電機(jī)轉(zhuǎn)同時(shí)點(diǎn)陣顯示
#include <reg52.h>
sbit da =P2^7;
sbit shcp=P2^5;
sbit stcp=P2^6;
uint led_array_count,anode_next;
bit motor_flag=0,led_array_flag;
uchar anode,negative;
uchar a,b;
void delays(uchar ms)
uint a;
while(ms--) for(a=0;a<100;a++);
////////////////////////////////////////初始化定時(shí)器
void initial_timer0()
TMOD=0X02;
TH0=0x38; //100us
TL0=0x38;
TR0=1;
EA=1;
ET0=1;
uchar code motor_run[]={0x08,0x0c,0x04,0x06,0x02,0x03,0x01,0x09}; //最高頻率250us
uchar code led_array_anode[]={ 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
0xC1,0x01,0x00,0x00,0x00,0x00,0x80,0x83,
0x60,0x01,0x01,0x00,0x00,0x80,0x80,0x06,
0x30,0x00,0x01,0x01,0x80,0x80,0x00,0x0C,
0x18,0x00,0x00,0x81,0x81,0x00,0x00,0x18,
0x0C,0x00,0x80,0x80,0x01,0x01,0x00,0x30,
0x06,0x80,0x80,0x00,0x01,0x01,0x01,0x60,
0x83,0x80,0x00,0x00,0x00,0x00,0x01,0xC1,
0xE1,0x01,0x01,0x00,0x00,0x80,0x80,0x87,
0x62,0xC3,0x01,0x00,0x00,0x80,0xC3,0x46,
0x30,0x62,0x03,0x01,0x80,0xC0,0x46,0x0C,
0x08,0x14,0x22,0x41,0x82,0x44,0x28,0x10,
0x00,0x08,0x14,0x22,0x44,0x28,0x10,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,
0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,
0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0xE0, //16
0x00,0x00,0x00,0x00,0x80,0xC0,0xE0,0xF0,
0x00,0x00,0x00,0x80,0xC0,0xE0,0xF0,0xF8,
0x00,0x00,0x80,0xC0,0xE0,0xF0,0xF8,0xFC,
0x00,0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,
0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF,
0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF,0xFF,
0xE0,0xF0,0xF8,0xFC,0xFE,0xFF,0xFF,0xFF,
0xF0,0xF8,0xFC,0xFE,0xFF,0xFF,0xFF,0xFF,
0xF8,0xFC,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFC,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0x00,0x7E,0x7E,0x7E,0x7E,0x7E,0x7E,0x00,
0x00,0x00,0x3C,0x3C,0x3C,0x3C,0x00,0x00,
0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00, //31
uchar led_array_negative[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe}; //負(fù)極
////////////////////////////////////// //595送數(shù)據(jù)
void input595(uchar dat)
uchar b;
shcp=0;
for(b=0;b<8;b++)
da=dat&0x80;
dat=dat<<1;
shcp=1;
shcp=0;
//////////////////////////////////// //595輸出數(shù)據(jù)
void output595()
stcp=0;
stcp=1;
void motor_foreward()
uint motor_time;
if(!led_array_flag)
motor_time++;
if(motor_time==5)
motor_time=0;
P3=motor_run[a];
a++;
if(a>=8)
a=0;
void refresh_led_array() //刷新點(diǎn)陣
if(!led_array_flag)
anode_next++;
if(anode_next==100) //1s
anode_next=0;
anode=anode+8;
if(anode>240)
anode=0;
for(negative=0;negative<8;negative++)
input595(led_array_anode[anode+negative]);
input595(led_array_negative[negative]);
output595();
initial_timer0();
// initial_timer1();
refresh_led_array();
motor_foreward();
void timer0_interrupt()interrupt 1
led_array_count++;
if(led_array_count==10) //1ms
led_array_count=0;
!led_array_flag;
