關(guān)鍵是頻譜,通過輸出不同頻率的方波產(chǎn)生不同音色。
- #include <AT89X51.H>
- unsigned char code table[]={0x3f,0x06,0x5b,0x4f,
- 0x66,0x6d,0x7d,0x07,
- 0x7f,0x6f,0x77,0x7c,
- 0x39,0x5e,0x79,0x71};
- unsigned char temp;
- unsigned char key;
- unsigned char i,j;
- unsigned char STH0;
- unsigned char STL0;
- unsigned int code tab[]={64021,64103,64260,64400,
- 64524,64580,64684,64777,
- 64820,64898,64968,65030,
- 65058,65110,65157,65178};
- void main(void)
- TMOD=0x01;
- ET0=1;
- EA=1;
- while(1)
- P3=0xff;
- P3_4=0;
- temp=P3;
- temp=temp & 0x0f;
- if (temp!=0x0f)
- for(i=50;i>0;i--)
- for(j=200;j>0;j--);
- temp=P3;
- temp=temp & 0x0f;
- if (temp!=0x0f)
- temp=P3;
- temp=temp & 0x0f;
- switch(temp)
- case 0x0e:
- key=0;
- break;
- case 0x0d:
- key=1;
- break;
- case 0x0b:
- key=2;
- break;
- case 0x07:
- key=3;
- break;
- temp=P3;
- P1_0=~P1_0;
- P0=table[key];
- STH0=tab[key]/256;
- STL0=tab[key]%256;
- TR0=1;
- temp=temp & 0x0f;
- while(temp!=0x0f)
- temp=P3;
- temp=temp & 0x0f;
- TR0=0;
- P3=0xff;
- P3_5=0;
- temp=P3;
- temp=temp & 0x0f;
- if (temp!=0x0f)
- for(i=50;i>0;i--)
- temp=P3;
- temp=temp & 0x0f;
- if (temp!=0x0f)
- temp=P3;
- temp=temp & 0x0f;
- switch(temp)
- case 0x0e:
- key=4;
- break;
- case 0x0d:
- key=5;
- break;
- case 0x0b:
- key=6;
- break;
- case 0x07:
- key=7;
- break;
- temp=P3;
- P1_0=~P1_0;
- P0=table[key];
- TR0=1;
- temp=temp & 0x0f;
- while(temp!=0x0f)
- temp=P3;
- temp=temp & 0x0f;
- TR0=0;
- P3=0xff;
- P3_6=0;
- temp=P3;
- temp=temp & 0x0f;
- if (temp!=0x0f)
- for(i=50;i>0;i--)
- temp=P3;
- temp=temp & 0x0f;
- if (temp!=0x0f)
- temp=P3;
- temp=temp & 0x0f;
- switch(temp)
- case 0x0e:
- key=8;
- break;
- case 0x0d:
- key=9;
- break;
- case 0x0b:
- key=10;
- break;
- case 0x07:
- key=11;
- break;
- temp=P3;
- P1_0=~P1_0;
- P0=table[key];
- TR0=1;
- temp=temp & 0x0f;
- while(temp!=0x0f)
- temp=P3;
- temp=temp & 0x0f;
- TR0=0;
- P3=0xff;
- P3_7=0;
- temp=P3;
- temp=temp & 0x0f;
- if (temp!=0x0f)
- for(i=50;i>0;i--)
- temp=P3;
- temp=temp & 0x0f;
- if (temp!=0x0f)
- temp=P3;
- temp=temp & 0x0f;
- switch(temp)
- case 0x0e:
- key=12;
- break;
- case 0x0d:
- key=13;
- break;
- case 0x0b:
- key=14;
- break;
- case 0x07:
- key=15;
- break;
- temp=P3;
- P1_0=~P1_0;
- P0=table[key];
- TR0=1;
- temp=temp & 0x0f;
- while(temp!=0x0f)
- temp=P3;
- temp=temp & 0x0f;
- TR0=0;
- void t0(void) interrupt 1 using 0
- TH0=STH0;
- TL0=STL0;
- P1_0=~P1_0;
電子琴.rar
2015-11-11 20:12 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
24.26 KB, 下載次數(shù): 26, 下載積分: 黑幣 -5
