下面是我的程序:
#include<reg52.h>
#include<absacc.h>
#include<intrins.h>
#define ADC0809 XBYTE[0xFBF8]
/* 12864端口定義*/
#define LCD_data P0 //帶字庫液晶12864數(shù)據(jù)口
sbit LCD_RS = P2^3; //寄存器選擇輸入
sbit LCD_RW = P2^7; //液晶讀/寫控制
sbit LCD_EN = P2^6; //液晶使能控制
sbit PSB=P2^5; //并口控制
sbit RES=P2^4;
sbit R=P1^7;
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
bit lcd_busy()
bit result;
LCD_RS = 0;
LCD_RW = 1;
LCD_EN = 1;
_nop_();
_nop_();
result = (bit)(P0&0x80);
LCD_EN = 0;
return(result);
/*寫指令數(shù)據(jù)到LCD */
/*RS=L,RW=L,E=高脈沖,D0-D7=指令碼。 */
void lcd_wcmd(uchar cmd)
while(lcd_busy());
LCD_RS = 0;
LCD_RW = 0;
LCD_EN = 0;
_nop_();
_nop_();
P0 = cmd;
delay(1);
LCD_EN = 1;
delay(1);
LCD_EN = 0;
/*寫顯示數(shù)據(jù)到LCD */
/*RS=H,RW=L,E=高脈沖,D0-D7=數(shù)據(jù)。 */
void lcd_wdat(uchar dat)
while(lcd_busy());
LCD_RS = 1;
LCD_RW = 0;
LCD_EN = 0;
P0 = dat;
_nop_();
_nop_();
LCD_EN = 1;
delay(1);
LCD_EN = 0;
/* LCD初始化設(shè)定 */
void lcd_init()
P0=0xFF;
delay(40);
PSB=1; //并口方式。
delay(1);
RES=0;
delay(1);
RES=1;
lcd_wcmd(0x30);
lcd_wcmd(0x30);
lcd_wcmd(0x08);
lcd_wcmd(0x10);
lcd_wcmd(0x0C); //顯示開,關(guān)光標(biāo)
lcd_wcmd(0x01); //清除LCD的顯示內(nèi)容
lcd_wcmd(0x06);
delay(100);
LCD_EN = 0;
/* 設(shè)定顯示位置 */
void lcd_pos(uchar X,uchar Y)
uchar pos;
if (X==0)
{X=0x80;}
else if (X==1)
{X=0x90;}
else if (X==2)
{X=0x88;}
else if (X==3)
{X=0x98;}
pos = X+Y ;
lcd_wcmd(pos); //顯示地址
uint adc_data;
int disi,disan,dier,diyi;
lcd_init();
uchar i;
R=0; //蜂鳴器
ADC0809=i;
delay(1000);
adc_data=ADC0809;
adc_data=adc_data*19.61;
disi=adc_data/1000;
disan=(adc_data%1000)/100;
dier=(adc_data%1000%100)/10;
diyi=adc_data%1000%100%10;
delay(10000);
delay(10000);
delay(1000);
lcd_pos(0,0);
lcd_wdat(disi+0x30);
lcd_wdat(disan+0x30);
lcd_wdat(dier+0x30);
lcd_wdat(diyi+0x30);
求大神指點(diǎn)!謝謝啦~~ |
