查看: 4978|回復(fù): 7
16*16點(diǎn)陣求問(wèn) if(j==(17*15))是什么意思?為什么我的只能循環(huán)一次,下一次就是亂碼了
ID:75829 發(fā)表于 2015-6-10 11:58 | 顯示全部樓層 |閱讀模式
#include <REG51.H>
//--重定義函數(shù)變量--//
#define uint  unsigned int
#define ulong unsigned long
//--定義SPI要使用的 IO--//
sbit MOSIO = P3^4;
sbit R_CLK = P3^5;
sbit S_CLK = P3^6;
unsigned char code tab17[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
unsigned char code tab0[] = {0x00, 0x01, 0x00, 0x02, 0x00, 0x04, 0x00, 0x08, 0x00, 0x10, 0x00, 0x20, 0x00, 0x40, 0x00, 0x80,         /*行掃描*/
                             0x01, 0x00, 0x02, 0x00, 0x04, 0x00, 0x08, 0x00, 0x10, 0x00, 0x20, 0x00, 0x40, 0x00, 0x80, 0x00};
unsigned char code tab1[] = {96,2,28,10,16,18,16,2,254,63,16,2,16,18,112,18,24,10,22,10,16,36,16,42,16,49,156,32,0,0,0,0};          /*我*/
unsigned char code tab2[] = {0,14,252,1,72,8,144,4,254,63,2,16,33,8,252,31,32,0,224,7,80,2,136,1,68,2,58,28,0,0,0,0};                  /*愛(ài)*/
unsigned char code tab3[] = {144,0,144,0,208,63,72,32,40,16,12,2,10,2,136,10,136,18,72,18,72,34,40,34,8,2,136,3,0,0,0,0};           /*你*/
unsigned char code tab15[] = {0,0,0,0,60,240,102,156,67,130,0,0,0,0,0,0,0,0,0,0,48,24,96,8,192,7,0,0,0,0,0,0};                                  /*笑臉*/
unsigned char code tab16[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
//--全局函數(shù)聲明--//
void HC595SendData(  uchar BT3, uchar BT2,uchar BT1,uchar BT0);
* 函 數(shù) 名         : main
* 函數(shù)功能                   : 主函數(shù)
* 輸    入         : 無(wú)
* 輸    出         : 無(wú)
void main(void)
   int k, ms,j;
   //--定義一個(gè)指針數(shù)據(jù)指向漢字--//
   uchar *p[] = {  tab1, tab2, tab3, tab15 ,tab16};
                        for(ms = 20; ms > 0; ms--)        //顯示50次,即肉眼可識(shí)別的停留時(shí)間
                                for(k = 0; k < 16; k++)                        //顯示一個(gè)字
                                        //--因?yàn)樽帜\浖〉臄?shù)組是高電平有效,所以列要取反--//
                                        HC595SendData(~(*(p[0] + 2*(k+j) + 1)),~(*(p[0] + 2*(k+j) )),
                                                       tab0[2*k],tab0[2*k + 1]);
                                HC595SendData(0xff,0xff,0,0);                                //清屏
                                  j++;
                        if(j==(17*15))
                        j=0;
* 函 數(shù) 名         : HC595SendData
* 函數(shù)功能                   : 通過(guò)595發(fā)送四個(gè)字節(jié)的數(shù)據(jù)
* 輸    入         : BT3:第四個(gè)595輸出數(shù)值
*                  * BT2: 第三個(gè)595輸出數(shù)值
*                  * BT1:第二個(gè)595輸出數(shù)值
*                  * BT0:第一個(gè)595輸出數(shù)值
* 輸    出         : 無(wú)
        uchar i;
        //--發(fā)送第一個(gè)字節(jié)--//
        for(i=0;i<8;i++)
                MOSIO = BT3 >> 7 ;        //從高位到低位
                BT3 <<= 1;
                S_CLK = 0;
                S_CLK = 1;
        for(i=0;i<8;i++)
                MOSIO = BT2 >>7;                //從高位到低位
                BT2 <<= 1;
                S_CLK = 0;
                S_CLK = 1;
        for(i=0;i<8;i++)
                MOSIO = BT1 >> 7;                //從高位到低位
                BT1 <<= 1;
                S_CLK = 0;
                S_CLK = 1;
        for(i=0;i<8;i++)
                MOSIO = BT0 >> 7;                //從高位到低位
                BT0 <<= 1;
                S_CLK = 0;
                S_CLK = 1;
        //--輸出--//
        R_CLK = 0; //set dataline low
        R_CLK = 1; //片選
請(qǐng)問(wèn)if(j==(17*15))是什么意思?為什么我的只能循環(huán)一次,下一次就是亂碼了?
ID:76927 發(fā)表于 2015-6-10 14:04 | 顯示全部樓層
很好很好
ID:77578 發(fā)表于 2015-6-11 00:13 來(lái)自手機(jī) | 顯示全部樓層
j是計(jì)數(shù)程序運(yùn)行了多少次吧,應(yīng)該是這個(gè)程序要運(yùn)行17*15次,運(yùn)行過(guò)了就清零,重新運(yùn)行
參與人數(shù) 1黑幣 +35 收起 理由
admin + 35 回帖助人的獎(jiǎng)勵(lì)!
ID:75829 發(fā)表于 2015-6-12 15:26 | 顯示全部樓層
moyuqilin 發(fā)表于 2015-6-11 00:13
那請(qǐng)問(wèn)17和15到底什么意思呢?
ID:82323 發(fā)表于 2015-6-13 14:16 來(lái)自手機(jī) | 顯示全部樓層
if(j==255)  判斷真假 如果等于  就執(zhí)行下一條語(yǔ)句
ID:84147 發(fā)表于 2015-7-4 10:50 | 顯示全部樓層
還是先去了解if的作用
ID:78889 發(fā)表于 2021-9-25 16:06 | 顯示全部樓層
應(yīng)該是查詢的地址為一個(gè)字節(jié)吧
ID:78889 發(fā)表于 2021-9-26 03:18 | 顯示全部樓層
qq4612519 發(fā)表于 2021-9-25 16:06
16*16的點(diǎn)陣,字模的大小為32個(gè)字節(jié),32*8=256位,完成一次字模的移動(dòng),
