查看: 9274|回復(fù): 8
51單片機(jī)2塊74hc595移位寄存器控制16*16LED點(diǎn)陣程序
ID:11064 發(fā)表于 2015-11-3 21:13 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <REG51.H>
//--重定義函數(shù)變量--//
#define uint  unsigned int
#define ulong unsigned long
//--定義SPI要使用的 IO--//
sbit MOSIO = P3^4;
sbit R_CLK = P3^5;
sbit S_CLK = P3^6;
//---全局變量聲明--//
ulong column;   //點(diǎn)陣列
ulong row;      //點(diǎn)陣行
ulong dt;
//--點(diǎn)陣顯示數(shù)組--//
uchar code tab0[] =
{0x00, 0x01, 0x00, 0x02, 0x00, 0x04, 0x00, 0x08,
0x00, 0x10, 0x00, 0x20, 0x00, 0x40, 0x00, 0x80,
0x01, 0x00, 0x02, 0x00, 0x04, 0x00, 0x08, 0x00,
0x10, 0x00, 0x20, 0x00, 0x40, 0x00, 0x80, 0x00};
//--10字模--//
uchar code tab1[] =
{0, 0, 0, 0, 0, 0, 8, 24, 14, 36, 8, 66, 8, 66, 8, 66,
8, 66, 8, 66, 8, 66, 8, 36, 62, 24, 0, 0, 0, 0, 0, 0};
//--09字模--//
uchar code tab2[] =
{0, 0, 0, 0, 0, 0, 24, 24, 36, 36, 66, 66, 66, 66, 66,
66, 66, 100, 66, 88, 66, 64, 66, 64, 36, 36, 24, 28, 0, 0, 0, 0} ;
//--08字模--//
uchar code tab3[] =
{0, 0, 0, 0, 0, 0, 24, 60, 36, 66, 66, 66, 66, 66, 66, 36,
66, 24, 66, 36, 66, 66, 66, 66, 36, 66, 24, 60, 0, 0, 0, 0};
//--07字模--//
uchar code tab4[] =
{0, 0, 0, 0, 0, 0, 24, 126, 36, 34, 66, 34, 66, 16, 66, 16,
66, 8, 66, 8, 66, 8, 66, 8, 36, 8, 24, 8, 0, 0, 0, 0};
//--06字模--//
uchar code tab5[] =
{0, 0, 0, 0, 0, 0, 24, 56, 36, 36, 66, 2, 66, 2, 66, 26, 66,
38, 66, 66, 66, 66, 66, 66, 36, 36, 24, 24, 0, 0, 0, 0};
//--05字模--//
uchar code tab6[] =
{0, 0, 0, 0, 0, 0, 24, 126, 36, 2, 66, 2, 66, 2, 66, 26, 66,
38, 66, 64, 66, 64, 66, 66, 36, 34, 24, 28, 0, 0, 0, 0};
//--04字模--//
uchar code tab7[] =
{0, 0, 0, 0, 0, 0, 24, 32, 36, 48, 66, 40, 66, 36, 66, 36, 66,
34, 66, 34, 66, 126, 66, 32, 36, 32, 24, 120, 0, 0, 0, 0};
//--03字模--//
uchar code tab8[] =
{0, 0, 0, 0, 0, 0, 24, 60, 36, 66, 66, 66, 66, 32, 66, 24, 66,
32, 66, 64, 66, 64, 66, 66, 36, 34, 24, 28, 0, 0, 0, 0};
//--02字模--//
uchar code tab9[] =
{0, 0, 0, 0, 0, 0, 24, 60, 36, 66, 66, 66, 66, 66, 66, 32, 66,
32, 66, 16, 66, 8, 66, 4, 36, 66, 24, 126, 0, 0, 0, 0};
//--01字模--//
uchar code tab10[] =
{0, 0, 0, 0, 0, 0, 24, 8, 36, 14, 66, 8, 66, 8, 66, 8, 66, 8, 66,
8, 66, 8, 66, 8, 36, 8, 24, 62, 0, 0, 0, 0};
//--00字模--//
uchar code tab11[] =
{0, 0, 0, 0, 0, 0, 24, 24, 36, 36, 66, 66, 66, 66, 66, 66, 66, 66,
//--GO--//
uchar code tab12[] =
{0, 0, 0, 0, 0, 0, 60, 28, 34, 34, 34, 65, 1, 65, 1, 65, 1, 65, 113,
65, 33, 65, 34, 65, 34, 34, 28, 28, 0, 0, 0, 0};
//--全局函數(shù)聲明--//
void HC595SendData(  uchar BT3, uchar BT2,uchar BT1,uchar BT0);
* 函 數(shù) 名         : main
* 函數(shù)功能                   : 主函數(shù)
* 輸    入         : 無
* 輸    出         : 無
void main(void)
        int k, i, ms;
        i = 60;                                        //顯示時(shí)間
                //--顯示10--//
                for(ms = i; ms > 0; ms--)
                        for(k = 0; k < 16; k++)
                        HC595SendData(~tab1[2*k +1],~tab1[2*k],tab0[2*k],tab0[2*k + 1]);
                //--清屏--//
                HC595SendData(0xff,0xff,0,0);
                //--顯示09--//
                                HC595SendData(~tab2[2*k +1],~tab2[2*k],tab0[2*k],tab0[2*k + 1]);
                //--清屏--//
                //--顯示08--//
                                HC595SendData(~tab3[2*k +1],~tab3[2*k],tab0[2*k],tab0[2*k + 1]);
                //--清屏--//
                //--顯示07--//
                                HC595SendData(~tab4[2*k +1],~tab4[2*k],tab0[2*k],tab0[2*k + 1]);
                //--清屏--//
                //--顯示06--//
                                HC595SendData(~tab5[2*k +1],~tab5[2*k],tab0[2*k],tab0[2*k + 1]);
                //--清屏--//
            //--顯示05--//
                        for(k = 0; k < 16; k++)        //歡
                                HC595SendData(~tab6[2*k +1],~tab6[2*k],tab0[2*k],tab0[2*k + 1]);
                //--清屏--//
            //--顯示04--//
                                HC595SendData(~tab7[2*k +1],~tab7[2*k],tab0[2*k],tab0[2*k + 1]);
                //--清屏--//
                //--顯示03--//
                                HC595SendData(~tab8[2*k +1],~tab8[2*k],tab0[2*k],tab0[2*k + 1]);
                //--清屏--//
                //--顯示02--//
                                HC595SendData(~tab9[2*k +1],~tab9[2*k],tab0[2*k],tab0[2*k + 1]);
                //--清屏--//
                //--顯示01--//
                                HC595SendData(~tab10[2*k +1],~tab10[2*k],tab0[2*k],tab0[2*k + 1]);
                //--清屏--//
                //--顯示00--//
                                HC595SendData(~tab11[2*k +1],~tab11[2*k],tab0[2*k],tab0[2*k + 1]);
                //--清屏--//
                HC595SendData(0xff,0xff,0,0);        //清屏
            //--一直顯示G0--//
                        for(k = 0; k < 16; k++)        //中
                                HC595SendData(~tab12[2*k +1],~tab12[2*k],tab0[2*k],tab0[2*k + 1]);
* 函 數(shù) 名         : HC595SendData
* 函數(shù)功能                   : 通過595發(fā)送四個(gè)字節(jié)的數(shù)據(jù)
* 輸    入         : BT3:第四個(gè)595輸出數(shù)值
*                  * BT2: 第三個(gè)595輸出數(shù)值
*                  * BT1:第二個(gè)595輸出數(shù)值
*                  * BT0:第一個(gè)595輸出數(shù)值
* 輸    出         : 無
        uchar i;
        //--發(fā)送第一個(gè)字節(jié)--//
        for(i=0;i<8;i++)
                MOSIO = BT3 >> 7 ;        //從高位到低位
                BT3 <<= 1;
                S_CLK = 0;
                S_CLK = 1;
        for(i=0;i<8;i++)
                MOSIO = BT2 >>7;                //從高位到低位
                BT2 <<= 1;
                S_CLK = 0;
                S_CLK = 1;
        for(i=0;i<8;i++)
                MOSIO = BT1 >> 7;                //從高位到低位
                BT1 <<= 1;
                S_CLK = 0;
                S_CLK = 1;
        for(i=0;i<8;i++)
                MOSIO = BT0 >> 7;                //從高位到低位
                BT0 <<= 1;
                S_CLK = 0;
                S_CLK = 1;
        //--輸出--//
        R_CLK = 0; //set dataline low
        R_CLK = 1; //片選
ID:1 發(fā)表于 2015-11-3 21:27 來自觸屏版 | 只看該作者
樓主最好說明一下這個(gè)程序是干什么的?另外最好還是有個(gè)電路圖
ID:92665 發(fā)表于 2015-11-4 11:33 | 只看該作者
寫的很辛苦 下來看看
ID:74441 發(fā)表于 2016-4-18 18:40 | 只看該作者
這是普中科技的
ID:120469 發(fā)表于 2016-5-13 08:59 來自觸屏版 | 只看該作者
樓主有點(diǎn)圖仿真圖嗎
ID:117053 發(fā)表于 2016-5-16 20:54 | 只看該作者
這個(gè)程序有什么作用?
ID:165107 發(fā)表于 2017-2-17 14:51 | 只看該作者
沒電路,原理呢
ID:165792 發(fā)表于 2017-3-25 08:04 來自觸屏版 | 只看該作者
學(xué)習(xí)了,不錯(cuò)不錯(cuò)
