmp=0;
   if(key()==0)
   mode++;
   if(mode>1)
   mode=0;
   while(key()==0);
   delay10ms();
   if(mode==1)
   tdsp=0x80;
   delay10ms();
   if(key()==101)
   stmp++;
   if(stmp>99)
   stmp=99;
   EEPROMwrite(0,stmp);//向EEPROM寫入預(yù)設(shè)溫度數(shù)據(jù)
   while(key()==101);
   delay10ms();
   if(key()==173)
   stmp--;
   if(stmp<1)
   stmp=1;
   while(key()==173);
   if(dsp!=stmp)
   dsp=stmp;
   disp();
   ReadTemp();
  delay10ms();
  if(mode==0)
   tdsp=0x00;
   if(tmp>stmp)
     beep();
     FSH;
   if(dsp!=tmp)
   dsp=tmp;
   disp();
  //delay10ms();
                                   THE ds18b20 LIB
   File Name:       ds18b20.h
#ifndef ds18b20_2005_4_9
#define ds18b20_2005_4_9
#define DQL  PORTB &= ~(1<<PB0)
#define DQH  PORTB |=(1<<PB0)
#define DQ  PINB&(1<<PB0)
#define DO DDRB|= (1<<PB0)         //PB0定義成輸出
#define DI DDRB&=~(1<<PB0)         //PB0定義成輸入
uchar tmp;              //
/***********ds18b20延遲子函數(shù)(晶振12MHz )*******/
void delay_18B20(unsigned int i)
         unsigned char a,b;
    for(b=9;b>0;b--)
        for(a=i;a>0;a--);
void delay(unsigned char i)
         unsigned char a,b;
    for(b=2;b>0;b--)
        for(a=i;a>0;a--);
/**********ds18b20初始化函數(shù)**********************/
void Init_DS18B20(void)
         unsigned char x=0;
         DO;
         DQH;          //拉高總線
         delay(30);
         DQL;          //單片機(jī)將DQ拉低
         delay(255);delay(50); //精確延時(shí) 大于 480us
         DQH;          //拉高總線
         DI;
        if(DQ)
        {x=0;}else{x=1;}
                DO;
        DQL;delay(55);
        DQH;          //拉高總線
        delay(55);
/***********ds18b20讀一個(gè)字節(jié)**************/
unsigned char ReadOneChar(void)
        uchar i=0;
        uchar dat = 0;
        for (i=8;i>0;i--)
                 DO;
                  DQL;      // 給脈沖信號(hào)
                  delay(1);
                  dat>>=1;     //數(shù)據(jù)右移一位
                  DQH;
                  DI;
                  if(DQ)
                 { dat|=0x80;}   //按位或,取最高位
                  delay(20);
        return(dat);
/*************ds18b20寫一個(gè)字節(jié)****************/
void WriteOneChar(uchar dat)
        unsigned char i=0;
        DO;
        for (i=8; i>0; i--)
                  DQL;
                delay(0);
                if(dat&0x01)
                {DQH;}
                {DQL;}
            delay(25);
                DQH;            //上升沿將數(shù)據(jù)送入
            dat>>=1;delay(1);
}//DQH;delay(1);
/**************讀取ds18b20當(dāng)前溫度************/
void ReadTemp(void)
        unsigned char a=0;
        unsigned char b=0;
        //unsigned char t=0;
        Init_DS18B20();
        WriteOneChar(0xCC);            // 跳過讀序號(hào)列號(hào)的操作
        WriteOneChar(0x44);         // 啟動(dòng)溫度轉(zhuǎn)換
        delay(255);delay(150);     // this message is wery important
        Init_DS18B20();
        WriteOneChar(0xCC);         //跳過讀序號(hào)列號(hào)的操作
        WriteOneChar(0xBE);         //讀取溫度寄存器等(共可讀9個(gè)寄存器) 前兩個(gè)就是溫度
        a=ReadOneChar();            //讀取溫度值低位
        b=ReadOneChar();                   //讀取溫度值高位
        //temp_value=b<<4;        //左移四位,擴(kuò)大16倍,變?yōu)橐粋(gè)字節(jié)的高四位
        //temp_value+=(a&0xf0)>>4;//取溫度值的地位的高四位,右移四位后與溫度的高四位相加得到溫度值
    //delay(150);
        tmp=(b<<4)+((a&0xf0)>>4);
//void temp_to_str()   //溫度數(shù)據(jù)轉(zhuǎn)換成液晶字符顯示
//tmp=temp_value;
#endif
admin + 50 共享資料的積分獎(jiǎng)勵(lì)!
