要編寫CAM350的宏命令,并不是很難的事情,下面的一些命令弄明白的話,再加上自己錄制幾次,實(shí)踐一下,你就能做出自己的宏命令來了。
捕捉當(dāng)前層 a=Blanklayer! 捕捉當(dāng)前D碼 b=Blankdcode!
設(shè)置10號為0.4的圓
set_aperture@ 10,"Round d:0.4000"
update_dcodebar@
清除多余D碼
aptable_compress@
update_dcodebar@
update_dcodebar@
update_dcodebar@
back@
單一選擇菜單
k%=10
OpenForm #1,25,10, "挑各類焊盤 2005-1-27 QMZ ", character, okcancel
AddForm #1, 0, 0, "★QMZ編制 保護(hù)版權(quán)★",Print
AddForm #1, 0, 1, "選擇焊盤形狀",CHOICE, k%, "1=圓形", "2=矩形", "3=方形", "4=標(biāo)靶", "5=花環(huán)形", "6=自定義", "7=同心圓", "8=多邊形", "9=橢圓形", "10=SMT Pad"
DisplayForm #1
Canceled% = formCancel(1)
DeleteForm #1
if Canceled% then goto 999
多重選擇菜單
k%=2
OpenForm #1,30,9, "挑各類焊盤 2005-1-28 保護(hù)版權(quán) QMZ ", character, okcancel
AddForm #1, 15, 0, "★★QMZ編制 ★★",Print
AddForm #1, 15, 1, "選擇模式", Choice, k%, "SMT Pad", "普通模式"
AddForm #1, 0, 0, "1=Round", Check, A1%
AddForm #1, 0, 1, "2=Square", Check, A2%
AddForm #1, 0, 2, "3=Rectangle", Check, A3%
AddForm #1, 0, 3, "4=Target", Check, A4%
AddForm #1, 0, 4, "5=Thermal", Check, A5%
AddForm #1, 0, 5, "6=Custom", Check, A6%
AddForm #1, 0, 6, "7=Donut", Check, A7%
AddForm #1, 0, 7, "8=Octagon", Check, A8%
AddForm #1, 0, 8, "9=Oblong", Check, A9%
DisplayForm #1
DeleteForm #1
}2 q4 P) a! x* w/ t1 Z2 M, B 9 H* S7 H C! D$ s) Z" ^
a=Blanklayer! '設(shè)A=空層的ID數(shù)
b=Blankdcode! '設(shè)B=空D碼數(shù)
edit_layer@ a,1,1,4,0,"wokao" '增加一新層。A=層ID;1=線路顏色;1=焊盤顏色;4=層屬性,
'0=顯示狀態(tài);wokao=層名
setlayer@ a '設(shè)A為當(dāng)前層
edit_aperture@ b,1,0.200,0.200,b,"" '增加一新D碼。B=D碼號;1=圓形;0.200=X軸大�。�
'0.200=Y軸大小;B=D碼號;""=預(yù)留一空D碼號
update_dcodebar@ '更新D碼條
add_text@ '增加文字
addtext@ 0,0,time! '將系統(tǒng)時(shí)間寫在原點(diǎn)處。0=X軸坐標(biāo);0=Y軸坐標(biāo);time!=系統(tǒng)時(shí)間
back@ '命令結(jié)束
view_all@ '顯示所有
a=Blanklayer!
b=Blankdcode!
ts$=Dbname! '設(shè)當(dāng)前文件的文件名和路徑=ts$
ts$=UCASE$(ts$) '將所有字符轉(zhuǎn)換成大寫
ts1$=mid$(ts$,17) '從第17位字符開始取完
ts$=ts1$ '設(shè)取到的字符=ts$
tstr1$="^ "+ts$ '字符#
setlayer@ a
update_dcodebar@
add_text@
addtext@ 0,0,tstr1$
back@
view_all@
a=Blanklayer!
b=Blankdcode!
Input "請輸入生產(chǎn)型號", xh1$ '顯示一個(gè)輸入框,要求輸入型號
if xh1$="" then goto 100 '如果輸入的是空字符傳就轉(zhuǎn)到100
xh1$=UCASE$(xh1$) '將輸入的字符轉(zhuǎn)換成大寫
xh$="^ "+xh1$ '字符#
setlayer@ a
update_dcodebar@
add_text@
addtext@ 0,0,xh$
back@
view_all@
100 end '結(jié)束
OpenForm #1, 30, 8, "窗體按鈕", character, YESNO '創(chuàng)建窗體,1號窗體,寬30,高8,標(biāo)題,單位,按鈕
DisplayForm #1 '顯示1號窗體
下面我們來介紹一下CAM350宏里面的按鈕:
OK 只有一個(gè)按鈕“OK”。
OKCANCEL 兩個(gè)按鈕“OK”、“CANCEL”。
YESNO 兩個(gè)按鈕“YES”、“NO”。
NEXTCANCEL 兩個(gè)按鈕“NEXT”、“CANCEL”。
YESNOCANCEL 三個(gè)按鈕“YES”、“NO”、“CANCEL”。
PREVFINISH 三個(gè)按鈕“Previous”、“Finish”、“Cancel”。
NEXTFINISH 三個(gè)按鈕“NEXT”、“FINISH”、“CANCEL”。
PREVNEXT 三個(gè)按鈕“PREVIOUS”、“NEXT”、“CANCEL”。
PREVNEXTFINISH 四個(gè)按鈕“OREVIOUS”、“NEXT”、“FINISH”、“CANCEL”。
MessageBox "消息框按鈕、圖標(biāo)及返回值","消息框",YESNO,N% '顯示消息框,消息內(nèi)容,標(biāo)題,按鈕和圖標(biāo),返回值
if N% = 6 then end '如果返回值=6就結(jié)束宏
按鈕和圖標(biāo)
INFORMATION = OK 按鈕和小寫字母 i圖標(biāo)
WARNING = OK 按鈕和感嘆號圖標(biāo)
ERROR = OK 按鈕和停止標(biāo)記圖標(biāo)
OKCANCEL = OK 和 CANCEL 按鈕,問號圖標(biāo)
YESNO = YES 和 NO 按鈕,問號圖標(biāo)
YESNOCANCEL = YES, NO, 和 CANCEL 按鈕,問號圖標(biāo)
RETRYCANCEL = RETRY 和 CANCEL 按鈕, 問號圖標(biāo)
返回值:
1 OK
2 Cancel
3 Abort
4 Retry
5 Ignore
6 Yes
7 No
'Set variables: '設(shè)置變量
label1$ = "This is an eighty character string to be used as a test for the Print command."
'設(shè)置label1$的默認(rèn)字符串
i% = 4 '設(shè)i%的默認(rèn)值為:4
d# = 12345.678 '設(shè)d#的默認(rèn)值為:12345.678
s$ = "The quick brown fox" '設(shè)s$的默認(rèn)字符串為:"The quick brown fox"
j% = 1 '設(shè)j%的默認(rèn)值為:1
k% = 2 '設(shè)k%的默認(rèn)值為:2
filename$ = "" '設(shè)filename$為空字符串
OpenForm #1, 50, 12, "Test form", character, yesnocancel
'新建1號窗體,寬50,高12,標(biāo)題"Test form",單位character,按鈕yesnocancel
AddForm #1, 0, 0, "Integer:", INPUT, i%, 0 to 10
'新增一輸入框,距左邊0,距頂邊0,顯示"Integer:",輸入命令,變量i%,范圍0 to 10
AddForm #1, 0, 1, "Real : ", INPUT, d#
'新增一輸入框,距左邊0,距頂邊1,顯示"Real : ",輸入命令,變量d#
AddForm #1, 0, 2, "String :", INPUT, s$
'新增一輸入框,距左邊0,距頂邊2,顯示"String :",輸入命令,變量ds$
AddForm #1, 1, 3, "Check:", CHECK, j%
'新增一復(fù)選框,距左邊1,距頂邊3,顯示"Check:",復(fù)選命令,j%=1為選中狀態(tài)
AddForm #1, 2, 4, "Choice", CHOICE, k%, "Choice One", "Choice Two", "Choice Three"
'新增一單選框,距左邊2,距頂邊4,顯示"Choice",單選命令,k%=2默認(rèn)選中第二項(xiàng),選項(xiàng)……
AddForm #1, 0, 8, label1$, PRINT
'新增一標(biāo)簽,距左邊0,距頂邊8,標(biāo)簽內(nèi)容,顯示命令
AddForm #1, 2, 10, "Open File", GETOPENFILENAME, filename$
'新增一打開文件框,距左邊2,距頂邊10,顯示"Open File",打開文件命令,filename$默認(rèn)為空字符串
if formcancel(1) then goto skipit '如果按CANCEL按鈕就執(zhí)行skipit那一行
'Set strings for print statement: '將數(shù)值轉(zhuǎn)換成字符串
i$ = str$(i%)
d$ = str$(d#)
j$ = str$(j%)
k$ = str$(k%)
print "i% = ",i$+cr!+"d# = ",d$+cr!+"s$ = "+quote!+s$+quote!+cr!+"Check = ",j$+cr!+"Choice = ",k$+cr!+"File = ",filename$
'顯示各項(xiàng)內(nèi)容
skipit: '標(biāo)號
DeleteForm #1 '刪除1號窗體
End '結(jié)束
88
print_msg "退出宏!"
delay 1000
end
