查看: 5286|回復: 0
關(guān)于用單片機內(nèi)部時鐘實現(xiàn)時鐘計數(shù)
ID:20965 發(fā)表于 2010-1-12 23:49 | 顯示全部樓層 |閱讀模式
用軟件實現(xiàn)時鐘計數(shù),下載到開發(fā)板上,數(shù)碼管上數(shù)字一閃一閃的,剛開始學,不知為什么?求助。程序如下:
 #include<reg52.h>
 #define uint unsigned char
 uchar code led_7seg[]={0x28,0x7e,0xa2,0x62,0x74,0x61,0x21,0x7a,0x20,0x60};
 uchar hour=23,minute=59,second=50,n=0;
 uint count=0;
 void init_timer0(void)    //timer0每2MS中斷一次
    TMOD=0x01;
    TH0=(65536-1000)/256;
    TL1=(65536-1000)%256;
    ET0=1;
    TR0=1;
    EA=1;
 void d1_10ms(void)
    uchar i;
    for(i=200;i>0;i--){}
 uchar kbscan(void)
    uchar sccode,recode;
    P1=0xf0;
    if((P1&0xf0)!=0xf0)
      d1_10ms();
      if((P1&0xf0)!=0xf0)
        sccode=0xfe;
        while((sccode&0x10)!=0)
            P1=sccode;
            if((P1&0xf0)!=0xf0)
                recode=(P1&0xf0)|0xf0;
                return((~sccode)+(~recode));
            sccode=(sccode<<1)|0x01;
    return(0);
 void timer0_int(void) interrupt 1 using 1
    TL0=(65536-1000)%256;
    count++;
    switch(n&&0x07)
     case 0:{P0=led_7seg[hour/10];P2=0xfe;}break;
     case 1:{P0=led_7seg[hour%10];P2=0xfd;}break;
     //case 2:{P0=led_7seg[10];P2=0xfb;}break;
     case 3:{P0=led_7seg[minute/10];P2=0xf7;}break;
     case 4:{P0=led_7seg[minute%10];P2=0xef;}break;
     //case 5:{P0=led_7seg[10];P2=0xdf;}break;
     case 6:{P0=led_7seg[second/10];P2=0xbf;}break;
     case 7:{P0=led_7seg[second%10];P2=0x7f;}break;
     default:break;
    if(count==500) //1MS時間到調(diào)整顯示時間
        count=0;
        second++;
            if(second==60)
                second=0;
                minute++;
            if(minute==60)
                 minute=0;
                 hour++;
                 if(hour==24)
                    hour=0;
 void main(void)
    uchar key;
    init_timer0();
     key=kbscan();
     switch(key)
        case 0x11:{if(hour<23)hour++;else hour=0;}break;
        case 0x21:{if(minute<59)minute++;else minute=0;}break;
        default:break;
[此貼子已經(jīng)被作者于2010-1-12 23:50:00編輯過]
