#include<intrins.h>
#include<math.h>
#include<string.h>
struct PID
unsigned int SetPoint ;
// 設(shè)定目標(biāo) Desired Value
unsigned int Proportion ;
// 比例常數(shù) Proportional Const
unsigned int Integral ;
// 積分常數(shù) Integral Const
unsigned int Derivative ;
// 微分常數(shù) Derivative Const
unsigned int LastError ;
// Error[-1]
unsigned int PrevError ;
// Error[-2]
unsigned int SumError ;
// Sums of Errors
struct PID spid ;
// PID Control Structure
unsigned int rout ;
// PID Response (Output)
unsigned int rin ;
// PID Feedback (Input)
unsigned int set_temper,temper,s ;
sbit output=P3^4;
unsigned char high_time,low_time,count=0 ;
//占空比調(diào)節(jié)參數(shù)
void PIDInit(struct PID*pp)
memset(pp,0,sizeof(struct PID)); //PID參數(shù)初始化全部設(shè)置為0
unsigned int PIDCalc(struct PID*pp,unsigned int NextPoint)
unsigned int dError,Error ;
Error=pp->SetPoint-NextPoint ;
// 偏差
pp->SumError+=Error ;
// 積分
dError=pp->LastError-pp->PrevError ;
// 當(dāng)前微分
pp->PrevError=pp->LastError ;
pp->LastError=Error ;
//比例
//積分項(xiàng)
return(pp->Proportion*Error+pp->Integral*pp->SumError+pp->Derivative*dError);
// 微分項(xiàng)
溫度比較處理子程序
void compare_temper(unsigned int set_temper,unsigned int temper)
unsigned char i ;
//EA=0;
if(set_temper>temper)
if(set_temper-temper>10)
high_time=100 ; //大于1°不進(jìn)行PID運(yùn)算
low_time=0 ;
{ //在1°范圍內(nèi)進(jìn)行PID運(yùn)算
for(i=0;i<10;i++)
//get_temper();
rin=temper;
// Read Input
rout=PIDCalc(&spid,rin); //執(zhí)行PID運(yùn)算
// Perform PID Interation
if(high_time<=100) //限制最大值
high_time=(unsigned char)(rout/800);
high_time=100;
low_time=(100-high_time);
else if(set_temper<=temper) //當(dāng)實(shí)際溫度大于設(shè)置溫度時(shí)
if(temper-set_temper>0)//如果實(shí)際溫度大于設(shè)定溫度
high_time=0 ;
low_time=100 ;
for(i=0;i<10;i++)
//get_temper();
rin=temper;
// Read Input
if(high_time<100) //此變量是無(wú)符號(hào)字符型
high_time=(unsigned char)(rout/10000);
high_time=0 ;//限制不輸出負(fù)值
//EA=1;
T1中斷服務(wù)子程序,用于控制電平的翻轉(zhuǎn) ,40us*100=4ms周期
void serve_T1()interrupt 3 using 1
if(++count<=(high_time))
output=0 ;
else if(count<=100)
output=1 ;
count=0 ;
TH1=0x2f ;
TL1=0xe0 ;
void PIDBEGIN()
TH1=0x2f ;
TL1=0x40 ;
ET1=1 ;
TR1=1 ;
high_time=50 ;
low_time=50 ;
PIDInit(&spid);
// Initialize Structure
spid.Proportion=10 ;
// Set PID Coefficients
spid.Integral=8 ;
spid.Derivative=6 ;
spid.SetPoint=100 ;
// Set PID Setpoint
#endif
main
while(1){
PIDBEGIN();
if(hengwen==0)
compare_temper(temp4,temp5);
temp4是設(shè)定溫度和temp5時(shí)實(shí)際溫度,求高人指點(diǎn),急急急
