要知道時間對程序來說也是生命!該延時的要延時,不該延時的不能延時,操作器件不也就是操作時序嗎?,所以延時是非常重要的,但是ARM的運算速度非?,用普通單片機似的延時恐怕。。。,很難算得很精確,這就出來了滴答時鐘,他和內(nèi)核在一塊,方便的時鐘選擇,簡單的寄存器,就搞定。
本程是查詢程序,下一步亞用中斷實現(xiàn)!
值得注意的是我沒找到庫函數(shù)!所以采用的是操作寄存器實現(xiàn)的!
SYSCLK=72mhz
- #include "main.h"
- GPIO_InitTypeDef GPIO_InitStructure;
- void mysysint()//系統(tǒng)初始化程序
- ErrorStatus HSEStartUpStatus;//說明標(biāo)志位
- RCC_DeInit();//所有外設(shè)全部缺省設(shè)置
- /* Enable HSE */
- RCC_HSEConfig(RCC_HSE_ON);
- /* Wait till HSE is ready and if Time out is reached exit */
- HSEStartUpStatus = RCC_WaitForHSEStartUp();
- if(HSEStartUpStatus == SUCCESS)//啟動成功
- /*這兩條FLASH指令必須加上,不知為啥?不加上就運行幾秒后出錯,參照系統(tǒng)初始化*/
- /* Enable The Prefetch Buffer */
- FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);//FLASH緩存開啟
- /* Configure the Latency cycle: Set 2 Latency cycles */
- FLASH_SetLatency(FLASH_Latency_2); //設(shè)置FLASH這些位表示SYSCLK(系統(tǒng)時鐘)周期與閃存訪問時間的比例,為010:兩個等待狀態(tài),當(dāng) 48MHz < SYSCLK ≤ 72MHz
- /* Set PLL clock output to 72MHz using HSE (8MHz) as entry clock */
- RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);//外部時鐘為8M,PLL的輸入時鐘=8MHZ,倍頻系數(shù)9,
- /* Configure HCLK such as HCLK = SYSCLK */
- RCC_HCLKConfig(RCC_SYSCLK_Div1);//設(shè)置了啦AHB分頻器的分頻系數(shù)=1,即HCLK=SYSCLK=72MHZ
- /* Configure PCLK1 such as PCLK1 = HCLK/2 */
- RCC_PCLK1Config(RCC_HCLK_Div2);//設(shè)置了APB1外設(shè)的時鐘頻率最大是36M這里是APB1的分頻器設(shè)為2,PCLK1=HCLK/2=72/2=36MHZ正好是最大值
- /* Configure PCLK2 such as PCLK2 = HCLK */
- RCC_PCLK2Config(RCC_HCLK_Div1);//設(shè)置PLCK2=HCLK=72MHZ,的APB2分頻器=1
- /* Select the PLL as system clock source */
- RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//設(shè)置了SYSCLK的提供者為PLL,頻率由上面算出=72MHZ
- /* disable PLL Ready interrupt */
- RCC_ITConfig(RCC_IT_PLLRDY, DISABLE);//PLL中斷關(guān)閉
- RCC_ITConfig(RCC_IT_HSERDY,DISABLE);//HSE中斷關(guān)閉
- RCC_ITConfig(RCC_IT_HSIRDY, DISABLE); //HSI中斷關(guān)閉
- RCC_ITConfig(RCC_IT_LSERDY, DISABLE); //LSE中斷關(guān)閉
- RCC_ITConfig(RCC_IT_LSIRDY, DISABLE); //LSI中斷關(guān)閉
- /* PLL clock divided by 1.5 used as USB clock source */
- RCC_USBCLKConfig(RCC_USBCLKSource_PLLCLK_1Div5);//設(shè)置USB的時鐘為=72、1.5=48mhz
- /* Configure ADCCLK such as ADCCLK = PCLK2/2 */
- RCC_ADCCLKConfig(RCC_PCLK2_Div2);//設(shè)置ADC時鐘=PCLK2/2= 36MHZ
- /* disable the LSE */
- RCC_LSEConfig(RCC_LSE_OFF);//外部低速晶振關(guān)閉
- /*DISable the RTC clock */
- RCC_RTCCLKCmd(DISABLE);
- /* DISable the Clock Security System */
- RCC_ClockSecuritySystemCmd(DISABLE);
- /* Enable the PLL */
- RCC_PLLCmd(ENABLE);//使能PLL
- /* PLL ans system clock config */
- else
- /* Add here some code to deal with this error */
- /** @addtogroup STM32F10x_StdPeriph_Examples
- /** @addtogroup SysTick_TimeBase
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- static __IO uint32_t TimingDelay;
- /* Private function prototypes -----------------------------------------------*/
- void Delay(__IO uint32_t nTime);
- /* Private functions ---------------------------------------------------------*/
- * @brief Main program.
- * @param None
- * @retval None
- void wang_mySYStick_init()
- //SysTick->LOAD=72000; //53MHZ下定時1ms
- SysTick->LOAD = 72000;
- SysTick->CTRL=0x00000005;//表示HCLK=SYStick時鐘,開啟滴答,關(guān)閉中斷
- *此函數(shù)為滴答時鐘的查詢函數(shù),不斷地在查詢標(biāo)志位。。。
- * 王均偉
- * 形參為時間值,延時時間=TIME*1毫秒
- void mydelay(unsigned int time) //20110725他媽的我沒找到關(guān)于這個版本的庫函數(shù),直接對寄存器操作了、反而感覺更親切了。很想51
- unsigned long a,b;
- while(time)
- a=SysTick->CTRL;
- b=a&0x00010000;
- if(b==0x00010000)
- SysTick->LOAD = 72000-1; //用的72MHZ時鐘,一直使用的話要減一。。。
- time--;
- int main(void)
- mysysint();//系統(tǒng)初始化程序
- /* GPIOD Periph clock enable */
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);//使能時鐘
- /* Configure PD0 and PD2 in output pushpull mode */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9| GPIO_Pin_10| GPIO_Pin_11;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(GPIOD, &GPIO_InitStructure);
- wang_mySYStick_init();//滴答初始化!
- while(1)
- /* Set the GPIOA port pin 10 and pin 15 */
- GPIO_SetBits(GPIOD, GPIO_Pin_8);//GPIOD->BSRR = 0x00000f00;//置為PD8-PD11
- mydelay(100);
- /* Clears the GPIOA port pin 10 and pin 15 */
- GPIO_ResetBits(GPIOD, GPIO_Pin_8);//GPIOD->BRR = 0x00000f00;
- mydelay(100);
- GPIO_SetBits(GPIOD, GPIO_Pin_9);//GPIOD->BSRR = 0x00000f00;//置為PD8-PD11
- mydelay(100);
- GPIO_ResetBits(GPIOD, GPIO_Pin_9);//GPIOD->BRR = 0x00000f00;
- mydelay(100);
- GPIO_SetBits(GPIOD, GPIO_Pin_10);//GPIOD->BSRR = 0x00000f00;//置為PD8-PD11
- mydelay(100);
- GPIO_ResetBits(GPIOD, GPIO_Pin_10);//GPIOD->BRR = 0x00000f00;
- mydelay(100);
- GPIO_SetBits(GPIOD, GPIO_Pin_11);//GPIOD->BSRR = 0x00000f00;//置為PD8-PD11
- mydelay(100);
- GPIO_ResetBits(GPIOD, GPIO_Pin_11);//GPIOD->BRR = 0x00000f00;
- mydelay(100);
