我今天剛寫(xiě)了一個(gè), 沒(méi)有燒錄,編譯沒(méi)有問(wèn)題, 另外我之前用PIC18F4520寫(xiě)的現(xiàn)在還在用, 這個(gè)是按照PIC的移植過(guò)來(lái)的。
//*********ATmega128,8channel ADC sampling + LED display + USART*******
#include <iom128v.h>
#include <macros.h>
#define ulong unsigned long
#define FOSC 1843200
#define baud 9600
#define MyUBBR (uint)((ulong)FOSC/(16*(ulong)baud)-1)
const uchar table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar Data[4]={0};
uchar adcon0_table[]={0x40,0x41,0x42,0x43,0x44,0x45,0x46,0x47};
uchar num1,num2;
uint data_buf[10]={0};
void delay_ms(uint x);
void PORT_init();
void USART_Init(uint ubbr);
void USART_Transmit(uchar data);
uchar USART_Receive(void);
void NumericalLED_display(void);
uint data_average(uint buffer[30]);
void get_AD(void);
uchar i;
PORT_init();
USART_Init(MyUBBR);
NumericalLED_display();
get_AD();
if(USART_Receive()==0x01)
num1=PORTD;
num2=PORTB&0X03;
if((num1==0xff)&&(num2==0x03))
USART_Transmit(num1);
USART_Transmit(num2);
for(i=0;i<8;i++)
num1=data_buf[i]/255;
num2=data_buf[i]%255;
delay_ms(1000);
uint y,z;
for(y=x;y>0;y--)
for(z=110;z>0;z--);
void PORT_init()
DDRA=0x00;
DDRB=0xFF;
PORTB=0xFF;
DDRC=0xFF;
PORTC=0xFF;
PORTD=0xFF;
DDRD=0xFF;
UBRR1H= (uchar)(ubbr>>8);
UBRR1L= (uchar)ubbr;
UCSR1A= 0x00;
UCSR1B|=(1<<TXEN1)|(1<<RXEN1);
UCSR1C=0x06;//(0<<USBS0)|(1<<UCSZ01)|(1<<UCSZ00);
while(!(UCSR1A&(UDRE1)));
UDR1=data;
while(!(UCSR1A&(1<<RXC1)));
return UDR1;
static uchar i,temp=0x01;//temp=0x7f;
for (i=0; i<4; i++)
PORTC=table[Data[i]];
temp=1<<i;
PORTB&=~temp;
delay_ms(10);
//PORTC=table[Data[i]];
//PORTB=temp;
//temp=(temp>>1)|0x80;
//__delay_cycles(100);
uchar i,j;
uint temp;
float temp1;
for(i=1; i<30; i++)
for(j=29; j>=i; --j)
if(buffer[j-1] > buffer[j])
temp = buffer[j-1];
buffer[j-1] = buffer[j];
buffer[j] = temp;
temp1 = 0;
for(i=5; i<25; i++)
temp1 += buffer[i];
temp = (uint)(((float)temp1) / 20 + 0.5);
return(temp);
void get_AD(void)
uchar i,j;
uint adcbuf[30]={0};
static uchar ADC_channel=0;
//ADMUX=0x40;
ADCSRA=0x83;
SFIOR=0x00;
delay_ms(1);
for (i=0; i<8; i++)
ADMUX=adcon0_table[ADC_channel];
for(j=0; j<30; j++)
asm("NOP");
asm("NOP");
ADCSRA|=BIT(6);
while(((1<<ADIF)&0x10)!=0x10);
// adcbuf[j]=(ADCH*256)+ADCL;
adcbuf[j]=(ADCH<<8)|ADCL;
data_buf[i]=data_average(adcbuf);
Data[3]=data_buf[i]/1000;
Data[2]=data_buf[i]%1000/100;
Data[1]=data_buf[i]%100/10;
Data[0]=data_buf[i]%10;
if (++ADC_channel>8)ADC_channel=0;
delay_ms(1);
//PIC Multi_CD channel source code,
//******Multi_ADChannel converter**********//
#include <pic18.h>
__PROG_CONFIG(1,0xc200);
__PROG_CONFIG(2,0x0a16);
__PROG_CONFIG(3,0x8100);
__PROG_CONFIG(4,0x0081);
__PROG_CONFIG(5,0xc00f);
__PROG_CONFIG(6,0xe00f);
__PROG_CONFIG(7,0x400f);
uchar temp;
void multi_convertor(void);
void port_check(void);
uint ADbuf[10];
void delay_ms(uint t)
uint m,n;
for (m=0;m<t; m++)
for (n=0; n<1140;n++);
void GPIO_Init(void)
TRISA=0xff;
TRISB=0xff;
TRISC=0xff;
TRISD=0xff;
TRISE=0xff;
PSPMODE=0;
PSPIE=0;
PSPIP=0;
TRISBbits.RB2 =1; //set direction of RB2 to be An input;
TRISBbits.RB3 =1; //set direction of RB3 to be An input;
void ADC_Init(void)
ADCON1 = 0x05; //seting AN0~AN9 to be analog input;
ADCON2 = 0xBE; //20TAD,FOSC/64 and right justified;
void timer0_init(void)
INTCON =0xE0;//GIE,PEIE,TMR0IE to set;
T0CON = 0x1F;// timer0 to be 16-bit;
TMR0H = (65536-1000)/256;
TMR0L = (65536-1000)%256;
T0CON |=0x80;
TMR0ON=1;
void EUART_init(void)
TRISC7=1;
TRISC6=1;
SPBRG=0x40;
TXSTA=0x24;
RCSTA=0x90;
RCIE=0;
TXIE=0;
PEIE=1;
GIE=1;
void transmit_udata(uchar udata)
TXREG=udata;
while(!TRMT);
uchar receive_udata(void)
uchar temp;
if (RCIF==1)
temp=RCREG;
return temp;
uchar i,j;
uint temp;
float temp1;
for(i=1; i<30; i++)
temp = buffer[j-1];
buffer[j] = temp;
temp1 = 0;
for(i=5; i<25; i++)
temp1 += buffer[i];
return(temp);
void main(void)
EUART_init();
GPIO_Init();
ADC_Init();
timer0_init();
temp=receive_udata();
if (temp==0x01)
temp=0;
port_check();
multi_convertor();
uchar num1, num2;
num1=PORTD;
num2=PORTB&0X03;
transmit_udata(num2);
transmit_udata(num1);
uchar data1,data2,i;
uint adc[30]={0};
// ADC_channel++;
for (ADC_channel=0; ADC_channel<10; ADC_channel++)
switch(ADC_channel)
case 0: ADCON0=0x01;break;//AN0 channel;
case 1: ADCON0=0x05;break;//AN1 channel;
case 2: ADCON0=0x09;break;//AN2 channel;
case 3: ADCON0=0x0D;break;//AN3 channel;
case 4: ADCON0=0x11;break;//AN4 channel;
case 5: ADCON0=0x15;break;//AN5 channel;
case 6: ADCON0=0x19;break;//AN6 channel;
case 7: ADCON0=0x1D;break;//AN7 channel;
case 8: ADCON0=0x21;break;//AN8 channel;
case 9: ADCON0=0x25;break;//AN9 channel;
default:break;
for(i=0;i<30;i++)
ADCON0 |=0x01;
asm("NOP");
asm("NOP");
GODONE=1;
while(GODONE);
adc[i]=(ADRESH*256)+ADRESL;
ADbuf[ADC_channel]=data_average(adc);
data1=ADbuf[ADC_channel]/255;
data2=ADbuf[ADC_channel]%255;
transmit_udata(data1);
transmit_udata(data2);
