查看: 58804|回復(fù): 18
STC15F2K60S2.H頭文件下載 引腳圖 管腳定義封裝及中文資料
ID:85086 發(fā)表于 2015-7-8 16:53 | 顯示全部樓層 |閱讀模式
STC15F2K60S2引腳圖及各種封裝圖的管腳定義請(qǐng)看下面:
STC15F2K60S2.H頭文件下載 :http://www.torrancerestoration.com/bbs/dpj-36960-1.html
  STC15F2K60S2頭文件內(nèi)容預(yù)覽
  1. #ifndef __STC15F2K60S2_H_
  2. #define __STC15F2K60S2_H_
  3. /////////////////////////////////////////////////
  4. //包含本頭文件后,不用另外再包含"REG51.H"
  5. //內(nèi)核特殊功能寄存器        // 復(fù)位值   描述
  6. sfr ACC         =   0xE0;   //0000,0000 累加器Accumulator
  7. sfr B           =   0xF0;   //0000,0000 B寄存器
  8. sfr PSW         =   0xD0;   //0000,0000 程序狀態(tài)字
  9. sbit CY         =   PSW^7;
  10. sbit AC         =   PSW^6;
  11. sbit F0         =   PSW^5;
  12. sbit RS1        =   PSW^4;
  13. sbit RS0        =   PSW^3;
  14. sbit OV         =   PSW^2;
  15. sbit P          =   PSW^0;
  16. sfr SP          =   0x81;   //0000,0111 堆棧指針
  17. sfr DPL         =   0x82;   //0000,0000 數(shù)據(jù)指針低字節(jié)
  18. sfr DPH         =   0x83;   //0000,0000 數(shù)據(jù)指針高字節(jié)
  19. //I/O 口特殊功能寄存器
  20. sfr P0          =   0x80;   //1111,1111 端口0
  21. sbit P00        =   P0^0;
  22. sbit P01        =   P0^1;
  23. sbit P02        =   P0^2;
  24. sbit P03        =   P0^3;
  25. sbit P04        =   P0^4;
  26. sbit P05        =   P0^5;
  27. sbit P06        =   P0^6;
  28. sbit P07        =   P0^7;
  29. sfr P1          =   0x90;   //1111,1111 端口1
  30. sbit P10        =   P1^0;
  31. sbit P11        =   P1^1;
  32. sbit P12        =   P1^2;
  33. sbit P13        =   P1^3;
  34. sbit P14        =   P1^4;
  35. sbit P15        =   P1^5;
  36. sbit P16        =   P1^6;
  37. sbit P17        =   P1^7;
  38. sfr P2          =   0xA0;   //1111,1111 端口2
  39. sbit P20        =   P2^0;
  40. sbit P21        =   P2^1;
  41. sbit P22        =   P2^2;
  42. sbit P23        =   P2^3;
  43. sbit P24        =   P2^4;
  44. sbit P25        =   P2^5;
  45. sbit P26        =   P2^6;
  46. sbit P27        =   P2^7;
  47. sfr P3          =   0xB0;   //1111,1111 端口3
  48. sbit P30        =   P3^0;
  49. sbit P31        =   P3^1;
  50. sbit P32        =   P3^2;
  51. sbit P33        =   P3^3;
  52. sbit P34        =   P3^4;
  53. sbit P35        =   P3^5;
  54. sbit P36        =   P3^6;
  55. sbit P37        =   P3^7;
  56. sfr P4          =   0xC0;   //1111,1111 端口4
  57. sbit P40        =   P4^0;
  58. sbit P41        =   P4^1;
  59. sbit P42        =   P4^2;
  60. sbit P43        =   P4^3;
  61. sbit P44        =   P4^4;
  62. sbit P45        =   P4^5;
  63. sbit P46        =   P4^6;
  64. sbit P47        =   P4^7;
  65. sfr P5          =   0xC8;   //xxxx,1111 端口5
  66. sbit P50        =   P5^0;
  67. sbit P51        =   P5^1;
  68. sbit P52        =   P5^2;
  69. sbit P53        =   P5^3;
  70. sbit P54        =   P5^4;
  71. sbit P55        =   P5^5;
  72. sbit P56        =   P5^6;
  73. sbit P57        =   P5^7;
  74. sfr P6          =   0xE8;   //0000,0000 端口6
  75. sbit P60        =   P6^0;
  76. sbit P61        =   P6^1;
  77. sbit P62        =   P6^2;
  78. sbit P63        =   P6^3;
  79. sbit P64        =   P6^4;
  80. sbit P65        =   P6^5;
  81. sbit P66        =   P6^6;
  82. sbit P67        =   P6^7;
  83. sfr P7          =   0xF8;   //0000,0000 端口7
  84. sbit P70        =   P7^0;
  85. sbit P71        =   P7^1;
  86. sbit P72        =   P7^2;
  87. sbit P73        =   P7^3;
  88. sbit P74        =   P7^4;
  89. sbit P75        =   P7^5;
  90. sbit P76        =   P7^6;
  91. sbit P77        =   P7^7;
  92. sfr P0M0        =   0x94;   //0000,0000 端口0模式寄存器0
  93. sfr P0M1        =   0x93;   //0000,0000 端口0模式寄存器1
  94. sfr P1M0        =   0x92;   //0000,0000 端口1模式寄存器0
  95. sfr P1M1        =   0x91;   //0000,0000 端口1模式寄存器1
  96. sfr P2M0        =   0x96;   //0000,0000 端口2模式寄存器0
  97. sfr P2M1        =   0x95;   //0000,0000 端口2模式寄存器1
  98. sfr P3M0        =   0xB2;   //0000,0000 端口3模式寄存器0
  99. sfr P3M1        =   0xB1;   //0000,0000 端口3模式寄存器1
  100. sfr P4M0        =   0xB4;   //0000,0000 端口4模式寄存器0
  101. sfr P4M1        =   0xB3;   //0000,0000 端口4模式寄存器1
  102. sfr P5M0        =   0xCA;   //0000,0000 端口5模式寄存器0
  103. sfr P5M1        =   0xC9;   //0000,0000 端口5模式寄存器1
  104. sfr P6M0        =   0xCC;   //0000,0000 端口6模式寄存器0
  105. sfr P6M1        =   0xCB;   //0000,0000 端口6模式寄存器1
  106. sfr P7M0        =   0xE2;   //0000,0000 端口7模式寄存器0
  107. sfr P7M1        =   0xE1;   //0000,0000 端口7模式寄存器1
  108. //系統(tǒng)管理特殊功能寄存器
  109. sfr PCON        =   0x87;   //0001,0000 電源控制寄存器
  110. sfr AUXR        =   0x8E;   //0000,0000 輔助寄存器
  111. sfr AUXR1       =   0xA2;   //0000,0000 輔助寄存器1
  112. sfr P_SW1       =   0xA2;   //0000,0000 外設(shè)端口切換寄存器1
  113. sfr CLK_DIV     =   0x97;   //0000,0000 時(shí)鐘分頻控制寄存器
  114. sfr BUS_SPEED   =   0xA1;   //xx10,x011 總線速度控制寄存器
  115. sfr P1ASF       =   0x9D;   //0000,0000 端口1模擬功能配置寄存器
  116. sfr P_SW2       =   0xBA;   //xxxx,x000 外設(shè)端口切換寄存器
  117. //中斷特殊功能寄存器
  118. sfr IE          =   0xA8;   //0000,0000 中斷控制寄存器
  119. sbit EA         =   IE^7;
  120. sbit ELVD       =   IE^6;
  121. sbit EADC       =   IE^5;
  122. sbit ES         =   IE^4;
  123. sbit ET1        =   IE^3;
  124. sbit EX1        =   IE^2;
  125. sbit ET0        =   IE^1;
  126. sbit EX0        =   IE^0;
  127. sfr IP          =   0xB8;   //0000,0000 中斷優(yōu)先級(jí)寄存器
  128. sbit PPCA       =   IP^7;
  129. sbit PLVD       =   IP^6;
  130. sbit PADC       =   IP^5;
  131. sbit PS         =   IP^4;
  132. sbit PT1        =   IP^3;
  133. sbit PX1        =   IP^2;
  134. sbit PT0        =   IP^1;
  135. sbit PX0        =   IP^0;
  136. sfr IE2         =   0xAF;   //0000,0000 中斷控制寄存器2
  137. sfr IP2         =   0xB5;   //xxxx,xx00 中斷優(yōu)先級(jí)寄存器2
  138. sfr INT_CLKO    =   0x8F;   //0000,0000 外部中斷與時(shí)鐘輸出控制寄存器
  139. //定時(shí)器特殊功能寄存器
  140. sfr TCON        =   0x88;   //0000,0000 T0/T1控制寄存器
  141. sbit TF1        =   TCON^7;
  142. sbit TR1        =   TCON^6;
  143. sbit TF0        =   TCON^5;
  144. sbit TR0        =   TCON^4;
  145. sbit IE1        =   TCON^3;
  146. sbit IT1        =   TCON^2;
  147. sbit IE0        =   TCON^1;
  148. sbit IT0        =   TCON^0;
  149. sfr TMOD        =   0x89;   //0000,0000 T0/T1模式寄存器
  150. sfr TL0         =   0x8A;   //0000,0000 T0低字節(jié)
  151. sfr TL1         =   0x8B;   //0000,0000 T1低字節(jié)
  152. sfr TH0         =   0x8C;   //0000,0000 T0高字節(jié)
  153. sfr TH1         =   0x8D;   //0000,0000 T1高字節(jié)
  154. sfr T4T3M       =   0xD1;   //0000,0000 T3/T4模式寄存器
  155. sfr T3T4M       =   0xD1;   //0000,0000 T3/T4模式寄存器
  156. sfr T4H         =   0xD2;   //0000,0000 T4高字節(jié)
  157. sfr T4L         =   0xD3;   //0000,0000 T4低字節(jié)
  158. sfr T3H         =   0xD4;   //0000,0000 T3高字節(jié)
  159. sfr T3L         =   0xD5;   //0000,0000 T3低字節(jié)
  160. sfr T2H         =   0xD6;   //0000,0000 T2高字節(jié)
  161. sfr T2L         =   0xD7;   //0000,0000 T2低字節(jié)
  162. sfr WKTCL       =   0xAA;   //0000,0000 掉電喚醒定時(shí)器低字節(jié)
  163. sfr WKTCH       =   0xAB;   //0000,0000 掉電喚醒定時(shí)器高字節(jié)
  164. sfr WDT_CONTR   =   0xC1;   //0000,0000 看門狗控制寄存器
  165. //串行口特殊功能寄存器
  166. sfr SCON        =   0x98;   //0000,0000 串口1控制寄存器
  167. sbit SM0        =   SCON^7;
  168. sbit SM1        =   SCON^6;
  169. sbit SM2        =   SCON^5;
  170. sbit REN        =   SCON^4;
  171. sbit TB8        =   SCON^3;
  172. sbit RB8        =   SCON^2;
  173. sbit TI         =   SCON^1;
  174. sbit RI         =   SCON^0;
  175. sfr SBUF        =   0x99;   //xxxx,xxxx 串口1數(shù)據(jù)寄存器
  176. sfr S2CON       =   0x9A;   //0000,0000 串口2控制寄存器
  177. sfr S2BUF       =   0x9B;   //xxxx,xxxx 串口2數(shù)據(jù)寄存器
  178. sfr S3CON       =   0xAC;   //0000,0000 串口3控制寄存器
  179. sfr S3BUF       =   0xAD;   //xxxx,xxxx 串口3數(shù)據(jù)寄存器
  180. sfr S4CON       =   0x84;   //0000,0000 串口4控制寄存器
  181. sfr S4BUF       =   0x85;   //xxxx,xxxx 串口4數(shù)據(jù)寄存器
  182. sfr SADDR       =   0xA9;   //0000,0000 從機(jī)地址寄存器
  183. sfr SADEN       =   0xB9;   //0000,0000 從機(jī)地址屏蔽寄存器
  184. //ADC 特殊功能寄存器
  185. sfr ADC_CONTR   =   0xBC;   //0000,0000 A/D轉(zhuǎn)換控制寄存器
  186. sfr ADC_RES     =   0xBD;   //0000,0000 A/D轉(zhuǎn)換結(jié)果高8位
  187. sfr ADC_RESL    =   0xBE;   //0000,0000 A/D轉(zhuǎn)換結(jié)果低2位
  188. //SPI 特殊功能寄存器
  189. sfr SPSTAT      =   0xCD;   //00xx,xxxx SPI狀態(tài)寄存器
  190. sfr SPCTL       =   0xCE;   //0000,0100 SPI控制寄存器
  191. sfr SPDAT       =   0xCF;   //0000,0000 SPI數(shù)據(jù)寄存器
  192. //IAP/ISP 特殊功能寄存器
  193. sfr IAP_DATA    =   0xC2;   //0000,0000 EEPROM數(shù)據(jù)寄存器
  194. sfr IAP_ADDRH   =   0xC3;   //0000,0000 EEPROM地址高字節(jié)
  195. sfr IAP_ADDRL   =   0xC4;   //0000,0000 EEPROM地址第字節(jié)
  196. sfr IAP_CMD     =   0xC5;   //xxxx,xx00 EEPROM命令寄存器
  197. sfr IAP_TRIG    =   0xC6;   //0000,0000 EEPRPM命令觸發(fā)寄存器
  198. sfr IAP_CONTR   =   0xC7;   //0000,x000 EEPROM控制寄存器
  199. //PCA/PWM 特殊功能寄存器
  200. sfr CCON        =   0xD8;   //00xx,xx00 PCA控制寄存器
  201. sbit CF         =   CCON^7;
  202. sbit CR         =   CCON^6;
  203. sbit CCF2       =   CCON^2;
  204. sbit CCF1       =   CCON^1;
  205. sbit CCF0       =   CCON^0;
  206. sfr CMOD        =   0xD9;   //0xxx,x000 PCA 工作模式寄存器
  207. sfr CL          =   0xE9;   //0000,0000 PCA計(jì)數(shù)器低字節(jié)
  208. sfr CH          =   0xF9;   //0000,0000 PCA計(jì)數(shù)器高字節(jié)
  209. sfr CCAPM0      =   0xDA;   //0000,0000 PCA模塊0的PWM寄存器
  210. sfr CCAPM1      =   0xDB;   //0000,0000 PCA模塊1的PWM寄存器
  211. sfr CCAPM2      =   0xDC;   //0000,0000 PCA模塊2的PWM 寄存器
  212. sfr CCAP0L      =   0xEA;   //0000,0000 PCA模塊0的捕捉/比較寄存器低字節(jié)
  213. sfr CCAP1L      =   0xEB;   //0000,0000 PCA模塊1的捕捉/比較寄存器低字節(jié)
  214. sfr CCAP2L      =   0xEC;   //0000,0000 PCA模塊2的捕捉/比較寄存器低字節(jié)
  215. sfr PCA_PWM0    =   0xF2;   //xxxx,xx00 PCA模塊0的PWM寄存器
  216. sfr PCA_PWM1    =   0xF3;   //xxxx,xx00 PCA模塊1的PWM寄存器
  217. sfr PCA_PWM2    =   0xF4;   //xxxx,xx00 PCA模塊1的PWM寄存器
  218. sfr CCAP0H      =   0xFA;   //0000,0000 PCA模塊0的捕捉/比較寄存器高字節(jié)
  219. sfr CCAP1H      =   0xFB;   //0000,0000 PCA模塊1的捕捉/比較寄存器高字節(jié)
  220. sfr CCAP2H      =   0xFC;   //0000,0000 PCA模塊2的捕捉/比較寄存器高字節(jié)
  221. /////////////////////////////////////////////////
  222. #endif
STC15F2K60S2中文資料下載鏈接: STC15F中文資料.rar (159 Bytes, 下載次數(shù): 534)
ID:112183 發(fā)表于 2016-4-4 17:18 | 顯示全部樓層
51黑有你更精彩�。�
ID:79544 發(fā)表于 2016-4-4 18:45 | 顯示全部樓層
謝謝樓主分享好的資料,感謝!�。�!支持國(guó)貨�。。。。。。。。�
ID:116589 發(fā)表于 2016-4-25 16:09 | 顯示全部樓層
謝謝樓主的資料
ID:115186 發(fā)表于 2016-5-26 01:08 | 顯示全部樓層
太好了,正需要
ID:129245 發(fā)表于 2016-7-5 00:52 | 顯示全部樓層
騰飛的龍 發(fā)表于 2016-4-4 18:45
謝謝樓主分享好的資料,感謝�。。�!支持國(guó)貨!�。。。。。。�!
ID:145267 發(fā)表于 2016-10-30 23:36 | 顯示全部樓層
不錯(cuò)。正找這個(gè)呢
ID:121541 發(fā)表于 2017-2-27 19:41 | 顯示全部樓層
為啥資料打不開
ID:219431 發(fā)表于 2017-7-13 16:27 | 顯示全部樓層
謝謝樓主
ID:223504 發(fā)表于 2017-7-31 10:42 | 顯示全部樓層
下載一份資料。
ID:221708 發(fā)表于 2017-8-10 20:42 | 顯示全部樓層
謝謝分享
ID:242559 發(fā)表于 2017-10-24 20:31 | 顯示全部樓層
想找個(gè)中文資料,謝謝分享!
ID:283470 發(fā)表于 2018-2-10 09:42 | 顯示全部樓層
頂,謝謝樓主,下載學(xué)習(xí)
ID:462651 發(fā)表于 2019-3-26 21:35 | 顯示全部樓層
好東西,謝謝分享
ID:529674 發(fā)表于 2019-5-7 16:15 | 顯示全部樓層
需要
ID:688460 發(fā)表于 2020-6-2 21:42 | 顯示全部樓層
感謝樓主!正要32pin的圖!謝謝!
ID:498223 發(fā)表于 2021-3-13 16:07 | 顯示全部樓層
謝謝樓主分享好的資料,感謝!
ID:1004193 發(fā)表于 2023-6-17 17:31 | 顯示全部樓層
stc15f2k60s2,有沒有PLCC封裝
