查看: 2412|回復: 0
求助!12864液晶顯示問題!
ID:85129 發(fā)表于 2015-7-29 20:14 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
我的12864顯示的問題,
程序如下:
#include <reg52.h>
#include"intrins.h"
#define LCD12864DataPort P0
#define  uchar unsigned char
#define  uint  unsigned  int
// LCD128*64 I/O
//信號管腳
sbit rs =P2^0;   // //數(shù)據(jù)\//指令//選擇
sbit rw =P2^1;   // //讀\寫選擇
sbit en =P2^2;   // 讀\寫使能
sbit cs1 =P2^4;  // 片選1,低有效(前64列)
sbit cs2 =P2^5;  // 片選2,低有效(后64列)
void    lcdstate()
uchar  lcd=0x00; /*設置初值為0,全部為低,方便后面的判忙*/
rs=0; /*根據(jù)時序圖拉低,選擇寫指令*/
rw=1; /*根據(jù)時序圖拉低,選擇寫模式*/
do
en=1; /*使能,使液晶輸出信號,檢查是否忙*/
_nop_();_nop_();_nop_();_nop_();/*延時4US*/
lcd=P0; /*把P0口的狀態(tài)值讀回來給lcd*/
en=0; /*使能端跳變*/;
}while(lcd&0x80); /*結果的高位保留,如果高位DB7為一,則表示忙*/
void delay(uchar  ms)
{ uchar   i;
   uchar   j;
  for(i=0;i<100;i++)
   for(j=0;j<ms;j++);
void   write_command(uchar   command)
lcdstate();
  rs=0;    //RS=0;為往MCU進行指令操作
  rw=0;    //RW=0;為往MCU寫入操作
  en=0;
  en=1;
  P0=command;
  en=0;
void   write_data(uchar   datas)
   lcdstate();
   rs=1;
   rw=0;
   en=0;
   en=1;
   P0=datas;
   en=0;
void   lcdinit()
    delay(100);      //
    cs1=1;
cs2=1;
delay(100);
  lcdstate();     //
write_command(0x3e);   //
write_command(0xb8+0);    //
write_command(0xc0+0);   //
write_command(0x40+0);   //
write_command(0x3f);
void clearScreen(  )
{   uchar i,j;
    lcdstate();
    cs1=1;
cs2=1;
write_command(0x3f);   //設置顯示開
write_command(0xb8);      //Y 設置第0頁;
write_command(0x40);    // 設置第0列
   for(i=0;i<8;i++)
     write_command(0xb8+i);
     for(j=0;j<64;j++)
    //write_command(0x40+j);
       write_data(0x00);
uchar code    xms[16]= {
0xee,0xef,0xee,0xee,0xee,0xff,0xff,0xff,0xff,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,
void hz_display16(unsigned char pag, unsigned char col, unsigned char code *hzk)
uchar j=0;
uchar i=0;
for(j=0;j<1;j++)
  write_command(0xb8+pag+j);
  write_command(0x40+col);
  for(i=0;i<16;i++)
  write_data(hzk[16*j+i]);
lcdinit();
clearScreen(  );
    cs1=1;
    cs2=0;
  delay(2);
// hz_display16(0,0,xms[]);
  hz_display16(0,0,xms);
0xee,0xef,0xee,0xee,0xee,0xff,0xff,0xff,0xff,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,這里的第六個0XFF,在液晶上顯示的是0XEF,第十個0X1F,顯示的是0X0F,百思不得其解,液晶是KS0108芯片。顯示1,3,5,7,9,B,D,F,都有類似問題,求幫助!先謝謝大家了!
