查看: 2703|回復(fù): 0
iOS開發(fā)之使用CALayer封裝下載進(jìn)度條
ID:85764 發(fā)表于 2015-7-18 00:34 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
效果圖
代碼
//  XRProgressView.h
//  使用CALayer封裝下載進(jìn)度條
//  Created by 寒竹子 on 15/6/14.
//  Copyright (c) 2015年 寒竹子. All rights reserved.
*  下載進(jìn)度條封裝
#import <UIKit/UIKit.h>
@interface XRProgressView : UIView
@property (nonatomic, assign) CGFloat progress;
@property (nonatomic, strong) UIColor * progressColor;
@end
//  XRProgressView.m
#import "XRProgressView.h"
@interface XRProgressView ()
@property (nonatomic, strong) CALayer * progressLayer; // 進(jìn)度layer
@property (nonatomic, assign) CGFloat currentWidth;    // 當(dāng)前l(fā)ayer的width
@end
@implementation XRProgressView
- (instancetype)initWithFrame:(CGRect)frame
    if (self = [super initWithFrame:frame]) {
        self.layer.backgroundColor = [UIColor clearColor].CGColor;
        self.layer.borderWidth = .5f;
        // 創(chuàng)建layer
        _progressLayer = [CALayer layer];
        _progressLayer.frame = CGRectMake(0, 0, 0, self.frame.size.height);
        // 將progressLayer添加到當(dāng)前View的layer中
        [self.layer addSublayer:_progressLayer];
        // 保存width
        _currentWidth = self.frame.size.width;
    return self;
#pragma mark - getters and setters
@synthesize progress = _progress;
// 設(shè)置進(jìn)度
- (void)setProgress:(CGFloat)progress
    _progress = progress;
    if (_progress < 0.0f) {
        self.progressLayer.frame = CGRectMake(0, 0, 0, self.frame.size.height);
    }else if (_progress <= 1.0f) {
        self.progressLayer.frame = CGRectMake(0, 0, _progress * self.currentWidth, self.frame.size.height);
    }else {
        self.progressLayer.frame = CGRectMake(0, 0, self.currentWidth, self.frame.size.height);
- (CGFloat)progress
    return _progress;
@synthesize progressColor = _progressColor;
// 設(shè)置layer背景顏色
- (void)setProgressColor:(UIColor *)progressColor
    _progressColor = progressColor;
    self.progressLayer.backgroundColor = _progressColor.CGColor;
- (UIColor *)progressColor
    return _progressColor;
@end
//  ViewController.m
#define KBorder 20.0f
#import "ViewController.h"
@interface ViewController ()
@property (nonatomic, strong) XRProgressView * progressView;
@property (nonatomic, strong) NSTimer        * timer;
@property (nonatomic, assign) CGFloat        progress; // 下載進(jìn)度
@end
@implementation ViewController
    if (self = [super init]) {
        _progress = 0.0f;
    return self;
// 起定時(shí)器
- (void)startTimer
    _timer = [NSTimer scheduledTimerWithTimeInterval:.1f
                                              target:self
                                            selector:@selector(updateProgress)
                                            userInfo:nil
                                             repeats:YES];
    [[NSRunLoop currentRunLoop] addTimer:_timer forMode:NSRunLoopCommonModes];
// 模擬更新下載進(jìn)度
- (void)updateProgress
    if (_progress > 1.0f) {
        _progress = 0.0f;
    }else {
        _progress += .01f;
    self.progressView.progress = _progress;
- (void)viewDidLoad {
    [super viewDidLoad];
    self.progressView = [[XRProgressView alloc] initWithFrame:CGRectMake(KBorder, KBorder * 2.0f, self.view.frame.size.width - KBorder * 2.0f, 4.0f)];
    self.progressView.layer.masksToBounds = YES;
    self.progressView.layer.cornerRadius = self.progressView.frame.size.height / 2.0f;
    self.progressView.progressColor = [UIColor redColor];
    [self.view addSubview:self.progressView];
    // 開啟定時(shí)器
    [self startTimer];
- (void)didReceiveMemoryWarning {
    [super didReceiveMemoryWarning];
@end
