查看: 2601|回復(fù): 2
求助,滾屏點(diǎn)陣的程序代碼不會啊
ID:92462 發(fā)表于 2015-11-18 21:25 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
我原理圖都畫出來了,就是C語言沒學(xué)好,代碼不會寫,寫的程序一直用不了,求哪位大神無聊時幫我寫寫,原理圖,程序都打包上傳了,我的那個不成功,求大神啊,或者可以加我QQ交流交流:1204106723
這個是程序:(老是感覺不對)
#include <reg51.h>
#include <intrins.h>
#define  DATAOUT P2    //P2 use as data,  you can change
#define  SPEED  13
void ymove(char dir,unsigned char *ptr,char speed);
void xmove(char dir,unsigned char *ptr,char n,char speed);
void delay(unsigned int a);
void display();
void displaytime(char time);
void init164();
sbit  ADATA= DATAOUT^0;
sbit  ASCK=  DATAOUT^1;
sbit  LATCH= DATAOUT^2;
sbit  BDATA= DATAOUT^3;
sbit  BCLK=  DATAOUT^4;
code unsigned char hu[32]={
/*--  文字:  湖  --*/
/*--  宋體12;  此字體下對應(yīng)的點(diǎn)陣為:寬x高=16x16   --*/
0x80,0x00,0x84,0x78,0x88,0x48,0xE8,0x4B,0x81,0x48,0x82,0x78,0x82,0x48,0xE8,0x4B,
0x28,0x4A,0x24,0x7A,0x27,0x4A,0xE4,0x4B,0x24,0x4A,0x04,0x44,0x04,0x54,0x00,0x22
code unsigned char nan[32]={
/*--  文字:  南  --*/
0x80,0x00,0x80,0x00,0xFF,0x7F,0x80,0x00,0x80,0x00,0xFE,0x3F,0x12,0x24,0x22,0x22,
0xF2,0x27,0x82,0x20,0x82,0x20,0xFA,0x2F,0x82,0x20,0x82,0x20,0x82,0x28,0x02,0x10
code unsigned char xin[32]={
/*--  文字:  信  --*/
0x10,0x02,0x10,0x04,0xD0,0x7F,0x08,0x00,0x08,0x00,0x8C,0x3F,0x0C,0x00,0x0A,0x00,
0x89,0x3F,0x08,0x00,0x08,0x00,0x88,0x3F,0x88,0x20,0x88,0x20,0x88,0x3F,0x88,0x20
code unsigned char xi[32]={
/*--  文字:  息  --*/
0x01,0x00,0x02,0x00,0x1F,0xF0,0x10,0x10,0x1F,0xF0,0x10,0x10,0x1F,0xF0,0x10,0x10,
0x1F,0xF0,0x10,0x10,0x01,0x00,0x08,0x84,0x48,0x92,0x48,0x12,0x87,0xF0,0x00,0x00
code unsigned char zhi[32]={
/*--  文字:  職  --*/
0x00,0x00,0xFF,0x00,0x24,0xFC,0x24,0x84,0x3C,0x84,0x24,0x84,0x24,0x84,0x3C,0x84,
0x24,0xFC,0x24,0x84,0x2E,0x00,0xF4,0x48,0x44,0x44,0x04,0x84,0x04,0x82,0x05,0x02
code unsigned char ye[32]={
/*--  文字:  業(yè)  --*/
0x04,0x40,0x04,0x40,0x04,0x40,0x04,0x40,0x44,0x44,0x24,0x44,0x24,0x48,0x14,0x48,
0x14,0x50,0x14,0x60,0x04,0x40,0x04,0x40,0x04,0x40,0x04,0x40,0xFF,0xFE,0x00,0x00
code unsigned char ji[32]={
/*--  文字:  技  --*/
0x10,0x20,0x10,0x20,0x10,0x20,0x13,0xFE,0xFC,0x20,0x10,0x20,0x10,0x20,0x15,0xFC,
0x18,0x84,0x30,0x88,0xD0,0x48,0x10,0x50,0x10,0x20,0x10,0x50,0x51,0x88,0x26,0x06
code unsigned char shu[32]={
/*--  文字:  術(shù)  --*/
0x01,0x00,0x01,0x20,0x01,0x10,0x01,0x10,0x7F,0xFC,0x03,0x80,0x05,0x40,0x05,0x40,
0x09,0x20,0x11,0x10,0x21,0x08,0x41,0x04,0x81,0x02,0x01,0x00,0x01,0x00,0x01,0x00
code unsigned char xue[32]={
/*--  文字:  學(xué)  --*/
0x22,0x08,0x11,0x08,0x11,0x10,0x00,0x20,0x7F,0xFE,0x40,0x02,0x80,0x04,0x1F,0xE0,
0x00,0x40,0x01,0x80,0xFF,0xFE,0x01,0x00,0x01,0x00,0x01,0x00,0x05,0x00,0x02,0x00
code unsigned char yuan[32]={
/*--  文字:  院  --*/
0x00,0x40,0x78,0x20,0x4B,0xFE,0x52,0x02,0x54,0x04,0x61,0xF8,0x50,0x00,0x48,0x00,
0x4B,0xFE,0x48,0x90,0x68,0x90,0x50,0x90,0x41,0x12,0x41,0x12,0x42,0x0E,0x44,0x00
code unsigned char xing[32]={
/*--  文字:  信  --*/
0x08,0x40,0x08,0x20,0x0B,0xFE,0x10,0x00,0x10,0x00,0x31,0xFC,0x30,0x00,0x50,0x00,
0x91,0xFC,0x10,0x00,0x10,0x00,0x11,0xFC,0x11,0x04,0x11,0x04,0x11,0xFC,0x11,0x04
code unsigned char xii[32]={
/*--  文字:  息  --*/
code unsigned char gong[32]={
/*--  文字:  工  --*/
0x00,0x00,0x00,0x00,0x7F,0xFC,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,
0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0xFF,0xFE,0x00,0x00,0x00,0x00
code unsigned char cheng[32]={
/*--  文字:  程  --*/
0x08,0x00,0x1D,0xFC,0xF1,0x04,0x11,0x04,0x11,0x04,0xFD,0xFC,0x10,0x00,0x30,0x00,
0x39,0xFE,0x54,0x20,0x54,0x20,0x91,0xFC,0x10,0x20,0x10,0x20,0x13,0xFE,0x10,0x00
code unsigned char xix[32]={
/*--  文字:  系  --*/
0x00,0xF8,0x3F,0x00,0x04,0x00,0x08,0x20,0x10,0x40,0x3F,0x80,0x01,0x00,0x06,0x10,
0x18,0x08,0x7F,0xFC,0x01,0x04,0x09,0x20,0x11,0x10,0x21,0x08,0x45,0x04,0x02,0x00
code unsigned char aa[32]={
/*--  文字:4  --*/
/*--  寬度x高度=16x16  --*/
0x00,0x00,0x00,0x00,0x00,0x40,0x00,0xC0,0x01,0xC0,0x03,0xC0,0x06,0xC0,0x0C,0xC0,
0x18,0xC0,0x3F,0xF0,0x3F,0xF0,0x00,0xC0,0x00,0xC0,0x00,0xC0,0x00,0xC0,0x00,0x00
code unsigned char bb[32]={
/*--  文字:0  --*/
0x00,0x00,0x00,0x00,0x0F,0xF0,0x0F,0xF0,0x0C,0x30,0x0C,0x30,0x0C,0x30,0x0C,0x30,
0x0C,0x30,0x0C,0x30,0x0C,0x30,0x0C,0x30,0x0F,0xF0,0x0F,0xF0,0x00,0x00,0x00,0x00
code unsigned char cc[32]={
/*--  文字:3  --*/
0x00,0x00,0x00,0x00,0x07,0xF8,0x07,0xF8,0x00,0x18,0x00,0x18,0x00,0x18,0x03,0xF8,
0x03,0xF8,0x00,0x18,0x00,0x18,0x00,0x18,0x07,0xF8,0x07,0xF8,0x00,0x00,0x00,0x00
code unsigned char xiang[32]={
/*--  文字:  項  --*/
0x00,0x00,0x01,0xFE,0x00,0x20,0xFC,0x40,0x11,0xFC,0x11,0x04,0x11,0x24,0x11,0x24,
0x11,0x24,0x11,0x24,0x11,0x24,0x1D,0x44,0xE0,0x50,0x40,0x88,0x01,0x04,0x02,0x02
code unsigned char mu[32]={
/*--  文字:  目  --*/
0x00,0x00,0x3F,0xF8,0x20,0x08,0x20,0x08,0x20,0x08,0x3F,0xF8,0x20,0x08,0x20,0x08,
0x20,0x08,0x3F,0xF8,0x20,0x08,0x20,0x08,0x20,0x08,0x20,0x08,0x3F,0xF8,0x20,0x08
code unsigned char xiao[32]={
/*--  文字:  小  --*/
0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x11,0x10,0x11,0x08,0x11,0x04,
0x21,0x04,0x21,0x02,0x41,0x02,0x81,0x02,0x01,0x00,0x01,0x00,0x05,0x00,0x02,0x00
code unsigned char zu[32]={
/*--  文字:  組  --*/
0x10,0x00,0x11,0xF8,0x21,0x08,0x21,0x08,0x49,0x08,0xF9,0xF8,0x11,0x08,0x21,0x08,
0x41,0x08,0xF9,0xF8,0x41,0x08,0x01,0x08,0x19,0x08,0xE1,0x08,0x47,0xFE,0x00,0x00
unsigned  char idata buffer[32];
void main(void)
        unsigned char i;
        init164();
                for(i=0;i<32;i++)
                        buffer=hu;
                        buffer=nan;
                        buffer=xin;
                        buffer=xi;
                        buffer=zhi;
                        buffer=ye;
                        buffer=ji;
                        buffer=shu;
                        buffer=xue;
                        buffer=yuan;
                displaytime(1);
                xmove(1,0,SPEED);
                xmove(1,hu,3,SPEED);
                xmove(1,nan,3,SPEED);
                xmove(1,xin,3,SPEED);
                xmove(1,xi,3,SPEED);
                xmove(1,zhi,3,SPEED);
                xmove(1,ye,3,SPEED);
                xmove(1,ji,3,SPEED);
                xmove(1,shu,3,SPEED);
                xmove(1,xue,3,SPEED);
                xmove(1,yuan,3,SPEED);
                xmove(1,0,SPEED);
                displaytime(1);
                ymove(1,0,SPEED);
                ymove(1,xing,3,SPEED);
                ymove(1,xii,3,SPEED);
                ymove(1,gong,3,SPEED);
                ymove(1,cheng,3,SPEED);
                ymove(1,xix,3,SPEED);
                ymove(1,aa,3,SPEED);
                ymove(1,bb,3,SPEED);
                ymove(1,cc,3,SPEED);
                ymove(1,xiang,3,SPEED);
                ymove(1,mu,3,SPEED);
                ymove(1,xiao,3,SPEED);
                ymove(1,zu,3,SPEED);
                ymove(0,0,SPEED);
                displaytime(1);
                xmove(1,hu,1,SPEED);
                xmove(1,nan,1,SPEED);
                xmove(1,xin,1,SPEED);
                xmove(1,xi,1,SPEED);
                xmove(1,zhi,1,SPEED);
                xmove(1,ye,1,SPEED);
                xmove(1,ji,1,SPEED);
                xmove(1,shu,1,SPEED);
                xmove(1,xue,1,SPEED);
                xmove(1,yuan,1,SPEED);
/*************  子函數(shù)   ******************/
        while(a--);
void display()
        unsigned char hang,ib,k,tmp;
    DATAOUT= 0x0;
        BDATA = 0;
        for(hang=0;hang<16;hang++)
                ASCK =0;
                LATCH=0;
                BCLK =0;
                for(ib=0;ib<2;ib++)
                        tmp = buffer[hang*2+ib];
                        for(k=0;k<8;k++)
                                tmp <<=1;
                                ASCK  =0;
                                ADATA =CY;
                                ASCK  =1;
                DATAOUT|=0x14;
                //LATCH=1;
                //BCLK=1;
                BDATA=1;
        delay(64);
        ASCK =0;
        ASCK =1;
        unsigned char i;
        while(time--)
                i=130;
                while(i--)
                         display();
void init164()
        char i;
        BDATA=1;
        for(i=0;i<16;i++)
                BCLK =0;
                BCLK =1;
{      /*       方向                    n是要移動的漢字個數(shù)        移動速度*/
        unsigned char  i=0,  ib=0;
        unsigned int   tmp=0, speedm=0;
        unsigned char  buffer2[16];         //半個漢字的緩存
        n*=20;     //左半字和右半字,所以要x2
        for(i=0;i<16;i++)   //清零
                buffer2=0;
        if(dir == 1)
/****     向左移動    ****/
                for(n;n>0;n--)
                        if(ptr != 0)
                                tmp = n%2;        //判斷是左半字還是右半字
                                for(i=0;i<16;i++)
                                        buffer2=ptr[i*2+tmp];
                                if(tmp)                //tmp為1時,將地址指向下一個漢字
                                        ptr+=32;
                        for(tmp=8;tmp>0;tmp--)  //要移動8列
                                ib=0;
                                for(i=0;i<16;i++)
                                {                //要移16行,共16個字節(jié)
                                        buffer[ib] <<=1; //移第一個半字
                                        if(buffer[ib+1] & 0x80)
                                                buffer[ib]++;
                                        ib++;
                                        buffer[ib]<<=1;                //移后半字
                                        if(buffer2 & 0x80)
                                                buffer[ib]++;
                                        ib++;
                                        buffer2<<=1;                //緩沖左半字向左移一位
                                speedm=speed;        //更新點(diǎn)陣
                                while(speedm--)
                                        display();
   /******  向右移動   ******/
                for(n;n>0;n--)
                        if(ptr != 0)
                                tmp = (n+1) % 2  ;        //判斷左半字還是右半字
                                for(i=0;i<16;i++)
                                if(tmp == 0)                //tmp為0時,將地址指向下一個漢字
                                        ptr+=32;
                                ib=0;
                                for(i=0;i<16;i++)
                                        buffer[ib+1] >>= 1;             //移右半字
                                        if(buffer[ib] & 0x01)
                                                buffer[ib+1] |=0x80 ;
                                        buffer[ib] >>= 1;            //移左半字
                                        if(buffer2 & 0x01)
                                                buffer[ib] |= 0x80;
                                        ib+=2;
                                        buffer2 >>=1;                //下個漢字的右半字向右移一位
                                speedm=speed;
                                while(speedm--)  //更新點(diǎn)陣
                                        display();
void ymove(char dir,unsigned char *ptr, char speed)
{                   //dir=1上移動,dir=0為下移動
        char i=0, j=0, ib=0;
        if(dir==0)
   /****  向下移  ****/
                ib=31;
                for(i=16;i>0;i--)   //下移16行
                        for(j=29;j>-1;j--)
                                buffer[j+2]=buffer[j];        //將上一行的內(nèi)容復(fù)制到下一行
                        if(ptr==0)
                        {                                //移空時,buffer的首行用0移入
                                buffer[0]=0;
                                buffer[1]=0;
                        {                                //否則,處理buffer的首行元素
                            buffer[1]=ptr[ib];
                                buffer[0]=ptr[ib-1];
                                ib=ib-2;
                        speedm=speed;
                                display();
/****** 向上移 *******/
                ib=0;          //數(shù)組元素序號
                for(i=0;i<16;i++)    //上移16行
                        for(j=0;j<30;j++)           //將下一行的內(nèi)容復(fù)制到上一行
                                buffer[j]=buffer[j+2];
                        if(ptr==0)        //移入為空,buffer的末行用0移入
                                buffer[30]=0;
                                buffer[31]=0;
                        {                        //否則,處理buffer的末行元素
                                buffer[30]=ptr[ib];
                                buffer[31]=ptr[ib+1];
                                ib=ib+2;
                        while(speedm--)
                                display();
這個是仿真圖
這個是仿真圖
相關(guān)帖子
ID:92462 發(fā)表于 2015-11-18 21:26 | 只看該作者
由10個74ls595,兩個74ls164,和單片機(jī)控制的
ID:92462 發(fā)表于 2015-11-18 21:30 | 只看該作者
求大神來指教,或者加我QQ指教也行
