查看: 3696|回復(fù): 1
16*16的點陣模擬電梯運(yùn)行時的樓層顯示 各位大神幫忙看看程序,一直搞不定啊
ID:90798 發(fā)表于 2015-12-24 18:20 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
我想用16*16的點陣模擬電梯運(yùn)行時的樓層顯示,但是寫出來的程序一直顯示不出來,按按鍵也沒反應(yīng),程序如下:(用4片595控制點陣)
#include<reg51.h>
#include<intrins.h>
#define  uchar  unsigned  char
#define  uint   unsigned  int
uchar code NUM_HANG[]={
0x80,0x00,0x40,0x00,0x20,0x00,0x10,0x00,0x08,0x00,0x04,0x00,0x02,0x00,0x01,0x00,
0x00,0x80,0x00,0x40,0x00,0x20,0x00,0x10,0x00,0x08,0x00,0x04,0x00,0x02,0x00,0x01,};
uchar  code  Table_of_Digits[8][32]=
{//數(shù)字8的字碼
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xC0,0x02,0x20,0x02,0x20,
0x03,0xE0,0x02,0x20,0x02,0x20,0x01,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
//數(shù)字7的字碼
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xE0,0x00,0x20,0x00,0x20,
0x00,0x40,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
//數(shù)字6的字碼
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xC0,0x02,0x20,0x03,0xC0,
0x02,0x20,0x02,0x20,0x01,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
//數(shù)字5的字碼
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xE0,0x02,0x00,0x03,0xC0,
0x00,0x20,0x00,0x20,0x03,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
//數(shù)字4的字碼
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x00,0xC0,0x01,0x40,
0x02,0x40,0x07,0xE0,0x00,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
//數(shù)字3的字碼
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xC0,0x02,0x20,
0x00,0xC0,0x00,0x20,0x02,0x20,0x01,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
//數(shù)字2的字碼
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xC0,0x02,0x20,0x00,0x20,
0x00,0x40,0x00,0x80,0x01,0x00,0x03,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
//數(shù)字1的字碼
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x03,0x80,0x00,0x80,0x00,0x80,
0x00,0x80,0x00,0x80,0x00,0x80,0x03,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
uchar i=0,t=0,j=0,a=0,m=0,n=0;
char   offset=0;
static  int Current_floor=0,Pressed_Key_up=0,  Pressed_Key_down=0,b=0,c=0,max=0,min=0;// Current_floor當(dāng)前樓層  Pressed_Key_up   上升請求 Pressed_Key_down  下降請求
int  flag;
int  floor_up[8]={9,9,9,9,9,9,9,9};
int  floor_down[8]={0,0,0,0,0,0,0,0};
sbit  KEY1=P2^0;         //定義按鍵P1口
sbit  KEY2=P2^1;
sbit  KEY3=P2^2;
sbit  KEY4=P2^3;
sbit  KEY5=P2^4;
sbit  KEY6=P2^5;
sbit  KEY7=P2^6;
sbit  KEY8=P2^7;
sbit  SPEAK=P0^7;        //定義蜂鳴器
sbit SCK=P3^6;
sbit LCK=P3^5;
sbit SDI=P3^4;
void  Key_up_comparison();        //函數(shù)聲明,把floor_up[]從小到大排列
void  Key_down_comparison();          //把floor_down[]從大到小排列
void  max_min_comparison();       //比較出floor_up[]的最大值(max)和flor_down[]的最小值(min)
void HC595_Send(uchar dat1,uchar dat0,uchar dat2,uchar dat3);
void  main()           //主函數(shù)
  SPEAK=0;
  TMOD=0x01;               //T0方式
  TH0=(-6000)/256;                   //6ms定時
  TL0=(-6000)%256;
  IT0=1;
  IE=0x83;
  TR0=1;
  ET0=1;
  EA=1;
  Pressed_Key_up=floor_up[0];
void  LED_Display()  interrupt 1                                  //進(jìn)入中斷,顯示樓層                           interrupt1
   TL0=(-6000)%256;
   Pressed_Key_down=floor_down[0];
   if(flag==1)        //上升標(biāo)志
     if(Pressed_Key_up!=9)
           if(Pressed_Key_up>Current_floor)
            m=(7-Current_floor)+i;
                for(n=0;n<32;n=n+2)        //一共有16行,所以刷16次
                                HC595_Send(~Table_of_Digits[m][n],~Table_of_Digits[m][n+1],NUM_HANG[n],NUM_HANG[n+1]);
             if(++i==8)
                          i=0;
                     if(++t==250)
                    t=0;
                        ++Current_floor;
                    else  if(Pressed_Key_up<Current_floor);
                   else  if(Pressed_Key_up==Current_floor)                //到達(dá)請求樓層
                            if(++i==8)
                          i=0;
                     SPEAK=~SPEAK;                           //蜂鳴器響
                         if(++t==250)
              t=0;
                          if(Current_floor=Pressed_Key_up)
                           Current_floor=Pressed_Key_up;
                           if(Current_floor==max)
                             flag=0;
                           floor_up[0]=9;
                   else  if(Pressed_Key_up==9)                  //無按鍵按下,即無請求,則掃描當(dāng)前樓層
                            if(++i==8)
                          i=0;
                         if(++t==250)
              t=0;
                            else if(flag==0)
                          if(Pressed_Key_down!=0)                                                          //有下降的請求
                           if(Pressed_Key_down>Current_floor);
                           else  if(Pressed_Key_down<Current_floor)                          //下降的顯示
                               m=(7-Current_floor)+i+offset;
                     if(++i==8)
                              i=0;
                          if(++t==25)
                        t=0;
                            if(--offset==-8)
                             offset=0;
                             --Current_floor;
                         else  if(Pressed_Key_down==Current_floor)        //到達(dá)請求的樓層
                            if(++i==8)
                          i=0;
                         if(++t==250)
              t=0;
                          if(Current_floor=Pressed_Key_down)
                           Current_floor=Pressed_Key_down;
                           if(Current_floor==min)
                             flag=1;
                           floor_down[0]=0;
                   else if(Pressed_Key_down==0)                           //無按鍵按下,即請求,則掃描顯示當(dāng)前樓層
                            if(i==8)
                          i=0;
                         if(t==250)
                         { t=0;}
                 void  Key_detection()  interrupt 0        //按下按鍵,進(jìn)入外部中斷,將上升請求和下降請求放入數(shù)組中去,并且判斷標(biāo)志位flag
//                 P0=0xff;
                 i=0;                                    //按鍵消抖
                   if(KEY1==0)   j=8;
                else  if(KEY2==0)   j=7;
                else  if(KEY3==0)   j=6;
                   else  if(KEY4==0)   j=5;
                   else  if(KEY5==0)   j=4;
                   else  if(KEY6==0)   j=3;
                   else  if(KEY7==0)   j=2;
                   else  if(KEY8==0)   j=1;
                if(j>Current_floor)                      //將上升請求放入數(shù)組中
                if(floor_down[0]==0)
                flag=1;
                floor_up[b++]=j;
        if(b==8)
                b=0;
                else if(j<Current_floor)                                 //將下降請求放入數(shù)組
                if(floor_up[0]==9)
                flag=0;
                floor_down[c++]=j;
                if(c==8)
                 c=0;
                else if(j==Current_floor);
                   void   Key_up_comparison()                                  //把floor_up[]按從小到大的順序排列
                 int  a1,a2,a3=0;
                 for(a2=0;a2<7;a2++)
                  for(a1=0;a1<7;++a1)
                   if(floor_up[a1]>floor_up[a1+1])
                    a3=floor_up[a1];
                        floor_up[a1]=floor_up[a1+1];
                        floor_up[a1+1]=a3;
                   if(floor_up[a1]==floor_up[a1+1])
                   floor_up[a1+1]=9;
              void  Key_down_comparison()                                        //把floor_down[]按從大到小的順序排列
           int  a1,a2,a3=0;
           for(a2=0;a2<7;a2++)
            for(a1=0;a1<7;++a1)
                 if(floor_down[a]<floor_down[a1+1])
                  a3=floor_down[a1];
                  floor_down[a1]=floor_down[a1+1];
                  floor_down[a1+1]=a3;
                 if(floor_down[a1]=floor_down[a1+1])
                 floor_down[a1+1]=0;
          void  max_min_comparison()                                          //求出  floor_up[]的最大(max)和floor_down[]的最小(min)
           int j;
           for(j=1;j<7;j++)
           if(floor_down[j]==0);
           else if(floor_down[j+1]==0)
                min=floor_down[j];
           else if(floor_down[j]>floor_down[j+1])
                min=floor_down[j+1];
           else min=floor_down[j];
           for(j=1;j<7;j++)
           if(floor_up[j]==9);
           else if(floor_up[j+1]==9)
                max=floor_up[j];
           else if(floor_up[j]<floor_up[j+1])
                max=floor_up[j+1];
           else max=floor_up[j];
            void HC595_Send(uchar dat1,uchar dat0,uchar dat3,uchar dat2)                                //顯示程序
        uchar i;
        SCK=1;
        LCK=1;
        for(i=0;i<8;i++)
                SDI=dat0&0x01;                //從高位到低位
                dat0>>=1;
                SCK=0;
                _nop_();
                _nop_();
                SCK=1;
                _nop_();
                _nop_();
        for(i=0;i<8;i++)
                SDI=dat1&0x01;                //從高位到低位
                dat1>>=1;
                SCK=0;
                _nop_();
                _nop_();
                SCK=1;
                _nop_();
                _nop_();
        for(i=0;i<8;i++)
                SDI=dat2&0x01;                //從高位到低位
                dat2>>=1;
                SCK=0;
                _nop_();
                _nop_();
                SCK=1;
                _nop_();
                _nop_();
        for(i=0;i<8;i++)
                SDI=dat3&0x01;                //從高位到低位
                dat3>>=1;
                SCK=0;
                _nop_();
                _nop_();
                SCK=1;
                _nop_();
                _nop_();
        LCK=0;        //下面是輸出時鐘
        _nop_();
        _nop_();
        LCK=1;
        _nop_();
        _nop_();
ID:100206 發(fā)表于 2015-12-24 19:59 | 只看該作者
