查看: 2202|回復(fù): 0
新手來的,誰能幫我改下,我用ICC編譯有錯(cuò)但是不知怎么修改。
ID:86731 發(fā)表于 2015-7-24 16:19 | 顯示全部樓層 |閱讀模式
#include <iom8v.h>
#include <macros.h>
#include <stdlib.h>
#include <lcd.h>
#include <math.h>
#include<string.h>
#define S0   1<<0    //pc0 gnd
#define S1   1<<1    //2v
#define S2   1<<7    //200mv   PD7
#define S3   1<<2    //-vref
#define S4   1<<4    //-20mv
#define S5   1<<3    //discharge
#define S6   1<<5    //Ux
#define S7   1<<6    //Ix
//全局變量
unsigned char timetemp=0;
unsigned char time100ms=0;
unsigned int time500ms=0;
unsigned char stepflag=0;//轉(zhuǎn)換階段標(biāo)志 -uref ? -uref/2 7?
unsigned char conflag=0; //正在轉(zhuǎn)換標(biāo)志
unsigned int  voltcount=0;  //ad值
float         volt=0;       //電壓值
unsigned char timeH=0;     //計(jì)數(shù)器值
unsigned char timeL=0;
//函數(shù)
void init_devices(void);
void port_init(void);
//1ms
void timer2_init(void);
void timer2_ovf_isr(void);
//100us
void timer1_init(void);
void timer1_ovf_isr(void);
void adadjust(void);
void adini(void);
void adconvert(unsigned char data);
//main()
unsigned char i;
unsigned char lcdbuf[32];
unsigned char *lcdp=lcdbuf;
init_devices();
Inti_Disp();
adadjust();
adini();
   adini();
   adconvert(0x08);//
   set_cur(0);
   lcdp=ftoa(volt,0);
   putstr(lcdp);
   set_cur(16);
   ltoa(lcdbuf,voltcount,10);
   putstr(lcdbuf);
//abc();
void adini(void)
    PORDC=0x08; //放電30ms
    timetemp=30;
    conflag=1;
void adconvert(unsigned char data)//充電
       //充電196ms
       PORDC=data; //打開Ux
       timetemp=196;
       conflag=1;
       while(timetemp);//等待
       //反向放電
          //讀取U0值
          if(PIND&0x08)
              PORDC=0x10;//接入-uref/2 7
              stepflag=1;//qi dong counter
              timeH=0;
              timeL=0;
            PORDC=0x04;//接入-uref
            stepflag=2; //qi dong counter
            timeH=0;
                timeL=0;
dischar1:
          while(stepflag==2)
             if(PIND&0x08)
          while(PIND&0x04);
          voltcount=timeH;
          voltcount=(voltcout<<7)+timeL;
PORTB = 0xFF;
DDRB  = 0xff;
PORTC = 0x08; //m103 output only
DDRC  = 0xff;
PORTD = 0x7F;
DDRD  = 0xf3;
//TIMER1 initialisation - prescale:64
// WGM: 0) Normal, TOP=0xFFFF
// desired value: 500uSec
// actual value: 500.000uSec (0.0%)
TCCR1B = 0x00; //stop
TCNT1H = 0xFF; //setup
TCNT1L = 0x83;
OCR1AH = 0x00;
OCR1AL = 0x7D;
OCR1BH = 0x00;
OCR1BL = 0x7D;
ICR1H  = 0x00;
ICR1L  = 0x7D;
TCCR1A = 0x00;
TCCR1B = 0x03; //start Timer
#pragma interrupt_handler timer1_ovf_isr:9
//TIMER1 has overflowed
TCNT1H = 0xFF; //reload counter high value
TCNT1L = 0x83; //reload counter low value
if(stepflag==1)
     //timeH
     timeL++;
if(stepflag==2)
     timeH++;
//TIMER2 initialisation - prescale:64
// WGM: Normal
// desired value: 1mSec
// actual value:  1.000mSec (0.0%)
TCCR2 = 0x00; //stop
ASSR  = 0x00; //set async mode
TCNT2 = 0x06; //setup
OCR2  = 0xFA;
TCCR2 = 0x04; //start
//1ms
#pragma interrupt_handler timer2_ovf_isr:5
TCNT2 = 0x06; //reload counter value
if(timetemp!=0)
   timetemp--;
   conflag=0;
if(time500ms==0)
     PORTC^=0x20;
     time500ms=500;
time500ms--;
//call this routine to initialise all peripherals
//stop errant interrupts until set up
CLI(); //disable all interrupts
port_init();
  timer1_init();
timer2_init();
MCUCR = 0x00;
GICR  = 0x00;
TIMSK = 0x44; //timer interrupt sources
SEI(); //re-enable interrupts
//all peripherals are now initialised
