SYSTICK中斷模式!實驗
這是MAIN文件
- #include "main.h"
- #include "myuse.h"
- extern unsigned int count;
- 全局變量在多文件中的定義方法,。h文件只是用來聲明變量和函數(shù)的,不是用來定義實體變量的
- 要在一個.c文件和另一個。c文件中使用同一個變量,要在一個.c文件中先定義入:uint a;然后再在
- 另一個.c文件中用 extern uint a;定義一下,就OK樂,就是全局變量。。。!而且是同一個變量!
- ,天津第四項目部宿舍
- /** @addtogroup STM32F10x_StdPeriph_Examples
- /** @addtogroup SysTick_TimeBase
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- static __IO uint32_t TimingDelay;
- /* Private function prototypes -----------------------------------------------*/
- void Delay(__IO uint32_t nTime);
- /* Private functions ---------------------------------------------------------*/
- * @brief Main program.
- * @param None
- * @retval None
- GPIO_InitTypeDef GPIO_InitStructure;
- void mysysint()//系統(tǒng)初始化程序
- ErrorStatus HSEStartUpStatus;//說明標志位
- RCC_DeInit();//所有外設全部缺省設置
- /* Enable HSE */
- RCC_HSEConfig(RCC_HSE_ON);
- /* Wait till HSE is ready and if Time out is reached exit */
- HSEStartUpStatus = RCC_WaitForHSEStartUp();
- if(HSEStartUpStatus == SUCCESS)//啟動成功
- /*這兩條FLASH指令必須加上,不知為啥?不加上就運行幾秒后出錯,參照系統(tǒng)初始化*/
- /* Enable The Prefetch Buffer */
- FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);//FLASH緩存開啟
- /* Configure the Latency cycle: Set 2 Latency cycles */
- FLASH_SetLatency(FLASH_Latency_2); //設置FLASH這些位表示SYSCLK(系統(tǒng)時鐘)周期與閃存訪問時間的比例,為010:兩個等待狀態(tài),當 48MHz < SYSCLK ≤ 72MHz
- /* Set PLL clock output to 72MHz using HSE (8MHz) as entry clock */
- RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);//外部時鐘為8M,PLL的輸入時鐘=8MHZ,倍頻系數(shù)9,
- /* Configure HCLK such as HCLK = SYSCLK */
- RCC_HCLKConfig(RCC_SYSCLK_Div1);//設置了啦AHB分頻器的分頻系數(shù)=1,即HCLK=SYSCLK=72MHZ
- /* Configure PCLK1 such as PCLK1 = HCLK/2 */
- RCC_PCLK1Config(RCC_HCLK_Div2);//設置了APB1外設的時鐘頻率最大是36M這里是APB1的分頻器設為2,PCLK1=HCLK/2=72/2=36MHZ正好是最大值
- /* Configure PCLK2 such as PCLK2 = HCLK */
- RCC_PCLK2Config(RCC_HCLK_Div1);//設置PLCK2=HCLK=72MHZ,的APB2分頻器=1
- /* Select the PLL as system clock source */
- RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//設置了SYSCLK的提供者為PLL,頻率由上面算出=72MHZ
- /* disable PLL Ready interrupt */
- RCC_ITConfig(RCC_IT_PLLRDY, DISABLE);//PLL中斷關閉
- RCC_ITConfig(RCC_IT_HSERDY,DISABLE);//HSE中斷關閉
- RCC_ITConfig(RCC_IT_HSIRDY, DISABLE); //HSI中斷關閉
- RCC_ITConfig(RCC_IT_LSERDY, DISABLE); //LSE中斷關閉
- RCC_ITConfig(RCC_IT_LSIRDY, DISABLE); //LSI中斷關閉
- /* PLL clock divided by 1.5 used as USB clock source */
- RCC_USBCLKConfig(RCC_USBCLKSource_PLLCLK_1Div5);//設置USB的時鐘為=72、1.5=48mhz
- /* Configure ADCCLK such as ADCCLK = PCLK2/2 */
- RCC_ADCCLKConfig(RCC_PCLK2_Div2);//設置ADC時鐘=PCLK2/2= 36MHZ
- /* disable the LSE */
- RCC_LSEConfig(RCC_LSE_OFF);//外部低速晶振關閉
- /*DISable the RTC clock */
- RCC_RTCCLKCmd(DISABLE);
- /* DISable the Clock Security System */
- RCC_ClockSecuritySystemCmd(DISABLE);
- /* Enable the PLL */
- RCC_PLLCmd(ENABLE);//使能PLL
- /* PLL ans system clock config */
- else
- /* Add here some code to deal with this error */
- void mysystickint()
- SysTick->LOAD=71999;//加載值=1ms
- SCB->SHP[11]=15;//設置SYSTICK的優(yōu)先級為15,注意SYSTICK屬于系統(tǒng)異常,所以他的優(yōu)先級在SCB里設置。
- SysTick->CTRL=7;//開啟中斷,開啟定時器,時鐘設置為HCLK=72mhz
- int main(void)
- mysysint();//系統(tǒng)初始化
- /* GPIOD Periph clock enable */
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);//使能時鐘
- /* Configure PD0 and PD2 in output pushpull mode */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9| GPIO_Pin_10| GPIO_Pin_11;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(GPIOD, &GPIO_InitStructure);
- mysystickint(); //w我設置的SYStick工作在中斷模式
- while(1);
復制代碼
