15黑幣
我就貼上幾個初始化的函數(shù)把
#define OLED_CS_PORT GPIOC
#define OLED_CS_PIN GPIO_PIN_2
#define Set_OLED_CS GPIO_WriteHigh(OLED_CS_PORT,OLED_CS_PIN)
#define Clr_OLED_CS GPIO_WriteLow(OLED_CS_PORT,OLED_CS_PIN)
#define OLED_RS_PORT GPIOC
#define OLED_RS_PIN GPIO_PIN_3
#define Set_OLED_RS GPIO_WriteHigh(OLED_RS_PORT,OLED_RS_PIN)
#define Clr_OLED_RS GPIO_WriteLow(OLED_RS_PORT,OLED_RS_PIN)
#define OLED_WR_PORT GPIOC
#define OLED_WR_PIN GPIO_PIN_7
#define Set_OLED_WR GPIO_WriteHigh(OLED_WR_PORT,OLED_WR_PIN)
#define Clr_OLED_WR GPIO_WriteLow(OLED_WR_PORT,OLED_WR_PIN)
#define OLED_RD_PORT GPIOC
#define OLED_RD_PIN GPIO_PIN_5
#define Set_OLED_RD GPIO_WriteHigh(OLED_RD_PORT,OLED_RD_PIN)
#define Clr_OLED_RD GPIO_WriteLow(OLED_RD_PORT,OLED_RD_PIN)
#define OLED_REST_PORT GPIOC
#define OLED_REST_PIN GPIO_PIN_6
#define Set_OLED_REST GPIO_WriteHigh(OLED_REST_PORT,OLED_REST_PIN)
#define Clr_OLED_REST GPIO_WriteLow(OLED_REST_PORT,OLED_REST_PIN)
#define OLED_GPIO_DATA_PORT GPIOB
#define DATAOUT(DataValue) GPIO_Write(OLED_GPIO_DATA_PORT,DataValue);
#define OLED_CMD 0 //寫命令
#define OLED_DATA 1 // 寫數(shù)據(jù)
CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);
OLED_IOInit();
OLED_init();
OLED_ShowString(0,0, "0.96' OLED TEST");
OLED_Refresh_Gram();
while(1);
IO初始化
void OLED_IOInit()
GPIO_DeInit(GPIOB);
GPIO_Init(GPIOB, GPIO_PIN_ALL, GPIO_MODE_OUT_PP_HIGH_FAST);
GPIO_DeInit(GPIOC);
GPIO_Init(GPIOC, GPIO_PIN_ALL, GPIO_MODE_OUT_PP_HIGH_FAST);
OLED寫命令\數(shù)據(jù)
void OLED_WR_Byte(u8 dat,u8 cmd)
DATAOUT(dat);
if(cmd==1) {Set_OLED_RS;}
else {Clr_OLED_RS;}
Clr_OLED_CS;
Clr_OLED_WR;
Set_OLED_WR;
Set_OLED_CS;
Set_OLED_RS;
OLED初始化
void OLED_init()
Clr_OLED_REST;
delay1(50);
Set_OLED_REST;
OLED_WR_Byte(0xAE,OLED_CMD); //關(guān)閉顯示
OLED_WR_Byte(0xD5,OLED_CMD); //設(shè)置時鐘分頻因子,震蕩頻率
OLED_WR_Byte(80,OLED_CMD); //【3:0】分頻因子【7:4】震蕩頻率
OLED_WR_Byte(0xA8,OLED_CMD); //設(shè)置驅(qū)動路數(shù)
OLED_WR_Byte(0X3F,OLED_CMD); //默認(rèn)0X3F(1/64)
OLED_WR_Byte(0xD3,OLED_CMD); //設(shè)置顯示偏移
OLED_WR_Byte(0X00,OLED_CMD); //默認(rèn)為0
OLED_WR_Byte(0x40,OLED_CMD); //設(shè)置顯示開始行[5:0],行數(shù)
OLED_WR_Byte(0x8D,OLED_CMD); //電荷泵設(shè)置
OLED_WR_Byte(0x14,OLED_CMD); //bit2,開啟/關(guān)閉
OLED_WR_Byte(0x20,OLED_CMD); //設(shè)置內(nèi)存地址模式
OLED_WR_Byte(0x02,OLED_CMD); //[1:0],00列地址模式;01行地址模式;10,頁地址模式;默認(rèn)0;
OLED_WR_Byte(0xA1,OLED_CMD); //段重定義設(shè)置,bit0:0,0->0;1,0->127;
OLED_WR_Byte(0xC0,OLED_CMD); //設(shè)置COM掃描方向;bit3:0,?普通模式;1,?重定義模式 COM[N-1]->COM0;N:驅(qū)動路數(shù)
OLED_WR_Byte(0xDA,OLED_CMD); //設(shè)置COM硬件引腳配置
OLED_WR_Byte(0x12,OLED_CMD); //[5:4]配置
OLED_WR_Byte(0x81,OLED_CMD); //對比度設(shè)置
OLED_WR_Byte(0xEF,OLED_CMD); //1~255;默認(rèn)0X7F (亮度設(shè)置,越大越亮)
OLED_WR_Byte(0xD9,OLED_CMD); //設(shè)置預(yù)充電周期
OLED_WR_Byte(0xf1,OLED_CMD); //[3:0],PHASE 1;[7:4],PHASE 2;
OLED_WR_Byte(0xDB,OLED_CMD); //設(shè)置VCOMH 電壓倍率
OLED_WR_Byte(0x30,OLED_CMD); //[6:4] 000,0.65*vcc;001,0.77*vcc;011,0.83*vcc;
OLED_WR_Byte(0xA4,OLED_CMD); //全局開啟顯示;bit0:1,卡其;0,1關(guān)閉
OLED_WR_Byte(0xA6,OLED_CMD); //設(shè)置顯示方式0:1,反向顯示;0,正常顯示
OLED_WR_Byte(0xAF,OLED_CMD); //開啟顯示
OLED_Clear();
個人分析是端口初始化或?qū)懨頫數(shù)據(jù)的函數(shù)不對,可不知道怎么改
oled.rar
2015-6-20 05:48 上傳
點(diǎn)擊文件名下載附件
756.96 KB, 下載次數(shù): 7
