本帖最后由 piaolin 于 2015-10-29 19:52 編輯
描述:用ADC連續(xù)采集11路模擬信號,并由DMA傳輸?shù)絻?nèi)存。ADC配置為掃描并且連續(xù)轉(zhuǎn)換模式,ADC的時鐘配置為12MHZ。在每次轉(zhuǎn)換結(jié)束后,由DMA循環(huán)將轉(zhuǎn)換的數(shù)據(jù)傳輸?shù)絻?nèi)存中。ADC可以連續(xù)采集N次求平均值。最后通過串口傳輸出最后轉(zhuǎn)換的結(jié)果。
程序如下:
- #i nclude "stm32f10x.h" //這個頭文件包括STM32F10x所有外圍寄存器、位、內(nèi)存映射的定義
- #i nclude "eval.h" //頭文件(包括串口、按鍵、LED的函數(shù)聲明)
- #i nclude "SysTickDelay.h"
- #i nclude "UART_INTERFACE.h"
- #i nclude <stdio.h>
- #define N 50 //每通道采50次
- #define M 12 //為12個通道
- vu16 AD_Value[N][M]; //用來存放ADC轉(zhuǎn)換結(jié)果,也是DMA的目標(biāo)地址
- vu16 After_filter[M]; //用來存放求平均值之后的結(jié)果
- int i;
- void GPIO_Configuration(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //因?yàn)閁SART1管腳是以復(fù)用的形式接到GPIO口上的,所以使用復(fù)用推挽式輸出
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
- //PA0/1/2 作為模擬通道輸入引腳
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0| GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //模擬輸入引腳
- //PB0/1 作為模擬通道輸入引腳
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- //PC0/1/2/3/4/5 作為模擬通道輸入引腳
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;
- GPIO_Init(GPIOC, &GPIO_InitStructure);
- void RCC_Configuration(void)
- ErrorStatus HSEStartUpStatus;
- RCC_DeInit(); //RCC 系統(tǒng)復(fù)位
- RCC_HSEConfig(RCC_HSE_ON); //開啟HSE
- HSEStartUpStatus = RCC_WaitForHSEStartUp(); //等待HSE準(zhǔn)備好
- if(HSEStartUpStatus == SUCCESS)
- FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); //Enable Prefetch Buffer
- FLASH_SetLatency(FLASH_Latency_2); //Set 2 Latency cycles
- RCC_HCLKConfig(RCC_SYSCLK_Div1); //AHB clock = SYSCLK
- RCC_PCLK2Config(RCC_HCLK_Div1); //APB2 clock = HCLK
- RCC_PCLK1Config(RCC_HCLK_Div2); //APB1 clock = HCLK/2
- RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_6); //PLLCLK = 12MHz * 6 = 72 MHz
- RCC_PLLCmd(ENABLE); //Enable PLL
- while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); //Wait till PLL is ready
- RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); //Select PLL as system clock source
- while(RCC_GetSYSCLKSource() != 0x08); //Wait till PLL is used as system clock source
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB
- | RCC_APB2Periph_GPIOC |RCC_APB2Periph_ADC1 | RCC_APB2Periph_AFIO |RCC_APB2Periph_USART1, ENABLE ); //使能ADC1通道時鐘,各個管腳時鐘
- RCC_ADCCLKConfig(RCC_PCLK2_Div6); //72M/6=12,ADC最大時間不能超過14M
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); //使能DMA傳輸
- void ADC1_Configuration(void)
- ADC_InitTypeDef ADC_InitStructure;
- ADC_DeInit(ADC1); //將外設(shè) ADC1 的全部寄存器重設(shè)為缺省值
- ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; //ADC工作模式:ADC1和ADC2工作在獨(dú)立模式
- ADC_InitStructure.ADC_ScanConvMode =ENABLE; //模數(shù)轉(zhuǎn)換工作在掃描模式
- ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //模數(shù)轉(zhuǎn)換工作在連續(xù)轉(zhuǎn)換模式
- ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; //外部觸發(fā)轉(zhuǎn)換關(guān)閉
- ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //ADC數(shù)據(jù)右對齊
- ADC_InitStructure.ADC_NbrOfChannel = M; //順序進(jìn)行規(guī)則轉(zhuǎn)換的ADC通道的數(shù)目
- ADC_Init(ADC1, &ADC_InitStructure); //根據(jù)ADC_InitStruct中指定的參數(shù)初始化外設(shè)ADCx的寄存器
- //設(shè)置指定ADC的規(guī)則組通道,設(shè)置它們的轉(zhuǎn)化順序和采樣時間
- //ADC1,ADC通道x,規(guī)則采樣順序值為y,采樣時間為239.5周期
- ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_239Cycles5 );
- ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_239Cycles5 );
- ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_239Cycles5 );
- ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 4, ADC_SampleTime_239Cycles5 );
- ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 5, ADC_SampleTime_239Cycles5 );
- ADC_RegularChannelConfig(ADC1, ADC_Channel_9, 6, ADC_SampleTime_239Cycles5 );
- ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 7, ADC_SampleTime_239Cycles5 );
- ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 8, ADC_SampleTime_239Cycles5 );
- ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 9, ADC_SampleTime_239Cycles5 );
- ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 10, ADC_SampleTime_239Cycles5 );
- ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 11, ADC_SampleTime_239Cycles5 );
- ADC_RegularChannelConfig(ADC1, ADC_Channel_15, 12, ADC_SampleTime_239Cycles5 );
- // 開啟ADC的DMA支持(要實(shí)現(xiàn)DMA功能,還需獨(dú)立配置DMA通道等參數(shù))
- ADC_DMACmd(ADC1, ENABLE);
- ADC_Cmd(ADC1, ENABLE); //使能指定的ADC1
- ADC_ResetCalibration(ADC1); //復(fù)位指定的ADC1的校準(zhǔn)寄存器
- while(ADC_GetResetCalibrationStatus(ADC1)); //獲取ADC1復(fù)位校準(zhǔn)寄存器的狀態(tài),設(shè)置狀態(tài)則等待
- ADC_StartCalibration(ADC1); //開始指定ADC1的校準(zhǔn)狀態(tài)
- while(ADC_GetCalibrationStatus(ADC1)); //獲取指定ADC1的校準(zhǔn)程序,設(shè)置狀態(tài)則等待
- void DMA_Configuration(void)
- DMA_InitTypeDef DMA_InitStructure;
- DMA_DeInit(DMA1_Channel1); //將DMA的通道1寄存器重設(shè)為缺省值
- DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&ADC1->DR; //DMA外設(shè)ADC基地址
- DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&AD_Value; //DMA內(nèi)存基地址
- DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //內(nèi)存作為數(shù)據(jù)傳輸?shù)哪康牡?br />
- DMA_InitStructure.DMA_BufferSize = N*M; //DMA通道的DMA緩存的大小
- DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //外設(shè)地址寄存器不變
- DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //內(nèi)存地址寄存器遞增
- DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //數(shù)據(jù)寬度為16位
- DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //數(shù)據(jù)寬度為16位
- DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //工作在循環(huán)緩存模式
- DMA_InitStructure.DMA_Priority = DMA_Priority_High; //DMA通道 x擁有高優(yōu)先級
- DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //DMA通道x沒有設(shè)置為內(nèi)存到內(nèi)存?zhèn)鬏?br />
- DMA_Init(DMA1_Channel1, &DMA_InitStructure); //根據(jù)DMA_InitStruct中指定的參數(shù)初始化DMA的通道
- //配置所有外設(shè)
- void Init_All_Periph(void)
- RCC_Configuration();
- GPIO_Configuration();
- ADC1_Configuration();
- DMA_Configuration();
- //USART1_Configuration();
- USART_Configuration(9600);
- u16 GetVolt(u16 advalue)
- return (u16)(advalue * 330 / 4096); //求的結(jié)果擴(kuò)大了100倍,方便下面求出小數(shù)
- void filter(void)
- int sum = 0;
- u8 count;
- for(i=0;i<12;i++)
- for ( count=0;count<N;count++)
- sum += AD_Value[count][i];
- After_filter[i]=sum/N;
- sum=0;
- int main(void)
- u16 value[M];
- init_All_Periph();
- SysTick_Initaize();
- ADC_SoftwareStartConvCmd(ADC1, ENABLE);
- DMA_Cmd(DMA1_Channel1, ENABLE); //啟動DMA通道
- while(1)
- while(USART_GetFlagStatus(USART1,USART_FLAG_TXE)==RESET);//等待傳輸完成否則第一位數(shù)據(jù)容易丟失
- filter();
- for(i=0;i<12;i++)
- value[i]= GetVolt(After_filter[i]);
- printf("value[%d]:t%d.%dvn",i,value[i]/100,value[i]0) ;
- delay_ms(100);
總結(jié)
該程序中的兩個宏定義,M和N,分別代表有多少個通道,每個通道轉(zhuǎn)換多少次,可以修改其值。
曾出現(xiàn)的問題:配置時鐘時要知道外部晶振是多少,以便準(zhǔn)確配置時鐘。將轉(zhuǎn)換值由二進(jìn)制轉(zhuǎn)換為十進(jìn)制時,要先擴(kuò)大100倍,方便顯示小數(shù)。最后串口輸出時在printf語句之前加這句代碼,防止輸出的第一位數(shù)據(jù)丟失:while(USART_GetFlagStatus(USART1,USART_FLAG_TXE)==RESET); |
