查看: 2800|回復(fù): 4
我寫(xiě)的程序選位加1之后全部都變了,怎樣加程序使他每個(gè)位置都獨(dú)立變化?
ID:69319 發(fā)表于 2015-7-7 01:15 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<reg51.h>
#include<intrins.h>
#define INT16U unsigned int
sbit          K1 = P3^1;
sbit          K2 = P3^2;
sbit          K3 = P3^3;
sbit WEI0=P2^4;
sbit WEI1=P2^5;
sbit WEI2=P2^6;
sbit WEI3=P2^7;
unsigned char Time;
uchar Count=0;
unsigned char a,b,c,d;
unsigned char code XIANSHI[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
//0x40,0X79,0X24,0X30,0X19,0X12,0X02,0X78,0X00,0X18};//段碼
unsigned char code WEI[]={0X7F,0XBF,0XDF,0XEF};        //位碼
void Delay10ms(unsigned int c) ;
unsigned char Key_Scan();
void Timer();
void main(void)
unsigned char ledValue, keyNum;
        ledValue = 0x01;
        while (1)
                keyNum = Key_Scan();  //掃描鍵盤(pán)
                if (keyNum == 1) //如果鍵值返回1
                        P0=0x40;
                        P2=0X0F;
                else if (keyNum == 2)//如果鍵值返回2
                      a++;
              if(a==4)
                  a=0;
                  switch(a)
                  case 0:
                  WEI0 = 1;WEI1 = 1;WEI2 = 1;WEI3 = 0;
            //P2=0X7F;
            Delay10ms(1);
            break;
          case 1:
                   WEI0 = 1;WEI1 = 1;WEI2 = 0;WEI3 = 1;
           //P2=0XBF;
            Delay10ms(1);
            break;
          case 2:
                   WEI0 = 1;WEI1 = 0;WEI2 = 1;WEI3 = 1;
           //P2=0XDF;
            Delay10ms(1);
            break;
          case 3:
                   WEI0 = 0;WEI1 = 1;WEI2 = 1;WEI3 = 1;
           // P2=0XEF;
            Delay10ms(1);
            break;
         if (keyNum == 3)//如果鍵值返回3
          Timer();
         Count = Count+1;
                if(Count>9) //【最大值】
                        Count=0;
        P0=XIANSHI[Count];
        unsigned char keyValue = 0 , i; //保存鍵值
        //--檢測(cè)按鍵1--//
        if (K1==0)                //檢測(cè)按鍵K1是否按下
                Delay10ms(1);        //消除抖動(dòng)
                if (K1==0)        //再次檢測(cè)按鍵是否按下
                        keyValue = 1;
                        i = 0;
                        while ((i<50&&K1==0))         //檢測(cè)按鍵是否松開(kāi)
                                Delay10ms(1);
                                i++;
        if (K2==0)                //檢測(cè)按鍵K2是否按下
                if (K2==0)        //再次檢測(cè)按鍵是否按下
                        keyValue = 2;
                        i = 0;
                        while ((i<50&&K2==0))         //檢測(cè)按鍵是否松開(kāi)
                                Delay10ms(1);
                                i++;
        if (K3==0)                //檢測(cè)按鍵K3是否按下
                if (K3==0)        //再次檢測(cè)按鍵是否按下
                        keyValue = 3;
                        i = 0;
                        while ((i<50&&K3==0))         //檢測(cè)按鍵是否松開(kāi)
                                Delay10ms(1);
                                i++;
        return keyValue;   //將讀取到鍵值的值返回
void Delay10ms(unsigned int c)   //誤差 0us
    unsigned char a, b;
        //--c已經(jīng)在傳遞過(guò)來(lái)的時(shí)候已經(jīng)賦值了,所以在for語(yǔ)句第一句就不用賦值了--//
    for (;c>0;c--)
                for (b=38;b>0;b--)
                        for (a=130;a>0;a--);
   void Timer()
        TMOD = 0x01;     //定時(shí)器0選擇工作方式1
    TH0  = 0x3C;         //設(shè)置初始值,定時(shí)50MS
    TL0  = 0xB0;
    EA   = 1;             //打開(kāi)總中斷
    ET0  = 1;                 //打開(kāi)定時(shí)器0中斷
    TR0  = 1;                 //啟動(dòng)定時(shí)器0
void Timer0() interrupt 1
        TL0 = 0xB0;
    Time++;
        if(Time == 20)
                Time = 0;
這是程序和電路圖。我寫(xiě)的程序選位加1之后全部都變了,怎樣加程序使他每個(gè)位置都獨(dú)立變化?
ID:81808 發(fā)表于 2015-7-7 09:54 來(lái)自手機(jī) | 只看該作者
把電路圖傳上來(lái)吧,程序太長(zhǎng)沒(méi)那么多時(shí)間一個(gè)一個(gè)看,跑起來(lái)就知道了
參與人數(shù) 1黑幣 +35 收起 理由
admin + 35 回帖助人的獎(jiǎng)勵(lì)!
ID:84959 發(fā)表于 2015-7-7 10:19 | 只看該作者
你這個(gè)的話,你可以使用下面的表達(dá)式參考下:個(gè)位:x%10  十位:x/10%10  百位:x/100%10  千位:x/1000%10
ID:69319 發(fā)表于 2015-7-7 14:49 | 只看該作者
yanjibao 發(fā)表于 2015-7-7 09:54
大神幫我看一下謝謝了
新建文件夾 (2).rar
60.01 KB, 下載次數(shù): 2
ID:69319 發(fā)表于 2015-7-7 14:50 | 只看該作者
這是文件夾
新建文件夾 (2).rar
