查看: 9846|回復(fù): 2
STM8S103的三路PWM波形(官方的示例程序備忘)
ID:75263 發(fā)表于 2015-6-9 02:48 | 顯示全部樓層 |閱讀模式
STM8S物美價廉,TIM2可同時產(chǎn)生三路PWM波形來,最快可達(dá)5MHZ
#include "stm8s.h"
uint16_t CCR1_Val = 500;
uint16_t CCR2_Val = 250;
uint16_t CCR3_Val = 100;
static void TIM2_Config(void);
void main(void)
{CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);//16/1=16MHZ
  TIM2_Config();
  while (1)
  TIM2_TimeBaseInit(TIM2_PRESCALER_1, 200);
  TIM2_OC1Init(TIM2_OCMODE_PWM1,TIM2_OUTPUTSTATE_ENABLE,CCR1_Val, TIM2_OCPOLARITY_HIGH);
  TIM2_OC1PreloadConfig(ENABLE);
  TIM2_OC2Init(TIM2_OCMODE_PWM1,TIM2_OUTPUTSTATE_ENABLE,CCR2_Val, TIM2_OCPOLARITY_HIGH);
  TIM2_OC2PreloadConfig(ENABLE);
  TIM2_OC3Init(TIM2_OCMODE_PWM1,TIM2_OUTPUTSTATE_ENABLE,CCR3_Val, TIM2_OCPOLARITY_HIGH);
  TIM2_OC3PreloadConfig(ENABLE);
  TIM2_ARRPreloadConfig(ENABLE);
  TIM2_Cmd(ENABLE);
#ifdef USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
  while (1)
#endif
ID:169756 發(fā)表于 2017-5-31 07:43 | 顯示全部樓層
學(xué)習(xí)了,謝謝樓主!
ID:337139 發(fā)表于 2020-11-6 22:20 | 顯示全部樓層
官方函數(shù)庫寫出來就完美了。
