查看: 2344|回復(fù): 0
眾數(shù) c語言程序
ID:90014 發(fā)表于 2015-9-14 18:40 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <iostream>
#include "stdio.h"
typedef unsigned char uint8_t;
using namespace std;
void putarr(uint8_t *arr,uint8_t Length)
       while(Length--)
              printf("%d ",*arr++);
       printf("\n");
void Stor(uint8_t  *arr,uint8_t Length)
       uint8_t Temp,i,j,k;
       for(i=0;i<Length-1;i++)
              k=i;
              for(j=k+1;j<Length;j++)
                     if(arr[k]<arr[j])
                            k=j;
              if(k!=i)
                     Temp=arr[k];
                     arr[k]=arr;
                     arr=Temp;
uint8_t MM(uint8_t *arr,uint8_t Length) //求眾數(shù)函數(shù)
       uint8_t i;
       uint8_t count=0,max=0,nunber;
       uint8_t cc;
       Stor(arr,Length);
       for(i=1;i<Length;i++)
              arr>arr[i-1]?cc=arr-arr[i-1]:cc=arr[i-1]-arr;
              if(cc==0)
                     count++;
                     count=1;
                     continue;
              if(count>max)
                     nunber=arr;
                     max=count;
       printf("zhong shu =%d\t ci shu shi %d\n",nunber,max);
       return nunber;
int main()
    uint8_t arr[]={1,2,3,12,14,18,2,2,3};
   // Stor(arr,sizeof(arr));
    //putarr(arr,sizeof(arr));
       MM(arr,sizeof(arr));
    return 0;
