完整程序源代碼工程文件下載地址:
使用dsp庫(kù)的FFT函數(shù).rar
(425.44 KB, 下載次數(shù): 267)
2015-5-27 18:01 上傳
點(diǎn)擊文件名下載附件
stm32 dsp lib V2.0庫(kù)文件下載:
stm32 dsp lib V2.0介紹.pdf
(233.4 KB, 下載次數(shù): 185)
2015-5-27 18:01 上傳
點(diǎn)擊文件名下載附件
stm32 dsp lib V2.0.zip
(1.36 MB, 下載次數(shù): 172)
2015-5-27 18:01 上傳
點(diǎn)擊文件名下載附件
- * @file FFT_Demo/src/main.c
- * @author MCD Application Team
- * @version V2.0.0
- * @date 04/27/2017
- * @file FFT_Demo/src/stm3210b_lcd.c
- * @version V2.0.0
- * @date 04/27/2009
- * @brief This file includes the LCD driver for AM-240320LTNQW00H
- * (LCD_HX8312), AM-240320L8TNQW00H (LCD_ILI9320),
- * AM-240320LDTNQW00H (LCD_SPFD5408B) Liquid Crystal Display
- * Module of STM3210B-EVAL board.
- * @copy
- * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
- * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
- * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
- * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
- * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
- * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
- * <h2><center>© COPYRIGHT 2009 STMicroelectronics</center></h2>
- /* Includes ------------------------------------------------------------------*/
- #include "stm3210b_lcd.h"
- #include "fonts.h"
- /** @addtogroup FFT_Demo
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- #define LCD_ILI9320 0x9320
- #define LCD_HX8312 0x8312
- #define LCD_SPFD5408 0x5408
- #define START_BYTE 0x70
- #define SET_INDEX 0x00
- #define READ_STATUS 0x01
- #define LCD_WRITE_REG 0x02
- #define LCD_READ_REG 0x03
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- /* Global variables to set the written text color */
- static __IO uint16_t TextColor = 0x0000, BackColor = 0xFFFF;
- static __IO uint32_t LCDType = LCD_ILI9320;
- /* Private function prototypes -----------------------------------------------*/
- static void LCD_WriteRegHX8312(uint8_t LCD_Reg, uint8_t LCD_RegValue);
- static void LCD_WriteRegILI9320(uint8_t LCD_Reg, uint16_t LCD_RegValue);
- /* Private functions ---------------------------------------------------------*/
- * @brief Setups the LCD.
- * @param None
- * @retval : None
- void LCD_Setup(void)
- /* Configure the LCD Control pins --------------------------------------------*/
- LCD_CtrlLinesConfig();
- /* Configure the SPI2 interface ----------------------------------------------*/
- LCD_SPIConfig();
- if(LCDType == LCD_ILI9320)
- Delay(5); /* Delay 50 ms */
- /* Start Initial Sequence ------------------------------------------------*/
- LCD_WriteReg(R229, 0x8000); /* Set the internal vcore voltage */
- LCD_WriteReg(R0, 0x0001); /* Start internal OSC. */
- LCD_WriteReg(R1, 0x0100); /* set SS and SM bit */
- LCD_WriteReg(R2, 0x0700); /* set 1 line inversion */
- LCD_WriteReg(R3, 0x1030); /* set GRAM write direction and BGR=1. */
- LCD_WriteReg(R4, 0x0000); /* Resize register */
- LCD_WriteReg(R8, 0x0202); /* set the back porch and front porch */
- LCD_WriteReg(R9, 0x0000); /* set non-display area refresh cycle ISC[3:0] */
- LCD_WriteReg(R10, 0x0000); /* FMARK function */
- LCD_WriteReg(R12, 0x0000); /* RGB interface setting */
- LCD_WriteReg(R13, 0x0000); /* Frame marker Position */
- LCD_WriteReg(R15, 0x0000); /* RGB interface polarity */
- /* Power On sequence -----------------------------------------------------*/
- LCD_WriteReg(R16, 0x0000); /* SAP, BT[3:0], AP, DSTB, SLP, STB */
- LCD_WriteReg(R17, 0x0000); /* DC1[2:0], DC0[2:0], VC[2:0] */
- LCD_WriteReg(R18, 0x0000); /* VREG1OUT voltage */
- LCD_WriteReg(R19, 0x0000); /* VDV[4:0] for VCOM amplitude */
- Delay(20); /* Dis-charge capacitor power voltage (200ms) */
- LCD_WriteReg(R16, 0x17B0); /* SAP, BT[3:0], AP, DSTB, SLP, STB */
- LCD_WriteReg(R17, 0x0137); /* DC1[2:0], DC0[2:0], VC[2:0] */
- LCD_WriteReg(R18, 0x0139); /* VREG1OUT voltage */
- LCD_WriteReg(R19, 0x1d00); /* VDV[4:0] for VCOM amplitude */
- LCD_WriteReg(R41, 0x0013); /* VCM[4:0] for VCOMH */
- LCD_WriteReg(R32, 0x0000); /* GRAM horizontal Address */
- LCD_WriteReg(R33, 0x0000); /* GRAM Vertical Address */
- /* Adjust the Gamma Curve ------------------------------------------------*/
- LCD_WriteReg(R48, 0x0006);
- LCD_WriteReg(R49, 0x0101);
- LCD_WriteReg(R50, 0x0003);
- LCD_WriteReg(R53, 0x0106);
- LCD_WriteReg(R54, 0x0b02);
- LCD_WriteReg(R55, 0x0302);
- LCD_WriteReg(R56, 0x0707);
- LCD_WriteReg(R57, 0x0007);
- LCD_WriteReg(R60, 0x0600);
- LCD_WriteReg(R61, 0x020b);
- /* Set GRAM area ---------------------------------------------------------*/
- LCD_WriteReg(R80, 0x0000); /* Horizontal GRAM Start Address */
- LCD_WriteReg(R81, 0x00EF); /* Horizontal GRAM End Address */
- LCD_WriteReg(R82, 0x0000); /* Vertical GRAM Start Address */
- LCD_WriteReg(R83, 0x013F); /* Vertical GRAM End Address */
- LCD_WriteReg(R96, 0x2700); /* Gate Scan Line */
- LCD_WriteReg(R97, 0x0001); /* NDL,VLE, REV */
- LCD_WriteReg(R106, 0x0000); /* set scrolling line */
- /* Partial Display Control -----------------------------------------------*/
- LCD_WriteReg(R128, 0x0000);
- LCD_WriteReg(R129, 0x0000);
- LCD_WriteReg(R130, 0x0000);
- LCD_WriteReg(R131, 0x0000);
- LCD_WriteReg(R132, 0x0000);
- LCD_WriteReg(R133, 0x0000);
- /* Panel Control ---------------------------------------------------------*/
- LCD_WriteReg(R144, 0x0010);
- LCD_WriteReg(R146, 0x0000);
- LCD_WriteReg(R147, 0x0003);
- LCD_WriteReg(R149, 0x0110);
- LCD_WriteReg(R151, 0x0000);
- LCD_WriteReg(R152, 0x0000);
- /* Set GRAM write direction and BGR = 1 */
- /* I/D=01 (Horizontal : increment, Vertical : decrement) */
- /* AM=1 (address is updated in vertical writing direction) */
- LCD_WriteReg(R3, 0x1018);
- LCD_WriteReg(R7, 0x0173); /* 262K color and display ON */
- else if(LCDType == LCD_SPFD5408)
- /* Start Initial Sequence --------------------------------------------------*/
- LCD_WriteReg(R227, 0x3008); /* Set internal timing */
- LCD_WriteReg(R231, 0x0012); /* Set internal timing */
- LCD_WriteReg(R239, 0x1231); /* Set internal timing */
- LCD_WriteReg(R1, 0x0100); /* Set SS and SM bit */
- LCD_WriteReg(R2, 0x0700); /* Set 1 line inversion */
- LCD_WriteReg(R3, 0x1030); /* Set GRAM write direction and BGR=1. */
- LCD_WriteReg(R8, 0x0202); /* Set the back porch and front porch */
- LCD_WriteReg(R9, 0x0000); /* Set non-display area refresh cycle ISC[3:0] */
- /* Power On sequence -------------------------------------------------------*/
- LCD_WriteReg(R17, 0x0007); /* DC1[2:0], DC0[2:0], VC[2:0] */
- LCD_WriteReg(R16, 0x12B0); /* SAP, BT[3:0], AP, DSTB, SLP, STB */
- LCD_WriteReg(R18, 0x01BD); /* External reference voltage= Vci */
- LCD_WriteReg(R19, 0x1400); /* VDV[4:0] for VCOM amplitude */
- LCD_WriteReg(R41, 0x000E); /* VCM[4:0] for VCOMH */
- LCD_WriteReg(R33, 0x013F); /* GRAM Vertical Address */
- /* Adjust the Gamma Curve --------------------------------------------------*/
- LCD_WriteReg(R48, 0x0007);
- LCD_WriteReg(R49, 0x0302);
- LCD_WriteReg(R50, 0x0105);
- LCD_WriteReg(R53, 0x0206);
- LCD_WriteReg(R54, 0x0808);
- LCD_WriteReg(R55, 0x0206);
- LCD_WriteReg(R56, 0x0504);
- LCD_WriteReg(R60, 0x0105);
- LCD_WriteReg(R61, 0x0808);
- /* Set GRAM area -----------------------------------------------------------*/
- LCD_WriteReg(R96, 0xA700); /* Gate Scan Line */
- LCD_WriteReg(R106, 0x0000); /* Set scrolling line */
- /* Partial Display Control -------------------------------------------------*/
- /* Panel Control -----------------------------------------------------------*/
- I/D=01 (Horizontal : increment, Vertical : decrement)
- AM=1 (address is updated in vertical writing direction) */
- LCD_WriteReg(R7, 0x0112); /* 262K color and display ON */
- else if(LCDType == LCD_HX8312)
- /* Enable the LCD Oscillator ---------------------------------------------*/
- LCD_WriteReg(R1, 0x10);
- LCD_WriteReg(R0, 0xA0);
- LCD_WriteReg(R3, 0x01);
- Delay(1); /* Delay 10 ms */
- LCD_WriteReg(R3, 0x00);
- LCD_WriteReg(R43, 0x04);
- LCD_WriteReg(R40, 0x18);
- LCD_WriteReg(R26, 0x05);
- LCD_WriteReg(R37, 0x05);
- LCD_WriteReg(R25, 0x00);
- /* LCD Power On ----------------------------------------------------------*/
- LCD_WriteReg(R28, 0x73);
- LCD_WriteReg(R36, 0x74);
- LCD_WriteReg(R30, 0x01);
- LCD_WriteReg(R24, 0xC1);
- LCD_WriteReg(R24, 0xE1);
- LCD_WriteReg(R24, 0xF1);
- Delay(6); /* Delay 60 ms */
- LCD_WriteReg(R24, 0xF5);
- LCD_WriteReg(R27, 0x09);
- LCD_WriteReg(R31, 0x11);
- LCD_WriteReg(R32, 0x0E);
- LCD_WriteReg(R30, 0x81);
- /* Chip Set --------------------------------------------------------------*/
- LCD_WriteReg(R157, 0x00);
- LCD_WriteReg(R192, 0x00);
- LCD_WriteReg(R14, 0x00);
- LCD_WriteReg(R15, 0x00);
- LCD_WriteReg(R16, 0x00);
- LCD_WriteReg(R17, 0x00);
- LCD_WriteReg(R18, 0x00);
- LCD_WriteReg(R19, 0x00);
- LCD_WriteReg(R20, 0x00);
- LCD_WriteReg(R21, 0x00);
- LCD_WriteReg(R22, 0x00);
- LCD_WriteReg(R23, 0x00);
- LCD_WriteReg(R52, 0x01);
- LCD_WriteReg(R53, 0x00);
- LCD_WriteReg(R75, 0x00);
- LCD_WriteReg(R76, 0x00);
- LCD_WriteReg(R78, 0x00);
- LCD_WriteReg(R79, 0x00);
- LCD_WriteReg(R80, 0x00);
- LCD_WriteReg(R60, 0x00);
- LCD_WriteReg(R61, 0x00);
- LCD_WriteReg(R62, 0x01);
- LCD_WriteReg(R63, 0x3F);
- LCD_WriteReg(R64, 0x02);
- LCD_WriteReg(R65, 0x02);
- LCD_WriteReg(R66, 0x00);
- LCD_WriteReg(R67, 0x00);
- LCD_WriteReg(R68, 0x00);
- LCD_WriteReg(R69, 0x00);
- LCD_WriteReg(R70, 0xEF);
- LCD_WriteReg(R71, 0x00);
- LCD_WriteReg(R72, 0x00);
- LCD_WriteReg(R73, 0x01);
- LCD_WriteReg(R74, 0x3F);
- LCD_WriteReg(R29, 0x08); /* R29:Gate scan direction setting */
- LCD_WriteReg(R134, 0x00);
- LCD_WriteReg(R135, 0x30);
- LCD_WriteReg(R136, 0x02);
- LCD_WriteReg(R137, 0x05);
- LCD_WriteReg(R141, 0x01); /* R141:Register set-up mode for one line clock */
- LCD_WriteReg(R139, 0x20); /* R139:One line SYSCLK number in one-line */
- LCD_WriteReg(R51, 0x01); /* R51:N line inversion setting */
- LCD_WriteReg(R55, 0x01); /* R55:Scanning method setting */
- LCD_WriteReg(R118, 0x00);
- /* Gamma Set -------------------------------------------------------------*/
- LCD_WriteReg(R143, 0x10);
- LCD_WriteReg(R144, 0x67);
- LCD_WriteReg(R145, 0x07);
- LCD_WriteReg(R146, 0x65);
- LCD_WriteReg(R147, 0x07);
- LCD_WriteReg(R148, 0x01);
- LCD_WriteReg(R149, 0x76);
- LCD_WriteReg(R150, 0x56);
- LCD_WriteReg(R151, 0x00);
- LCD_WriteReg(R152, 0x06);
- LCD_WriteReg(R153, 0x03);
- LCD_WriteReg(R154, 0x00);
- /* Display On ------------------------------------------------------------*/
- LCD_WriteReg(R1, 0x50);
- LCD_WriteReg(R5, 0x04);
- LCD_WriteReg(R0, 0x80);
- LCD_WriteReg(R59, 0x01);
- Delay(4); /* Delay 40 ms */
- LCD_WriteReg(R0, 0x20);
- * @brief Initializes the LCD.
- * @param None
- * @retval : None
- void STM3210B_LCD_Init(void)
- /* Setups the LCD */
- LCD_Setup();
- /* Try to read new LCD controller ID 0x9320 */
- if (LCD_ReadReg(R0) == LCD_ILI9320)
- LCDType = LCD_ILI9320;
- else
- LCDType = LCD_SPFD5408;
- LCD_Setup();
- /* Try to read new LCD controller ID 0x5408 */
- if (LCD_ReadReg(R0) != LCD_SPFD5408)
- LCDType = LCD_HX8312;
- LCD_Setup();
- * @brief Sets the Text color.
- * @param Color: specifies the Text color code RGB(5-6-5).
- * and LCD_DrawPicture functions.
- * @retval : None
- void LCD_SetTextColor(__IO uint16_t Color)
- TextColor = Color;
- * @brief Sets the Background color.
- * @param Color: specifies the Background color code RGB(5-6-5).
- * LCD_DrawChar and LCD_DrawPicture functions.
- * @retval : None
- void LCD_SetBackColor(__IO uint16_t Color)
- BackColor = Color;
- * @brief Clears the selected line.
- * @param Line: the Line to be cleared.
- * This parameter can be one of the following values:
- * @arg Linex: where x can be 0..9
- * @retval : None
- void LCD_ClearLine(uint8_t Line)
- LCD_DisplayStringLine(Line, " ");
- * @brief Clears the hole LCD.
- * @param lor: the color of the background.
- * @retval : None
- void LCD_Clear(uint16_t Color)
- uint32_t index = 0;
- LCD_SetCursor(0x00, 0x013F);
- if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
- LCD_WriteRAM_Prepare(); /* Prepare to write GRAM */
- for(index = 0; index < 76800; index++)
- LCD_WriteRAM(Color);
- LCD_CtrlLinesWrite(GPIOB, CtrlPin_NCS, Bit_SET);
- * @brief Sets the cursor position.
- * @param Xpos: specifies the X position.
- * @param Ypos: specifies the Y position.
- * @retval : None
- void LCD_SetCursor(uint8_t Xpos, uint16_t Ypos)
- LCD_WriteReg(R32, Xpos);
- LCD_WriteReg(R33, Ypos);
- LCD_WriteReg(R66, Xpos);
- LCD_WriteReg(R67, ((Ypos & 0x100)>> 8));
- LCD_WriteReg(R68, (Ypos & 0xFF));
- * @brief Draws a character on LCD.
- * @param Xpos: the Line where to display the character shape.
- * @param Linex: where x can be 0..9
- * @param Ypos: start column address.
- * @param c: pointer to the character data.
- * @retval : None
- void LCD_DrawChar(uint8_t Xpos, uint16_t Ypos, const uint16_t *c)
- uint32_t index = 0, i = 0;
- uint8_t Xaddress = 0;
- Xaddress = Xpos;
- LCD_SetCursor(Xaddress, Ypos);
- for(index = 0; index < 24; index++)
- for(i = 0; i < 16; i++)
- if((c[index] & (1 << i)) == 0x00)
- LCD_WriteRAM(BackColor);
- else
- LCD_WriteRAM(TextColor);
- Xaddress++;
- * @brief Displays one character (16dots width, 24dots height).
- * @param Line: the Line where to display the character shape .
- * @param Column: start column address.
- * @param Ascii: character ascii code, must be between 0x20 and 0x7E.
- * @retval : None
- void LCD_DisplayChar(uint8_t Line, uint16_t Column, uint8_t Ascii)
- Ascii -= 32;
- LCD_DrawChar(Line, Column, &ASCII_Table[Ascii * 24]);
- * @brief Displays a maximum of 20 char on the LCD.
- * @param *ptr: pointer to string to display on LCD.
- * @retval : None
- void LCD_DisplayStringLine(uint8_t Line, uint8_t *ptr)
- uint32_t i = 0;
- uint16_t refcolumn = 319;
- /* Send the string character by character on lCD */
- while ((*ptr != 0) & (i < 20))
- /* Display one character on LCD */
- LCD_DisplayChar(Line, refcolumn, *ptr);
- /* Decrement the column position by 16 */
- refcolumn -= 16;
- /* Point on the next character */
- ptr++;
- /* Increment the character counter */
- i++;
- * @brief Sets a display window
- * @param Xpos: specifies the X buttom left position.
- * @param Ypos: specifies the Y buttom left position.
- * @param Height: display window height.
- * @param Width: display window width.
- * @retval : None
- void LCD_SetDisplayWindow(uint8_t Xpos, uint16_t Ypos, uint8_t Height, uint16_t Width)
- /* Horizontal GRAM Start Address */
- if(Xpos >= Height)
- LCD_WriteReg(R80, (Xpos - Height + 1));
- else
- LCD_WriteReg(R80, 0);
- /* Horizontal GRAM End Address */
- LCD_WriteReg(R81, Xpos);
- /* Vertical GRAM Start Address */
- if(Ypos >= Width)
- LCD_WriteReg(R82, (Ypos - Width + 1));
- else
- LCD_WriteReg(R82, 0);
- /* Vertical GRAM End Address */
- LCD_WriteReg(R83, Ypos);
- LCD_WriteReg(R1, 0xD0);
- LCD_WriteReg(R5, 0x14);
- LCD_WriteReg(R69, (Xpos - Height + 1));
- LCD_WriteReg(R70, Xpos);
- LCD_WriteReg(R71, (((Ypos - Width + 1) & 0x100)>> 8));
- LCD_WriteReg(R72, ((Ypos - Width + 1) & 0xFF));
- LCD_WriteReg(R73, ((Ypos & 0x100)>> 8));
- LCD_WriteReg(R74, (Ypos & 0xFF));
- LCD_SetCursor(Xpos, Ypos);
- * @brief Disables LCD Window mode.
- * @param None
- * @retval : None
- void LCD_WindowModeDisable(void)
- LCD_SetDisplayWindow(239, 0x13F, 240, 320);
- * @brief Displays a line.
- * @param Length: line length.
- * @param Direction: line direction.
- * This parameter can be one of the following values: Vertical
- * or Horizontal.
- * @retval : None
- void LCD_DrawLine(uint8_t Xpos, uint16_t Ypos, uint16_t Length, uint8_t Direction)
- uint32_t i = 0;
- if(Direction == Horizontal)
- for(i = 0; i < Length; i++)
- else
- LCD_WriteRAMWord(TextColor);
- Xpos++;
- * @brief Displays a rectangle.
- * @param Height: display rectangle height.
- * @param Width: display rectangle width.
- * @retval : None
- void LCD_DrawRect(uint8_t Xpos, uint16_t Ypos, uint8_t Height, uint16_t Width)
- LCD_DrawLine(Xpos, Ypos, Width, Horizontal);
- LCD_DrawLine((Xpos + Height), Ypos, Width, Horizontal);
- LCD_DrawLine(Xpos, Ypos, Height, Vertical);
- LCD_DrawLine(Xpos, (Ypos - Width + 1), Height, Vertical);
- * @brief Displays a circle.
- * @retval : None
- void LCD_DrawCircle(uint8_t Xpos, uint16_t Ypos, uint16_t Radius)
- int32_t D;/* Decision Variable */
- uint32_t CurX;/* Current X Value */
- uint32_t CurY;/* Current Y Value */
- D = 3 - (Radius << 1);
- CurX = 0;
- CurY = Radius;
- while (CurX <= CurY)
- LCD_SetCursor(Xpos + CurX, Ypos + CurY);
- LCD_SetCursor(Xpos + CurX, Ypos - CurY);
- LCD_SetCursor(Xpos - CurX, Ypos + CurY);
- LCD_SetCursor(Xpos - CurX, Ypos - CurY);
- LCD_SetCursor(Xpos + CurY, Ypos + CurX);
- LCD_SetCursor(Xpos + CurY, Ypos - CurX);
- LCD_SetCursor(Xpos - CurY, Ypos + CurX);
- LCD_SetCursor(Xpos - CurY, Ypos - CurX);
- if (D < 0)
- D += (CurX << 2) + 6;
- else
- D += ((CurX - CurY) << 2) + 10;
- CurY--;
- CurX++;
- * @brief Displays a monocolor picture.
- * @param Pict: pointer to the picture array.
- * @retval : None
- void LCD_DrawMonoPict(const uint32_t *Pict)
- LCD_SetCursor(0, 319);
- for(index = 0; index < 2400; index++)
- for(i = 0; i < 32; i++)
- if((Pict[index] & (1 << i)) == 0x00)
- else
- * @brief Reset LCD control line(/CS) and Send Start-Byte
- * @param Start_Byte: the Start-Byte to be sent
- * @retval : None
- void LCD_nCS_StartByte(uint8_t Start_Byte)
- LCD_CtrlLinesWrite(GPIOB, CtrlPin_NCS, Bit_RESET);
- SPI_I2S_SendData(SPI2, Start_Byte);
- while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_BSY) != RESET)
- * @brief Writes index to select the LCD register.
- * @param LCD_Reg: address of the selected register.
- * @retval : None
- void LCD_WriteRegIndex(uint8_t LCD_Reg)
- /* Reset LCD control line(/CS) and Send Start-Byte */
- LCD_nCS_StartByte(START_BYTE | SET_INDEX);
- /* Write 16-bit Reg Index (High Byte is 0) */
- SPI_I2S_SendData(SPI2, 0x00);
- SPI_I2S_SendData(SPI2, LCD_Reg);
- * @brief Writes to the selected LCD ILI9320 register.
- * @arg LCD_RegValue: value to write to the selected register.
- * @retval : None
- /* Write 16-bit Index (then Write Reg) */
- LCD_WriteRegIndex(LCD_Reg);
- /* Write 16-bit Reg */
- LCD_nCS_StartByte(START_BYTE | LCD_WRITE_REG);
- SPI_I2S_SendData(SPI2, LCD_RegValue>>8);
- SPI_I2S_SendData(SPI2, (LCD_RegValue & 0xFF));
- * @brief Reads the selected LCD Register.
- * @param None
- * @retval : LCD Register Value.
- uint16_t LCD_ReadReg(uint8_t LCD_Reg)
- uint16_t tmp = 0;
- uint8_t i = 0;
- /* SPI2 prescaler: 4 */
- SPI2->CR1 &= 0xFFC7;
- SPI2->CR1 |= 0x0008;
- /* Write 16-bit Index (then Read Reg) */
- /* Read 16-bit Reg */
- LCD_nCS_StartByte(START_BYTE | LCD_READ_REG);
- for(i = 0; i < 5; i++)
- SPI_I2S_SendData(SPI2, 0xFF);
- /* One byte of invalid dummy data read after the start byte */
- while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET)
- SPI_I2S_ReceiveData(SPI2);
- /* Read upper byte */
- /* Read lower byte */
- tmp = SPI_I2S_ReceiveData(SPI2);
- tmp = ((tmp & 0xFF) << 8) | SPI_I2S_ReceiveData(SPI2);
- /* SPI2 prescaler: 2 */
- return tmp;
- * @brief Prepare to write to the LCD RAM.
- * @param None
- * @retval : None
- void LCD_WriteRAM_Prepare(void)
- LCD_WriteRegIndex(R34); /* Select GRAM Reg */
- * @brief Writes 1 word to the LCD RAM.
- * @param RGB_Code: the pixel color in RGB mode (5-6-5).
- * @retval : None
- void LCD_WriteRAMWord(uint16_t RGB_Code)
- LCD_WriteRAM(RGB_Code);
- * @brief Writes to the selected LCD HX8312 register.
- * @retval : None
- uint16_t tmp = 0;
- LCD_CtrlLinesWrite(GPIOD, CtrlPin_NWR, Bit_RESET);
- LCD_CtrlLinesWrite(GPIOD, CtrlPin_RS, Bit_RESET);
- tmp = LCD_Reg << 8;
- tmp |= LCD_RegValue;
- SPI_I2S_SendData(SPI2, tmp);
- * @brief Writes to the selected LCD register.
- * @retval : None
- void LCD_WriteReg(uint8_t LCD_Reg, uint16_t LCD_RegValue)
- LCD_WriteRegILI9320(LCD_Reg, LCD_RegValue);
- LCD_WriteRegHX8312(LCD_Reg, ((uint8_t)LCD_RegValue));
- * @brief Writes to the LCD RAM.
- * @retval : None
- void LCD_WriteRAM(uint16_t RGB_Code)
- SPI_I2S_SendData(SPI2, RGB_Code >> 8);
- SPI_I2S_SendData(SPI2, RGB_Code & 0xFF);
- if(LCDType == LCD_HX8312)
- LCD_CtrlLinesWrite(GPIOD, CtrlPin_RS, Bit_SET);
- SPI_I2S_SendData(SPI2, RGB_Code);
- * @brief Power on the LCD.
- * @param None
- * @retval : None
- void LCD_PowerOn(void)
- /* Power On sequence ---------------------------------------------------------*/
- Delay(5); /* delay 50 ms */
- /* Power On Set */
- * @brief Enables the Display.
- * @param None
- * @retval : None
- void LCD_DisplayOn(void)
- /* Display On */
- /* Display On */
- * @brief Disables the Display.
- * @param None
- * @retval : None
- void LCD_DisplayOff(void)
- /* Display Off */
- LCD_WriteReg(R7, 0x0);
- /* Display Off */
- LCD_WriteReg(R59, 0x00);
- * @brief Configures LCD control lines in Output Push-Pull mode.
- * @param None
- * @retval : None
- void LCD_CtrlLinesConfig(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- /* Configure NCS (PB.02) in Output Push-Pull mode */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- /* Configure NWR(RNW), RS (PD.15, PD.07) in Output Push-Pull mode */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_15;
- GPIO_Init(GPIOD, &GPIO_InitStructure);
- LCD_CtrlLinesWrite(GPIOD, CtrlPin_NWR, Bit_SET);
- * @brief Sets or reset LCD control lines.
- * @param GPIOx: where x can be B or D to select the GPIO peripheral.
- * @param CtrlPins: the Control line. This parameter can be:
- * @param CtrlPin_NCS: Chip Select pin (PB.02)
- * @param CtrlPin_NWR: Read/Write Selection pin (PD.15)
- * @param CtrlPin_RS: Register/RAM Selection pin (PD.07)
- * @param BitVal: specifies the value to be written to the selected bit.
- * This parameter can be:
- * @param Bit_RESET: to clear the port pin
- * @param Bit_SET: to set the port pin
- * @retval : None
- void LCD_CtrlLinesWrite(GPIO_TypeDef* GPIOx, uint16_t CtrlPins, BitAction BitVal)
- /* Set or Reset the control line */
- GPIO_WriteBit(GPIOx, CtrlPins, BitVal);
- * @brief Configures the SPI2 interface.
- * @param None
- * @retval : None
- void LCD_SPIConfig(void)
- SPI_InitTypeDef SPI_InitStructure;
- /* Enable GPIOB clock */
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
- /* Enable SPI2 clock */
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
- /* Configure SPI2 pins: NSS, SCK, MISO and MOSI */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
- SPI_I2S_DeInit(SPI2);
- /* SPI2 Config */
- SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
- SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
- SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
- SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
- SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
- SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b;
- SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
- SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
- SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
- SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2;
- SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
- SPI_Init(SPI2, &SPI_InitStructure);
- /* SPI2 enable */
- SPI_Cmd(SPI2, ENABLE);
- /******************* (C) COPYRIGHT 2009 STMicroelectronics *****END OF FILE****/
