本帖最后由 xuwei 于 2015-6-14 01:23 編輯
做攝像頭快一個(gè)半月了,今天終于有了重大的進(jìn)展,終于把圖像搞出來(lái)了,可是圖像是發(fā)白,模糊,我初步估計(jì)是數(shù)據(jù)lost ,所以還要繼續(xù)努力!
加油吧
江蘇無(wú)錫市第五項(xiàng)目部臨時(shí)工棚
主程序
- /* Includes ------------------------------------------------------------------*/
- #include "main.h"
- /*記住自己做完頭文件別忘了在左上角的品字形圖標(biāo)的C/C++里設(shè)置一下include選項(xiàng)奧,負(fù)責(zé)要出錯(cuò)的*/
- GPIO_InitTypeDef GPIO_InitStructure;
- int main(void)
- uint32_t numb;
- uint16_t date1,date2;
- init_STM32(); //開(kāi)機(jī)初始化
- // my_send_byte(0x00); //發(fā)送一個(gè)字節(jié)
- //my_send_byte(0x01); //發(fā)送一個(gè)字節(jié)
- //my_send_byte(0x02); //發(fā)送一個(gè)字節(jié)
- //my_send_byte(0x03); //發(fā)送一個(gè)字節(jié)
- CLK_init_ON();//開(kāi)啟PA8的輸出時(shí)鐘8MHZ
- LCD9328_init();//9328初始化
- SCCB_IIC_INIT();//IIC初始化函數(shù)
- delay1ms(20);
- init_OV7670_POWER_UP();//0V7670的初始化寄存器設(shè)置
- delay1ms(10);
- // wrOV7670Reg(0x40, 0xd0);
- write_ov7670_sccb_twi(0x17, 0x16);
- write_ov7670_sccb_twi(0x18, 0x04);
- write_ov7670_sccb_twi(0x19, 0x02);
- write_ov7670_sccb_twi(0x1A, 0x7B);
- write_ov7670_sccb_twi(0x32, 0x40);
- write_ov7670_sccb_twi(0x03, 0x0a);
- // wrOV7670Reg(0x3E, 0x1A);
- write_ov7670_sccb_twi(0x70, 0x3A);
- write_ov7670_sccb_twi(0x71, 0x35);
- write_ov7670_sccb_twi(0x72, 0x11);
- write_ov7670_sccb_twi(0x73, 0xF9);
- write_ov7670_sccb_twi(0xA2, 0x02);
- delay1ms(10);
- CLR_CS;
- CLR_RS;
- SET_RD;
- CLR_WR;
- GPIOE->ODR=0x0022;//GPIO_Write(GPIOE, reg);// //寫(xiě)入命令
- SET_WR;
- SET_RS;
- SET_FIFO_WE;
- CLR_FIFO_WRST; //復(fù)位寫(xiě)地址為0
- delay1us(40);
- SET_FIFO_WRST;//初始化完畢,將從0地址開(kāi)始
- CLR_FIFO_WE;//關(guān)閉寫(xiě)FIFO使能
- CLR_FIFO_CS;//使能讀
- CLR_FIFO_RD; //RCK時(shí)鐘拉低
- CLR_FIFO_RRST; //度地址復(fù)位
- SET_FIFO_RD;//RCK拉高
- CLR_FIFO_RD; //RCK拉低
- SET_FIFO_RD; //RCK拉高
- CLR_FIFO_RD;
- CLR_FIFO_RD;
- CLR_FIFO_RD;
- delay1us(2);
- SET_FIFO_RRST; //拉高復(fù)位結(jié)束
- //SET_FIFO_CS;//關(guān)閉能讀
- // SET_FIFO_WE;//開(kāi)啟寫(xiě)FIFO使能
- my_EXTI_int();//外部中斷初始化
- while(1)
- if(vsync_counter==2)
- EXTI->IMR=0;
- NVIC->ISER[0]=0;
- for(numb=76800;numb;numb--)
- CLR_FIFO_RD;
- SET_FIFO_RD;
- date1=GPIOA->IDR;
- date1<<=8;
- CLR_FIFO_RD;
- SET_FIFO_RD;
- date2=GPIOA->IDR;
- GPIOE->ODR=((date1&0xff00)|(date2&0x00ff));
- CLR_WR;
- SET_WR;
- CLR_FIFO_RRST; //讀指針復(fù)位
- CLR_FIFO_RD;
- SET_FIFO_RD;
- CLR_FIFO_RD;
- SET_FIFO_RD;
- SET_FIFO_RRST;
- CLR_FIFO_WRST;
- delay1us(2);
- SET_FIFO_WRST;
- vsync_counter = 0;
- EXTI->IMR=0x00000001;
- NVIC->ISER[0]=0x00000040;
- void init_STM32()
- delay1ms(10000);
- mysysinit();
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);//使能GPIOA時(shí)鐘
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);//使能GPIOB時(shí)鐘
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);//使能GPIOC時(shí)鐘
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);//使能GPIOD時(shí)鐘
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE, ENABLE);//使能GPIOE時(shí)鐘
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);//使能AFIO復(fù)用時(shí)鐘
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);//使能USART1時(shí)鐘
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,ENABLE); //使能IIC1時(shí)鐘
- /* LED8-11設(shè)置為指示燈,設(shè)置為輸出推挽 */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9|GPIO_Pin_10 | GPIO_Pin_11;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(GPIOD, &GPIO_InitStructure);
- /* 設(shè)置IIC總線的 PB10 and PB11 in 開(kāi)樓復(fù)用輸出 mode */ //I2C的兩條總線
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- /* 設(shè)置PD口用于控制LCD的控制總線 */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12 | GPIO_Pin_13| GPIO_Pin_14| GPIO_Pin_15;
- /* 設(shè)置PE口用于控制LCD的為輸出 */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1| GPIO_Pin_2| GPIO_Pin_3| GPIO_Pin_4|
- GPIO_Pin_5 | GPIO_Pin_6| GPIO_Pin_7| GPIO_Pin_8| GPIO_Pin_9|
- GPIO_Pin_10 | GPIO_Pin_11| GPIO_Pin_12| GPIO_Pin_13| GPIO_Pin_14|
- GPIO_Pin_15 ;
- GPIO_Init(GPIOE, &GPIO_InitStructure);
- /* 設(shè)置PA口的低8位用于控制7670的數(shù)據(jù)輸出 */
- GPIO_Pin_5 | GPIO_Pin_6| GPIO_Pin_7;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- /* 422B的操作設(shè)置,設(shè)置為輸出推挽 */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15 | GPIO_Pin_14|GPIO_Pin_13 | GPIO_Pin_12| GPIO_Pin_11;
- /*串口初始化*/
- //my_USART_init();
- void mysysinit()//系統(tǒng)初始化程序
- ErrorStatus HSEStartUpStatus;//說(shuō)明標(biāo)志位
- RCC_DeInit();//所有外設(shè)全部缺省設(shè)置
- /* Enable HSE */
- RCC_HSEConfig(RCC_HSE_ON);
- /* Wait till HSE is ready and if Time out is reached exit */
- HSEStartUpStatus = RCC_WaitForHSEStartUp();
- if(HSEStartUpStatus == SUCCESS)//啟動(dòng)成功
- /*這兩條FLASH指令必須加上,不知為啥?不加上就運(yùn)行幾秒后出錯(cuò),參照系統(tǒng)初始化*/
- /* Enable The Prefetch Buffer */
- FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);//FLASH緩存開(kāi)啟
- /* Configure the Latency cycle: Set 2 Latency cycles */
- FLASH_SetLatency(FLASH_Latency_2); //設(shè)置FLASH這些位表示SYSCLK(系統(tǒng)時(shí)鐘)周期與閃存訪問(wèn)時(shí)間的比例,為010:兩個(gè)等待狀態(tài),當(dāng) 48MHz < SYSCLK ≤ 72MHz
- /* Set PLL clock output to 72MHz using HSE (8MHz) as entry clock */
- RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);//外部時(shí)鐘為8M,PLL的輸入時(shí)鐘=8MHZ,倍頻系數(shù)9,
- /* Configure HCLK such as HCLK = SYSCLK */
- RCC_HCLKConfig(RCC_SYSCLK_Div1);//設(shè)置了啦AHB分頻器的分頻系數(shù)=1,即HCLK=SYSCLK=72MHZ
- /* Configure PCLK1 such as PCLK1 = HCLK/2 */
- RCC_PCLK1Config(RCC_HCLK_Div2);//設(shè)置了APB1外設(shè)的時(shí)鐘頻率最大是36M這里是APB1的分頻器設(shè)為2,PCLK1=HCLK/2=72/2=36MHZ正好是最大值
- /* Configure PCLK2 such as PCLK2 = HCLK */
- RCC_PCLK2Config(RCC_HCLK_Div1);//設(shè)置PLCK2=HCLK=72MHZ,的APB2分頻器=1
- /* Select the PLL as system clock source */
- RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//設(shè)置了SYSCLK的提供者為PLL,頻率由上面算出=72MHZ
- /* disable PLL Ready interrupt */
- RCC_ITConfig(RCC_IT_PLLRDY, DISABLE);//PLL中斷關(guān)閉
- RCC_ITConfig(RCC_IT_HSERDY,DISABLE);//HSE中斷關(guān)閉
- RCC_ITConfig(RCC_IT_HSIRDY, DISABLE); //HSI中斷關(guān)閉
- RCC_ITConfig(RCC_IT_LSERDY, DISABLE); //LSE中斷關(guān)閉
- RCC_ITConfig(RCC_IT_LSIRDY, DISABLE); //LSI中斷關(guān)閉
- /* PLL clock divided by 1.5 used as USB clock source */
- RCC_USBCLKConfig(RCC_USBCLKSource_PLLCLK_1Div5);//設(shè)置USB的時(shí)鐘為=72、1.5=48mhz
- /* Configure ADCCLK such as ADCCLK = PCLK2/2 */
- RCC_ADCCLKConfig(RCC_PCLK2_Div2);//設(shè)置ADC時(shí)鐘=PCLK2/2= 36MHZ
- /* disable the LSE */
- RCC_LSEConfig(RCC_LSE_OFF);//外部低速晶振關(guān)閉
- /*DISable the RTC clock */
- RCC_RTCCLKCmd(DISABLE);
- /* DISable the Clock Security System */
- RCC_ClockSecuritySystemCmd(DISABLE);
- /* Enable the PLL */
- RCC_PLLCmd(ENABLE);//使能PLL
- /* PLL ans system clock config */
- else
- /* Add here some code to deal with this error */
- 中斷程序
- #include "stm32f10x_it.h"
- uint8_t vsync_counter=0;
- void EXTI0_IRQHandler(void)//場(chǎng)中斷 PC0
- { EXTI->PR|=0x00000001;
- // EXTI->IMR=0;
- vsync_counter++;
- if(2==vsync_counter)
- CLR_FIFO_CS;//使能讀
- CLR_FIFO_WE;//禁止寫(xiě)入FIFO數(shù)據(jù)
- else
- {SET_FIFO_WE;//開(kāi)啟寫(xiě)FIFO使能
- //EXTI->IMR=0x00000001;
- 7670程序
- void init_OV7670_POWER_UP()//0V7670的初始化寄存器設(shè)置
- uint16_t i;
- for(i=0;i<176;i++)
- write_ov7670_sccb_twi(change_reg[i][0],change_reg[i][1]);
- /*PA8的MCO時(shí)鐘輸出為關(guān)閉,切換到普通IO*/
- void CLK_init_OFF(void)
- //時(shí)鐘的輸出txz
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
- RCC->CFGR&=0xf8ffffff;//RCC_MCOConfig(RCC_MCO_HSE );//hsi
- void write_ov7670_sccb_twi(uint8_t add,uint8_t date)
- { uint8_t a;
- delay1ms(500);
- I2C1->CR1=1;//開(kāi)啟IIC
- //my_send_byte(0x80);
- I2C1->CR1=0x0101;//發(fā)送起始位
- while(1)
- { a=I2C1->SR1;
- a=(a&0x0001);
- delay1ms(1);
- //my_send_byte(0x11);
- if(a==0x0001)
- break;
- }//EV5是向下
- I2C1->DR=0x42;//寫(xiě)入地址
- delay1ms(10);
- while(1)
- { a=I2C1->SR1;
- a=(a&0x0002);
- delay1ms(1);
- // my_send_byte(0x22);
- if(a==0x0002)
- break;
- }//EV6ADDR發(fā)送?是向下,否等待
- a=I2C1->SR1;
- a=I2C1->SR2;
- //my_send_byte((I2C1->SR1));
- //my_send_byte((I2C1->SR2)); //必須讀SR1
- I2C1->DR=add;//寫(xiě)入寄存地址
- while(1)
- { a=I2C1->SR1;
- a=(a&0x0080);
- delay1ms(1);
- //my_send_byte(0x33);
- if(a==0x0080)
- break;
- }//EV8寄存器為空?是向下,否等待
- a=I2C1->SR1;
- a=I2C1->SR2;
- I2C1->DR=date;//寫(xiě)數(shù)據(jù)
- while(1)
- { a=I2C1->SR1;
- a=(a&0x0080);
- delay1ms(1);
- // my_send_byte(0x44);
- if(a==0x0080)
- break;
- delay1ms(1);
- while(1)
- {a=I2C1->SR1;
- a=(a&0x0084);
- delay1ms(1);
- // my_send_byte(0x55);
- if(a==0x0084)
- break;
- }//EV8-2發(fā)送完成,寄存器為空?是向下,否等待
- I2C1->CR1=0x0201;//STOP
- SCCB底層操作函數(shù)利用硬件模塊IIC讀取一個(gè)指定地址的數(shù)據(jù)
- 返回值:為讀取的數(shù)據(jù)
- 形參:為將要讀取的寄存器地址
- *****************************8*/
- uint8_t SCCB_IIC_READ(uint8_t add)//讀一個(gè)字節(jié)數(shù)據(jù)
- uint8_t date;
- uint16_t a;
- delay1ms(3000);
- while(1)
- { a=I2C1->SR1;
- a=(a&0x0001);
- delay1ms(2);
- // my_send_byte(0x11);
- if(a==0x0001)
- break;
- }//EV5是向下
- delay1ms(10);
- while(1)
- { a=I2C1->SR1;
- a=(a&0x0002);
- delay1ms(1);
- if(a==0x0002)
- break;
- a=I2C1->SR1;
- a=I2C1->SR2;
- while(1)
- { a=I2C1->SR1;
- a=(a&0x0080);
- delay1ms(1);
- // my_send_byte(0x33);
- if(a==0x0080)
- break;
- delay1ms(1);
- while(1)
- {a=I2C1->SR1;
- a=(a&0x0084);
- delay1ms(1);
- if(a==0x0084)
- break;
- //delay(1000000);
- ///delay(10000);
- delay1ms(10);
- //my_send_byte(0x88);
- while(1)
- { a=I2C1->SR1;
- a=(a&0x0001);
- delay1ms(2);
- //my_send_byte(0x55);
- if(a==0x0001)
- break;
- }//EV5是向下
- I2C1->DR=0x43;//寫(xiě)入地址
- delay1ms(1);
- while(1)
- { a=I2C1->SR1;
- a=(a&0x0002);
- delay1ms(1);
- // my_send_byte(0x66);
- if(a==0x0002)
- break;
- a=I2C1->SR1;
- a=I2C1->SR2;
- delay1ms(1);
- // my_send_byte(I2C1->SR1);
- // my_send_byte(I2C1->SR2);
- while(1)
- { a=I2C1->SR1;
- a=(a&0x0040);
- delay1ms(1);
- //my_send_byte(0x77);
- if(a==0x0040)
- break;
- }//EV7ARXEN發(fā)送?是向下,否等待
- date=I2C1->DR;
- return date;
- void SCCB_IIC_INIT()//IIC初始化函數(shù)
- delay1ms(5000);
- I2C1->CR1=0;//關(guān)閉I2C
- I2C1->CR2=2;//IIC的時(shí)鐘源設(shè)為8MHZ,但是這不是總線上的時(shí)鐘,他是由CCR1,分頻后作為SCL時(shí)鐘 的,見(jiàn)手冊(cè),
- I2C1->CCR=400;//標(biāo)準(zhǔn)IIC模式,對(duì)IIC時(shí)鐘源的分頻系數(shù)是40,用來(lái)產(chǎn)生10KHZ的SCL時(shí)鐘
- I2C1->TRISE=3;//SCL的上升沿時(shí)間寬度為300NS
- I2C1->CR1=1;//開(kāi)啟IIC;
- void delay1ms(uint32_t a)
- for(a=23980;a;a--);
- 9328程序
- #include "ili9328.h"
- uint8_t tab[]={/*-- 文字: 王 --*/
- /*-- 宋體12; 此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16 --*/
- 0x00,0x00,0x7F,0xFC,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x3F,0xF8,
- 0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0xFF,0xFE,0x00,0x00};
- void write_LCD_CHINA_WRODS()
- uint8_t i,val,n;
- wr_cmd_date(0x0050,0);//行開(kāi)始坐標(biāo)
- wr_cmd_date(0x0051,15); //行結(jié)束坐標(biāo)
- wr_cmd_date(0x0052,0);//場(chǎng)開(kāi)始地址坐標(biāo)
- wr_cmd_date(0x0053,15); //場(chǎng)結(jié)束地址坐標(biāo)
- wr_cmd_date(0x0020,0); //行地址計(jì)數(shù)器
- wr_cmd_date(0x0021,0);//場(chǎng)地址計(jì)數(shù)器
- for(n=0;n<32;n++)
- for(i=0;i<8;i++)
- val=tab[n];
- if(((val<<i)&0x80)==0x80)
- wr_cmd_date(0x22,0x0000 );//bloke
- else
- wr_cmd_date(0x22,0xf800 );//red
- void lcm_coordinate(uint16_t x1,uint16_t y1 )//掃描地 寫(xiě)一個(gè)像素
- wr_cmd_date(0x0050,x1);//行開(kāi)始坐標(biāo)
- wr_cmd_date(0x0051,x1); //行結(jié)束坐標(biāo)
- wr_cmd_date(0x0052,y1);//場(chǎng)開(kāi)始地址坐標(biāo)
- wr_cmd_date(0x0053,y1); //場(chǎng)結(jié)束地址坐標(biāo)
- wr_cmd_date(0x0020,x1); //行地址計(jì)數(shù)器
- wr_cmd_date(0x0021,y1);//場(chǎng)地址計(jì)數(shù)器
- void LCD9328_init()//橫屏初始
- uint32_t a;
- delay1us(150000);
- wr_cmd_date(0x0001,0x0100); //s1-s720
- wr_cmd_date(0x0002,0x0700);
- wr_cmd_date(0x0003,0x1038);//默認(rèn)0x1030,現(xiàn)在設(shè)為0X1038.1018
- wr_cmd_date(0x0004,0x0000);
- wr_cmd_date(0x0008,0x0404);
- wr_cmd_date(0x0009,0x0000);
- wr_cmd_date(0x000A,0x0000);
- wr_cmd_date(0x000C,0x0000);
- wr_cmd_date(0x000D,0x0000);
- wr_cmd_date(0x000F,0x0000);
- //power on sequence VGHVGL
- wr_cmd_date(0x0010,0x0080);
- wr_cmd_date(0x0011,0x0007);
- wr_cmd_date(0x0012,0x0000);
- wr_cmd_date(0x0013,0x0000);
- //vgh
- wr_cmd_date(0x0010,0x1590);
- wr_cmd_date(0x0011,0x0227);
- delay1us(800000);
- //vregiout
- wr_cmd_date(0x0012,0x001F); //0x001b
- delay1us(800000);
- //vom amplitude
- wr_cmd_date(0x0013,0x1500);
- delay1us(800000);
- //vom H
- wr_cmd_date(0x0029,0x0022);
- wr_cmd_date(0x002B,0x000F);
- //gamma
- wr_cmd_date(0x0030,0x0004);
- wr_cmd_date(0x0031,0x0307);
- wr_cmd_date(0x0032,0x0002);// 0006
- wr_cmd_date(0x0035,0x0206);
- wr_cmd_date(0x0036,0x0408);
- wr_cmd_date(0x0037,0x0507);
- wr_cmd_date(0x0038,0x0204);//0200
- wr_cmd_date(0x0039,0x0707);
- wr_cmd_date(0x003C,0x0405);// 0504
- wr_cmd_date(0x003D,0x0F02);
- //ram
- /*wr_cmd_date(0x0050,0x0000);
- wr_cmd_date(0x0051,0x00B0);
- wr_cmd_date(0x0052,0x0000);
- wr_cmd_date(0x0053,0x00DC);*/
- wr_cmd_date(0x0050,0x0000);
- wr_cmd_date(0x0051,0x00EF);
- wr_cmd_date(0x0053,0x0013F);
- wr_cmd_date(0x0060,0xA700);
- wr_cmd_date(0x0061,0x0001);
- wr_cmd_date(0x006A,0x0000);
- wr_cmd_date(0x0080,0x0000);
- wr_cmd_date(0x0081,0x0000);
- wr_cmd_date(0x0082,0x0000);
- wr_cmd_date(0x0083,0x0000);
- wr_cmd_date(0x0084,0x0000);
- wr_cmd_date(0x0085,0x0000);
- wr_cmd_date(0x0090,0x0010);
- wr_cmd_date(0x0093,0x0003);
- wr_cmd_date(0x0095,0x0110);
- wr_cmd_date(0x0097,0x0000);
- wr_cmd_date(0x0098,0x0000);
- wr_cmd_date(0x0007,0x0173);
- for(a=76800;a;a--)
- wr_cmd_date(0x22,0xF800);//紅色刷屏
- void wr_cmd_date(uint16_t reg,uint16_t date)
- GPIOE->CRL=0x33333333; //數(shù)據(jù)口轉(zhuǎn)換成輸出
- GPIOE->CRH=0x33333333; //數(shù)據(jù)口轉(zhuǎn)換成輸出
- CLR_CS;
- CLR_RS;
- SET_RD;
- CLR_WR;
- GPIOE->ODR=reg;//GPIO_Write(GPIOE, reg);// //寫(xiě)入命令
- SET_WR;
- SET_RS;
- //delay_1us(1);
- CLR_WR;
- GPIOE->ODR=date;//GPIO_Write(GPIOE, date); // //寫(xiě)入命令
- SET_WR;
- SET_CS;
- uint16_t read_LCD_register(uint16_t reg)
- uint16_t date;
- CLR_CS;
- //delay_1us(1);
- CLR_RS;
- //delay_1us(1);
- SET_RD;
- CLR_WR;
- GPIO_Write(GPIOE, reg); //寫(xiě)入命令
- SET_WR;
- //delay_1us(1);
- CLR_RD;
- GPIOE->CRL=0x88888888; //數(shù)據(jù)口轉(zhuǎn)換成輸入
- GPIOE->CRH=0x88888888; //數(shù)據(jù)口轉(zhuǎn)換成輸入
- // for(n=200;n;n--);
- date=(GPIOE->IDR);//讀出數(shù)據(jù)
- SET_RD;
- SET_CS;
- return (date);
- void delay1us(uint32_t time)
- { uint32_t b,c;
- for(c=time;c;c--) //定時(shí)=time*3*333.6=time*1000.8ns
- for(b=8;b;b--); //8*13.9*3= 333.6
- 終端配置
- #include "EXTI.h"
- 外部中斷初始化
- void my_EXTI_int()
- /* PC0 被我設(shè)置成輸入模式,上拉、下拉 */
- GPIOC->CRL=0x00000008;
- /*配置PC0作為中斷輸入線*/
- AFIO->EXTICR[0]=2;
- /*設(shè)置開(kāi)啟外部中斷線0中斷請(qǐng)求,其他的都關(guān)閉*/
- /*PC0開(kāi)啟上升沿觸發(fā)*/
- EXTI->RTSR=0x00000001;
- /*設(shè)置PC0中斷的優(yōu)先級(jí)為5*/
- NVIC->IP[6]=5;//VSYNC
- /*開(kāi)啟號(hào)中斷即EXTI0,關(guān)閉其他所有外部的中斷*/
- NVIC->ISER[0]=0x00000040; //開(kāi)啟PC0中斷EXTI0 VSYNC中斷
