查看: 8533|回復(fù): 1
MSP430F5529驅(qū)動LCD102x64液晶程序及電路圖
ID:89763 發(fā)表于 2015-9-12 20:08 | 顯示全部樓層 |閱讀模式
MSP430F5529開發(fā)板上的102x64LCD采用的是SPI通信模式,即一種全雙工串行通信模式
參考程序:
#include "msp430F5529.h"
void delay(int ms)
  int i;
  while(ms--)
    for(i=0;i<999;i++);
//        寫數(shù)據(jù)函數(shù)         //
void writedata(unsigned char dat)
  char i,temp;
  P5OUT |=BIT7;     //結(jié)束置位
  P5OUT |=BIT6;    //數(shù)據(jù)輸入模式
  P4OUT &=~BIT3;   //sclk=0
  P7OUT &=~BIT4;    //片選選中
  P3OUT |=0x80;
  for(i=0;i<8;i++)
     temp =dat<<i;
     if((temp & 0x80)==0x80)
            P4OUT |=BIT1;
            P4OUT &=~BIT1;
    __delay_cycles(3);
    P4OUT |=BIT3;     //sclk=1上升沿
     __delay_cycles(3);
    P4OUT &=~BIT3;    //下降沿
  P7OUT |=BIT4;  //釋放片選
//        寫指令函數(shù)         //
void writecomd(unsigned char comd)
  char i,temp;
  P5OUT &=~BIT6;    //指令輸入模式并置位
  P4OUT &=~BIT3;
  P3OUT |=0x80;
  for(i=0;i<8;i++)
     temp =comd<<i;
            P4OUT |=BIT1;
            P4OUT &=~BIT1;
    __delay_cycles(3);
    P4OUT |=BIT3;
     __delay_cycles(3);
    P4OUT &=~BIT3;
//       液晶顯示      //
void LCD_XYSet(unsigned char x,unsigned char y)
     LCD_SPISend(0,0xB0|y);           //y的值為0~8
     LCD_SPISend(0,0x10|(x>>4));
     LCD_SPISend(0,0x00|(x&0x0F));
// 顯示   y<8,x<127     //
void LCDdisplay(unsigned char x,unsigned char y)
   writecomd(0xB0|y);
   writecomd(0x10|(x>>4));
   writecomd(0x0F);
//    LCD初始化        //
void LCDinit(void)
   P7DIR |=BIT4+BIT6;             //P7.6為LCD背光燈和LCD_EN使能,1亮 0滅,P7.4為LED_CS片選
   P7OUT |=BIT6;              //點亮背光
   P5DIR |=BIT6+BIT7;         //P5.6為SPI之命令數(shù)據(jù)切換,P5.7為SPI之LCD_RST液晶復(fù)位
   P4DIR |=BIT1+BIT3;        //P4.1為SIMO從設(shè)備輸入主設(shè)備信號端,P4.3為SCK
   UCSCTL3 |=SELREF__REFOCLK;
   P5OUT &=~(BIT6+BIT7);    //LCD reset  指令輸入
   writecomd(0xAF);         //開顯示
   writecomd(0x8c);         //設(shè)置掃描方向。
//  主時鐘設(shè)置       //
void MCLKtimer(void)
   __bis_SR_register(SCG0);     //disable the FLL control loop
   UCSCTL0=0X0000;//            //Set lowest possible DCOx,MODxSCG0
   UCSCTL1=DCORSEL_7;           //Select DCO range 24MHz opreation
                               //DCORSEL_x,其中x可選3、4、5、6、7
   UCSCTL3=FLLD_0+731;          //Set DCO Multiplier for 24MHz
                                //(N+1)*FLLRef=Fdco
                                //(731+1)*32768=24MHz
                               //Set FLL DIV =fDCOCLK/2
   /*__bis_SR_register(SCG0);                 //Enable the FLL control loopSCG0
   UCSCTL4 |=SELA__DCOCLK+SELS__XT1CLK+SELM__DCOCLK;//MCLK Source select
   UCSCTL5 |=DIVPA_2;                       //ACLK output divide
   UCSCTL6 |=XT1DRIVE_3+XCAP_0;             //XT1 cap */
int main( void )
  // Stop watchdog timer to prevent time out reset
  WDTCTL = WDTPW + WDTHOLD;
  MCLKtimer();
  P1DIR |=BIT3;
  P4DIR |=BIT7;
  P5OUT &=~BIT7;
  LCDinit();
  LCDdisplay(3,100);
     writedata(0x2F);
     writedata(0x07);
     writedata(0x18);
     writedata(0x2F);
ID:150645 發(fā)表于 2016-11-27 22:20 | 顯示全部樓層
......沒反映呀
