查看: 4067|回復(fù): 0
STM32 實(shí)時時鐘RTC原理和編程要旨
ID:91350 發(fā)表于 2015-10-29 19:03 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
   RTC是工業(yè)領(lǐng)域?qū)崟r控制離不開的一個外設(shè),相當(dāng)于一個獨(dú)立的定時器,STM32的RTC外設(shè)由一組連續(xù)計(jì)數(shù)的計(jì)數(shù)器組成,具體來說,由兩個部分組成:第一部分指APB1接口用來和APB1總線相連,此單元還包含一組1位寄存器,可通過APB1總線對其進(jìn)行讀寫操作,APB1接口由APB1總線時鐘驅(qū)動,用來與APB1總線相連;另一部分由一組可編程計(jì)數(shù)器組成,主要分為兩個模塊:第一個模塊為RTC的預(yù)分頻模塊,它可編程產(chǎn)生最長為1s的RTC時間基準(zhǔn)TR_CLK,RTC的預(yù)分頻模塊包含了一個20位的可編程分頻器(RTC預(yù)分頻器),如果在RTC_CR寄存器中設(shè)置了相應(yīng)的允許位,則在每個TR_CLK周期中RTC產(chǎn)生一個中斷,即所謂的秒中斷;第二個模塊是一個32位的可編程計(jì)數(shù)器,可被初始化為當(dāng)前的系統(tǒng)時間。系統(tǒng)時間按TR_CLK周期累加并與存儲在RTC_ALR寄存器中的可編程時間相比較,如果TR_CLK控制寄存器中設(shè)置了相應(yīng)允許位,比較匹配時將產(chǎn)生一個鬧鐘中斷,具體見下圖所示;
#include "stm32f10x_lib.h"
#include "platform_config.h"
#include
vu32 TimeDisplay = 0;
u32 hour = 0, minute = 0, second = 0;
void RCC_Configuration(void);
void GPIO_Configuration(void);
void RTC_Configuration(void);
void NVIC_Configuration(void);
void Time_Adjust(void);
void Time_Display(u32 TimeVar);
void Time_Regulate(u32 Tmp_HH,u32 Tmp_MM,u32 Tmp_SS);
int main(void)
  RCC_Configuration();
  NVIC_Configuration();
  GPIO_Configuration();
  RTC_Configuration();
  if (BKP_ReadBackupRegister(BKP_DR1) !=0xA5A5)
   Time_Adjust();
   BKP_WriteBackupRegister(BKP_DR1, 0xA5A5);
   RTC_WaitForSynchro();
   RTC_ITConfig(RTC_IT_SEC, ENABLE);
   RTC_WaitForLastTask();
   Time_Regulate(12,45,30);
  while (1)
    if(TimeDisplay == 1)
     Time_Display(RTC_GetCounter());
     TimeDisplay = 0;
  ErrorStatus HSEStartUpStatus;
  RCC_DeInit();
  RCC_HSEConfig(RCC_HSE_ON);
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if (HSEStartUpStatus == SUCCESS)
   FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
   FLASH_SetLatency(FLASH_Latency_2);
   RCC_HCLKConfig(RCC_SYSCLK_Div1);
   RCC_PCLK2Config(RCC_HCLK_Div1);
   RCC_PCLK1Config(RCC_HCLK_Div2);
   RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
   RCC_PLLCmd(ENABLE);
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
   RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    while(RCC_GetSYSCLKSource() != 0x08)
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|
                        RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC , ENABLE);
  NVIC_InitTypeDef NVIC_InitStructure;
#ifdef  VECT_TAB_RAM
  NVIC_SetVectorTable(NVIC_VectTab_RAM,0x0);
#else
  NVIC_SetVectorTable(NVIC_VectTab_FLASH,0x0);
#endif
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  NVIC_InitStructure.NVIC_IRQChannel =RTC_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority =0;
  NVIC_InitStructure.NVIC_IRQChannelCmd =ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
  GPIO_InitStructure.GPIO_Mode =GPIO_Mode_Out_PP;
  GPIO_InitStructure.GPIO_Speed =GPIO_Speed_50MHz;
  GPIO_Init(GPIO_LED,&GPIO_InitStructure);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR |RCC_APB1Periph_BKP, ENABLE);
  PWR_BackupAccessCmd(ENABLE);
  BKP_DeInit();
  RCC_LSEConfig(RCC_LSE_ON);
  while (RCC_GetFlagStatus(RCC_FLAG_LSERDY) ==RESET)
  RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE);
  RCC_RTCCLKCmd(ENABLE);
  RTC_SetPrescaler(32767);
  RTC_SetCounter(0);
  u32 RTC_Counter;
  RTC_Counter = Tmp_HH*3600 + Tmp_MM*60 +Tmp_SS;
  RTC_SetCounter(RTC_Counter);
  hour = TimeVar / 3600;
  minute = (TimeVar % 3600) / 60;
  second = (TimeVar % 3600) % 60;
