查看: 6335|回復(fù): 0
自己寫一個C語言中的printf函數(shù)
ID:90014 發(fā)表于 2015-9-14 18:49 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. #include <stdio.h>
  2. #include <stdlib.h>
  3. #include "stdarg.h"
  4. void PrintInt(unsigned int Num);//輸出正整數(shù)
  5. void PrintString(char *str);//輸出字符串
  6. void PrintInt_2(int Num);//輸出整數(shù)
  7. void PrintBit(int Bit);//輸出二進(jìn)制數(shù)
  8. void PrintFloat(float Num);//輸出浮點數(shù)
  9. void PrintFamt(const char *Format,...);//自己寫的printf
  10. int main()
  11. {
  12.     int x=12;
  13.     float y=12.5;
  14.     char *p="123";
  15.     PrintFamt("x=%d\ty=%f\t*p=%s\n",x,y,p);
  16.     return 0;
  17. }
  18. void PrintBit(int Bit)
  19. {
  20.     char bit;
  21.     for(bit=31;bit>=0;bit--)
  22.     {
  23.         if(Bit&(1<<31))
  24.             PrintChar('1');
  25.         else
  26.             PrintChar('0');
  27.         Bit<<=1;
  28.         PrintChar(' ');
  29.     }
  30. }
  31. void PrintChar(char ch)
  32. {
  33.     fprintf(stdout,"%c",ch);
  34. }
  35. void PrintString(char *str)
  36. {
  37.     while(*str)
  38.         PrintChar(*str++);
  39. }
  40. int Ex(char num)
  41. {
  42.     int Temp=1;
  43.     while(num--)
  44.     {
  45.         Temp*=10;
  46.     }
  47.     return Temp;
  48. }
  49. void PrintInt(unsigned int Num)
  50. {
  51.     unsigned char bit;
  52.     unsigned char number;
  53.     unsigned int Temp=Num;
  54.     unsigned char Length=0;
  55.     if(Num==0)
  56.     {
  57.         PrintChar('0');
  58.         return;
  59.     }
  60.     while(Temp)
  61.     {
  62.         Length++;
  63.         Temp/=10;
  64.     }
  65.     Temp=Num;
  66.     for(bit=0;bit<Length;bit++)
  67.     {
  68.         number=Temp/Ex(Length-bit-1);
  69.         PrintChar(number+'0');
  70.         Temp%=Ex(Length-bit-1);
  71.     }
  72. }
  73. void PrintInt_2(int Num)
  74. {
  75.     if(Num&(1<<31))
  76.     {
  77.         PrintChar('-');
  78.       //  Num=Num&(1<<31);
  79.         PrintInt(~(Num-1));
  80.     }
  81.     else
  82.     {
  83.         PrintInt(Num);
  84.     }
  85. }
  86. void PrintFloat(float Num)
  87. {
  88.     int Temp=(int)Num;
  89.     int fTemp=Ex(6)*(Num-(int)Num);
  90.     PrintInt_2(Temp);
  91.     PrintChar('.');
  92.     if(fTemp&(1<<31))
  93.         PrintInt_2(~(fTemp-1));
  94.     else
  95.     {
  96.         PrintInt_2(fTemp);
  97.     }
  98. }
  99. void PrintFamt(const char *Format,...)
  100. {
  101.     va_list ap;
  102.     va_start(ap,Format);
  103.     while(*Format)
  104.     {
  105.         switch(*Format)
  106.         {
  107.             case '%':{
  108.                 switch(*(Format+1))
  109.                 {
  110.                     case 'd':PrintInt_2(va_arg(ap,int));Format++;break;
  111.                     case 'f':PrintFloat(va_arg(ap,double));Format++;break;
  112.                     case 's':PrintString(va_arg(ap,char*));Format++;break;
  113.                     default:PrintChar('%');break;
  114.                 }
  115.             };break;
  116.             case '\n':PrintChar('\n');break;
  117.             case '\t':PrintChar('\t');break;
  118.             default :PrintChar(*Format);
  119.         }
  120.         Format++;
  121.     }
  122.     va_end(ap);
  123. }
