查看: 4978|回復(fù): 2
ds1302+led 匯編
ID:20190 發(fā)表于 2010-3-21 10:05 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
由于小弟C能力有限,就用匯編寫了一個(gè)DS1302+LED 程序, 程序在按鍵數(shù)據(jù)處理上有問題,實(shí)在不好寫.
    高電平點(diǎn)亮位數(shù)碼管!
           CLK    BIT P3.5;預(yù)定義ds1302
           IO    BIT P3.6
           RST   BIT P3.7
           SPEAKER      BIT P3.1;蜂鳴器
           KEY_S BIT P3.2;按鍵定義
           KEY_M BIT P3.3
           KEY_H        BIT P3.4
    SECOND  EQU 30H;秒地址
    MINUIE EQU 31H;分
    HOUR  EQU 32H;時(shí)地址
    DAY  EQU 33H
    MONTH EQU 34H
    WEEK  EQU 35H
    YEAR  EQU 36H
    Q1   EQU 50H
    Q2           EQU 51H
    CTH EQU (65536-50000)/256
     CTL EQU (65536-50000) MOD 256
    ORG 0000H
    SJMP START
    ORG 000BH
    LJMP TIME_0
    ORG 0030H
    JMP START
START:     MOV SP,#60H    ;開始
           MOV R2,#20
           MOV DPTR,#ABC
MAIN:      MOV TMOD,#01H
           MOV TH0,#CTH
           MOV TL0,#CTL
           SETB EA
    SETB ET0
           CALL READ1302
           MOV ACC,30H
           JNB ACC.7,JUMP
    CALL INIT
JUMP:    SETB TR0
LOOP:      CALL DISPLAY
           JNB KEY_S,K1
           JNB KEY_M,K2
    JNB KEY_H,K3
    SJMP LOOP
K1:        CALL DELAY
           JB KEY_S,LOOP
    MOV A,30H
    MOV B,#16
    DIV AB
    MOV A,B
    INC A
    CJNE A,#10,D1
    MOV A,30H
    ADD A,#16
    CJNE A,#60H,D4
    MOV A,#00H
    JMP D4
K2:        CALL DELAY
           JB KEY_M,LOOP
           MOV A,31H
    MOV B,#16
    DIV AB
    MOV A,B
    INC A
    CJNE A,#10,D2
    MOV A,31H
    ADD A,#16
    CJNE A,#60H,D5
    MOV A,#00H
    JMP D5
K3:        CALL DELAY
           JB KEY_H,LOOP
           MOV A,32H
    MOV B,#16
    DIV AB
    MOV A,B
    INC A
    CJNE A,#10,D3
    MOV A,32H
           ADD A,#16
    CJNE A,#30H,D6
    MOV A,#00H
    JMP D6
D1:        MOV A,30H      ;MIAO TIAO ZHENG SHU RU
           INC A
D4:    MOV 30H,A
    CALL DISPLAY
           CLR CLK
    CLR RST
    MOV Q1,#80H
    MOV Q2,30H
    MOV R1,#Q1
    CALL W1302
    CALL DISPLAY
    JMP LOOP
D2:        MOV A,31H     ;FEN YIAO ZHENG SHU RU
           INC A
D5:    MOV 31H,A
           CALL DISPLAY
           CLR CLK
    CLR RST
    MOV Q1,#82H
    MOV Q2,31H
    MOV R1,#Q1
    CALL W1302
    CALL DISPLAY
    JMP LOOP
D3:        MOV A,32H   ;SHI SHU JU SHU RU
           INC A
D6:        MOV 32H,A
           CALL DISPLAY
           CLR CLK
    CLR RST
           MOV Q1,#84H
    MOV Q2,32H
    MOV R1,#Q1
    CALL W1302
    CALL DISPLAY
    JMP LOOP
INIT:      CLR CLK           ;初始化1302
           CLR RST
    MOV Q1,#8EH;OPEN WRITE PROTECTION
    MOV Q2,#00H
    MOV R1,#Q1
    CALL W1302
    MOV Q1,#90H;OPEN BATTREY
    MOV Q2,#0AAH
    MOV R1,#Q1
    CALL W1302
    MOV Q1,#80H;START
    MOV Q2,#00H
    MOV  R1,#Q1
    CALL W1302
    RET
W1302:     CLR CLK
    NOP
    SETB RST
    NOP
    NOP
    MOV R7,#2
W_1:    MOV R6,#8
           MOV  A,@R1
    CLR C
W_2:       CLR CLK
           RRC A
    MOV IO,C
    NOP
    SETB CLK
    DJNZ R6,W_2
    INC R1
    DJNZ R7,W_1
    CLR RST
    NOP
    CLR CLK
    RET
READ1302:       MOV R0,#30H   ;  讀1302數(shù)據(jù)
                MOV R5,#3
  MOV R7,#81H
READ1302_: MOV A,R7
                CLR RST
         NOP
  SETB RST
  NOP
         MOV R4,#8          ;1302寫一字節(jié)
               CLR C
SETONE1:        CLR CLK
          RRC A
                MOV IO,C
         NOP
                SETB CLK
         DJNZ R4,SETONE1
      GET1302:  MOV R4,#8   ;1302讀一字節(jié)
                CLR C
      GETONE1:  SETB CLK
                NOP
                CLR CLK
         NOP
                MOV C,IO
                RRC A
         DJNZ R4,GETONE1
  CLR RST
                NOP
  CLR CLK   ;WAN BI
  MOV @R0,A
  INC R0
  INC R7
  INC R7
  DJNZ R5,READ1302_
  RET
TIME_0:   PUSH ACC        ;中斷服務(wù)
          PUSH PSW
          MOV TH0,#CTH
          MOV TL0,#CTL
          DJNZ R2,KEIL
   CALL READ1302
   MOV R2,#20
KEIL:     POP PSW
   POP ACC
   RETI
DISPLAY:   MOV A,SECOND    ;顯示子程序
           MOV B,#16
    DIV AB
    MOVC A,@A+DPTR
    MOV P2,A
           SETB P1.1
    CALL DELAY
    CLR P1.1;@@@@@@@@@秒十位
    MOV A,B
    MOVC A,@A+DPTR
    MOV P2,A
    SETB P1.0
    CALL DELAY
           CLR P1.0;@@@@@@@@@@@@秒個(gè)位
    MOV P2,#0BFH
    SETB P1.2
    CALL DELAY
    CLR P1.2;@@@@@@@@@222分秒之間橫杠
    MOV A,MINUIE
    MOV B,#16
    DIV AB
    MOVC A,@A+DPTR
    MOV P2,A
    SETB P1.4
    CALL DELAY
    CLR P1.4;@@@@@@@@@@分十位
    MOV A,B
    MOVC A,@A+DPTR
    MOV P2,A
    SETB P1.3
    CALL DELAY
    CLR P1.3;@@@@@@@@@@@@分個(gè)位
    MOV P2,#0BFH
    SETB P1.5
    CALL DELAY
    CLR P1.5;@@@@@@@@@@分時(shí)橫杠
    MOV A,HOUR
    MOV B,#16
    DIV AB
    MOVC A,@A+DPTR
    MOV P2,A
    SETB P1.7
    CALL DELAY
    CLR P1.7;@@@@@@@@@@@時(shí)十位
    MOV A,B
    MOVC A,@A+DPTR
    MOV P2,A
    SETB P1.6
    CALL DELAY
    CLR P1.6
    RET
DELAY:     MOV R3,#5
    N1:    MOV R6,#250
           DJNZ R6,$
    DJNZ R3,N1
    RET
ABC: DB 0C0H,0F9H,0A4H,0B0H,99H,92H,82H,0F8H,80H,90H ;碼表
           END
另有ds1302 資料打包
  在此感謝王老師提供的視頻。
ID:20190 發(fā)表于 2010-3-21 10:12 | 只看該作者
DS1302 地址
ID:61326 發(fā)表于 2014-5-4 10:58 | 只看該作者
謝謝你!
